Galaxy A5 (2017)
Simply Elegant
Elegance in its purest form. Crafted with minimalism in mind, its highly resistant rear 3D Glass and optimal 5.2" display fuse together flawlessly. Discover a seamless design for maximum enjoyment.
Uniform all around
Design that is a delight to hold. Sitting flush with the 3D curved back, the absence of any camera protrusion allows for a smooth and symmetrical design from all angles.
Capture richer stories
Grant your photos the added depth and detail they deserve thanks to the Galaxy A5's improved 16MP camera. And with its speedy and accurate Auto Focus, you’ll be able to capture unforgettable moments before they get away.
Expand your creativity
Enjoy greater creative control to make your visual storytelling much more brilliant. Optimise portraits or spice up colour tones with instant camera filters to enhance your favourite photos.
Capture life in optimal light
With its 16MP front camera and bright display that doubles as a flash you capture sharper results even in low-light conditions. It also features a floating shutter optimised for better grip so images stay blur-free.
Safeguarded for the unexpected
Reliable protection so you can keep up with life wherever it takes you. Equipped with IP68 to withstand the elements, it shields out everything from dust to liquids. Enjoy protection from the elements in most situations.
Powered for serious users
Power up in no time. With a longer lasting battery and fast charging capabilities, you'll be able to stay in charge for longer.
Pack more in
Seamless balance, signature performance. With up to 256GB of expandable storage you can store even more of your precious memories and music.
View in an instant
Get the essentials without even waking up your phone so you preserve time and power. With Always On Display your clock and calendar are always in sight for whenever you need them.
Safe and sound
Secure Folder keeps selected apps and sensitive data locked down and separate from the regular content on your device. It also saves you from having to log in every time with one time authentication.
All within reach
Peace of mind you can count on. Back up, upgrade and sync your data across all your Galaxy devices so everything is right where you need it. Even better, every Samsung Cloud account comes with 15GB of storage.
Works both ways
Thanks to its reversible plug, a USB Type-C cable goes to work whichever way you plug it in to your device. This means you can enjoy hassle-free charging without worrying which side is up.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
Simply elegant
Elegance in its purest form. Crafted with minimalism in mind for maximum enjoyment its highly resistant rear 3D Glass and optimal 5.2" display fuse together flawlessly to provide a remarkably seamless design. -
Uniform all around
Design that is a delight to hold. Sitting perfectly level with the rear casing the absence of any camera protrusion allows for uniformaly smooth and symmetrical design from all angles. -
Grant your photos the added depth and detail they deserve thanks to its powerful 16 MP camera. And with its speedy and accurate Auto Focus, you'll be able to capture unforgettable moments before they get away. -
Enjoy greater creative control to make your visual storytelling much more brilliant. Optimize portraits or spice up color tones with a set of preset camera filters to enhance your favorite photos. -
With its 16 MP front camera and bright display that doubles as a flash you capture sharper results even in low-light conditions. It also features a floating shutter optimized for better grip so images stay blur-free. -
Reliable protection so you can keep up with life wherever it takes you. Equipped with IP68 to withstand the elements it shields out everything from liquids to dust in most situations. -
Works both ways
Thanks to its reversible plug orientation USB Type-C cable goes to work whichever way you plug it in to your device. This means you can enjoy hassle-free charging without worrying which side is up.
- Samsung Galaxy A5 (2017) - sand gold - 4G smartphone - 32 GB - GSM
- Product Type
- 4G smartphone
- Manufacturer Model Number
- SM-A520F
- Display
- OLED display - 1920 x 1080 pixels - 5.2" - Super AMOLED
- Processor
- 1.9 GHz (8-core)
- Memory
- RAM 3 GB / 32 GB
- Supported Memory Card
- microSDXC slot - up to 256 GB
- Operating System
- Google Android
- Main Camera
- 16 Megapixel - CMOS - f/1.9 - focus: automatic
- Front Camera
- 16 Megapixel - CMOS f/1.9
- Service Provider
- Not specified
- SIM Card
- Single-SIM - nano SIM
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth, ANT+/ANT
- Security Devices
- Fingerprint reader
- Messaging Services
- SMS, MMS
- Connectors
- 3.5 mm headset jack, USB-C
- Talk Time
- Up to 960 minutes
- Protection
- Dustproof, waterproof
- Sand gold
- 71.4 mm x 7.9 mm x 146.1 mm
- 159 g
- Specific Absorption Rate (SAR)
- 0.522 W/kg (head) , 1.39 W/kg (body)
- 2-year warranty
- Product Type
- Smartphone
- SM-A520F
- Form Factor
- Touch
- Protection
- 71.4 mm
- 7.9 mm
- 146.1 mm
- 159 g
- Body Colour
- Sand gold
- Body Material
- Metal, glass
- SAR Value
- 1.39 W/kg (body), 0.522 W/kg (head)
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Google Android
- Navigation
- GPS, GLONASS, BeiDou
- SIM Card Type
- Nano SIM
- SIM Card Qty
- Single-SIM
- Input Device
- Multi-touch
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 17, Band 20, Band 28, Band 38, Band 40, Band 41
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700b, FDD 800 DD, FDD 700 APT, TDD 2600, TDD 2300, TDD 2500
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 4.2, ANT+/ANT
- Bluetooth Profiles
- HFP, HSP, OPP, PAN, A2DP, AVRCP, HID, PBAP, MAP, HOGP
Phone Features
- Phone Functions
- Speakerphone, call timer, conference call, flight mode, vibrating alert
- Sensors
- Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, RGB sensor, geomagnetic sensor
- Security Devices
Media Player
- Supported Digital Audio Standards
- WAV, WMA, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, AWB, IMY, RTTTL, RTX, OTA
- Supported Digital Video Standards
- MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, M4V, WebM
- Clock Speed
- 1.9 GHz
- Processor Core Qty
- 8-core
- RAM
- 3 GB
- Internal Memory Capacity
- 32 GB
- User Memory
- 23.1 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 256 GB
Front Camera
- Sensor Resolution
- 16 Megapixel
- Sensor Type
- CMOS
- Lens Aperture
- F/1.9
- Light Source
- Display flash
Main Camera
- Sensor Resolution
- 16 Megapixel
- Sensor Type
- CMOS
- Lens Aperture
- F/1.9
- Focus Adjustment
- Automatic
- Camera Modes
- Food mode
- Light Source
- LED light
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps
Display
- OLED display
- Technology
- Super AMOLED
- Diagonal Size
- 5.2"
- Display Resolution
- Display Format
- Full HD
- Colour Depth
- 16.7 million colours
- Connector Type
- Headset jack - mini-phone 3.5mm , USB Type-C - 24 pin USB-C
- Capacity
- 3000 mAh
- Talk Time
- 960 minutes
- Run Time Details
- Talk (WCDMA): up to 960 min , Active online usage (3G): up to 13 hrs , Active online usage (LTE): up to 16 hrs , Active online usage (Wi-Fi): up to 18 hrs , Playback (video): up to 19 hrs , Playback (audio): up to 53 hrs , Playback (audio (Always On Display Off)): up to 78 hrs
- IP68
- Included Accessories
- Power adapter
- Limited warranty - 2 years
