Samsung Galaxy A5 (2017) - 5.2" Super AMOLED Full HD Display, 32GB, 16MP CMOS Camera - Blue Mist
Quicklinx: CS99WS00 Mfr#: SM-A520FZBABTU
Colours:
  • microSDHC
  • Android
Galaxy A5 (2017)
Simply Elegant
Elegance in its purest form. Crafted with minimalism in mind, its highly resistant rear 3D Glass and optimal 5.2" display fuse together flawlessly. Discover a seamless design for maximum enjoyment.
Uniform all around
Design that is a delight to hold. Sitting flush with the 3D curved back, the absence of any camera protrusion allows for a smooth and symmetrical design from all angles.
Capture richer stories
Grant your photos the added depth and detail they deserve thanks to the Galaxy A5's improved 16MP camera. And with its speedy and accurate Auto Focus, you’ll be able to capture unforgettable moments before they get away.
Expand your creativity
Enjoy greater creative control to make your visual storytelling much more brilliant. Optimise portraits or spice up colour tones with instant camera filters to enhance your favourite photos.
Capture life in optimal light
With its 16MP front camera and bright display that doubles as a flash you capture sharper results even in low-light conditions. It also features a floating shutter optimised for better grip so images stay blur-free.
Safeguarded for the unexpected
Reliable protection so you can keep up with life wherever it takes you. Equipped with IP68 to withstand the elements, it shields out everything from dust to liquids. Enjoy protection from the elements in most situations.
Powered for serious users
Power up in no time. With a longer lasting battery and fast charging capabilities, you'll be able to stay in charge for longer.
Pack more in
Seamless balance, signature performance. With up to 256GB of expandable storage you can store even more of your precious memories and music.
View in an instant
Get the essentials without even waking up your phone so you preserve time and power. With Always On Display your clock and calendar are always in sight for whenever you need them.
Safe and sound
Secure Folder keeps selected apps and sensitive data locked down and separate from the regular content on your device. It also saves you from having to log in every time with one time authentication.
All within reach
Peace of mind you can count on. Back up, upgrade and sync your data across all your Galaxy devices so everything is right where you need it. Even better, every Samsung Cloud account comes with 15GB of storage.
Works both ways
Thanks to its reversible plug, a USB Type-C cable goes to work whichever way you plug it in to your device. This means you can enjoy hassle-free charging without worrying which side is up.
  • Simply elegant
    Elegance in its purest form. Crafted with minimalism in mind for maximum enjoyment its highly resistant rear 3D Glass and optimal 5.2" display fuse together flawlessly to provide a remarkably seamless design.
  • Uniform all around
    Design that is a delight to hold. Sitting perfectly level with the rear casing the absence of any camera protrusion allows for uniformaly smooth and symmetrical design from all angles.
  • Capture richer stories
    Grant your photos the added depth and detail they deserve thanks to its powerful 16 MP camera. And with its speedy and accurate Auto Focus, you'll be able to capture unforgettable moments before they get away.
  • Expand your creativity
    Enjoy greater creative control to make your visual storytelling much more brilliant. Optimize portraits or spice up color tones with a set of preset camera filters to enhance your favorite photos.
  • Capture life in optimal light
    With its 16 MP front camera and bright display that doubles as a flash you capture sharper results even in low-light conditions. It also features a floating shutter optimized for better grip so images stay blur-free.
  • Safeguarded for the unexpected
    Reliable protection so you can keep up with life wherever it takes you. Equipped with IP68 to withstand the elements it shields out everything from liquids to dust in most situations.
  • Works both ways
    Thanks to its reversible plug orientation USB Type-C cable goes to work whichever way you plug it in to your device. This means you can enjoy hassle-free charging without worrying which side is up.
Samsung Galaxy A5 (2017) - blue mist - 4G smartphone - 32 GB - GSM
4G smartphone
Manufacturer Model Number
SM-A520F
Display
OLED display - 1920 x 1080 pixels - 5.2" - Super AMOLED
1.9 GHz (8-core)
RAM 3 GB / 32 GB
Supported Memory Card
microSDXC slot - up to 256 GB
Operating System
Google Android
Main Camera
16 Megapixel - CMOS - f/1.9 - focus: automatic
Front Camera
16 Megapixel - CMOS f/1.9
Service Provider
Not specified
SIM Card
Single-SIM - nano SIM
Wireless Interface
NFC, Wi-Fi 5, Bluetooth, ANT+/ANT
Security Devices
Fingerprint reader
Messaging Services
SMS, MMS
Connectors
3.5 mm headset jack, USB-C
Talk Time
Up to 960 minutes
Protection
Dustproof, waterproof
Blue mist
71.4 mm x 7.9 mm x 146.1 mm
159 g
0.522 W/kg (head) , 1.39 W/kg (body)
Smartphone
SM-A520F
Touch
Protection
71.4 mm
7.9 mm
146.1 mm
159 g
Body Colour
Blue mist
Body Material
Metal, glass
SAR Value
1.39 W/kg (body), 0.522 W/kg (head)
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Google Android
Navigation
GPS, GLONASS, BeiDou
SIM Card Type
Nano SIM
SIM Card Qty
Single-SIM
Input Device
Multi-touch
Messaging & Internet
Messaging Services
SMS, MMS
Communications
Data Transmission
GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 17, Band 20, Band 28, Band 38, Band 40, Band 41
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700b, FDD 800 DD, FDD 700 APT, TDD 2600, TDD 2300, TDD 2500
Wireless Interface
NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 4.2, ANT+/ANT
Bluetooth Profiles
HFP, HSP, OPP, PAN, A2DP, AVRCP, HID, PBAP, MAP, HOGP
Phone Features
Phone Functions
Speakerphone, call timer, conference call, flight mode, vibrating alert
Sensors
Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, RGB sensor, geomagnetic sensor
Security Devices
Fingerprint reader
Media Player
Supported Digital Audio Standards
WAV, WMA, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, AWB, IMY, RTTTL, RTX, OTA
Supported Digital Video Standards
MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, M4V, WebM
Clock Speed
1.9 GHz
Processor Core Qty
8-core
RAM
3 GB
Internal Memory Capacity
32 GB
User Memory
23.1 GB
Supported Flash Memory Cards
microSDHC, microSDXC - up to 256 GB
Front Camera
Sensor Resolution
16 Megapixel
Sensor Type
CMOS
Lens Aperture
F/1.9
Light Source
Display flash
Main Camera
Sensor Resolution
16 Megapixel
Sensor Type
CMOS
Lens Aperture
F/1.9
Focus Adjustment
Automatic
Camera Modes
Food mode
Light Source
LED light
Video Resolutions
1920 x 1080 (1080p) at 30 fps
Display
OLED display
Super AMOLED
Diagonal Size
5.2"
Display Resolution
1920 x 1080 pixels
Display Format
Full HD
Colour Depth
16.7 million colours
Connector Type
Headset jack - mini-phone 3.5mm , USB Type-C - 24 pin USB-C
3000 mAh
Talk Time
960 minutes
Run Time Details
Talk (WCDMA): up to 960 min , Active online usage (3G): up to 13 hrs , Active online usage (LTE): up to 16 hrs , Active online usage (Wi-Fi): up to 18 hrs , Playback (video): up to 19 hrs , Playback (audio): up to 53 hrs , Playback (audio (Always On Display Off)): up to 78 hrs
IP68
Power adapter
