Samsung Galaxy A34 5G 128GB - Black
Quicklinx: H5Q7WS00 Mfr#: SM-A346BZKAEUB
  • microSDHC
  • microSD
Smooth and bright, even in sunlight
Galaxy A34 5G's 1,000nits, Super AMOLED display ensures a clear view even when outside. Enjoy silky smooth viewing on the 6.6-inch awesome screen and refresh rates of up to 120Hz that breathe life into your content
Get it done in a flash
Powered by an octa-core processor and connected in 5G, Galaxy A34 5G inspires your peak performance whether at work or play.
Plenty of juice
With a 5,000mAh (typical) battery, Galaxy A34 5G keeps going for all the snapping, scrolling and streaming you can handle.
  • Awesome viewing experience
    Get immersed! The 1000 nits, and Super AMOLED display on Galaxy A34 5G ensures clear visibility even in outdoor locations. For silky smooth viewing on the 16.65 cm (6.6") awesome screen, switch to a refresh rate of up to 120 Hz and binge-watch like never before.
  • Simple and sleek
    Framed in simple lines and a glastic finish, Galaxy A34 5G is available in fashionable yet timeless colors including Awesome Lime, Awesome Silver and Awesome Graphite.
  • Your moments come to life
    Galaxy A34 5G records your finest moments in bright, vivid colors even in the shakiest moments with its VDIS feature. The camera automatically adjusts the light and the frame to fit the subjects perfectly with Auto Framing.
  • Get it done in a flash
  • Go for days
    With a 5,000 mAh (typical) battery, Galaxy A34 5G is fueled for longer hours while optimizing the battery life based on your phone usage through Adaptive Battery.
  • Sense the palpable difference
    Boosted in precision and feedback, the enhanced haptic experience of Galaxy A34 5G, offers a new range of emotions that interact with your hands.
Samsung Galaxy A34 5G - awesome graphite - 5G smartphone - 128 GB - GSM
5G smartphone
Manufacturer Model Number
SM-A346B/DSN
Display
OLED display - 2340 x 1080 pixels - 6.6" - (120 Hz) - Super AMOLED
2.6 GHz (8-core)
RAM 6 GB / 128 GB
Supported Memory Card
microSDXC slot - up to 1 TB
Operating System
With One UI
Main Camera
48 Megapixel - f/1.8 - focus: automatic
Second Camera
8 Megapixel - ultra wide-angle lens - f/2.2
Third Camera
5 Megapixel - f/2.4 - macro camera
Front Camera
13 Megapixel f/2.2
Service Provider
Not specified
SIM Card
Dual-SIM - nano SIM
Wireless Interface
NFC, Wi-Fi 5, Bluetooth
Security Devices
Fingerprint reader
Connectors
USB-C
Talk Time
Up to 2160 minutes
Protection
Water-resistant, dust-resistant
Awesome graphite
78.1 mm x 8.2 mm x 161.3 mm
199 g
Repairability Index
8.3 (out of 10)
0.546 W/kg (head) , 1.488 W/kg (body) , 2.68 W/kg (limb)
Smartphone
SM-A346B/DSN
Touch
Protection
78.1 mm
8.2 mm
161.3 mm
199 g
Body Colour
Awesome graphite
SAR Value
2.68 W/kg (limb), 0.546 W/kg (head), 1.488 W/kg (body)
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
5G
Service Provider
Not specified
User Interface
One UI
Navigation
GPS, GLONASS, BeiDou, Galileo, QZSS
SIM Card Type
Nano SIM
SIM Card Qty
Dual-SIM
Input Device
Multi-touch
Communications
Data Transmission
FDD-LTE, TDD-LTE, 5G NR FR1
2G Band
850 GSM, 900 GSM, 1800 GSM, 1900 GSM
3G UMTS Band
Band 1, Band 2, Band 4, Band 5, Band 8
3G UMTS Frequency
2100, 1900, 1700, 850, 900
4G LTE Band
Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 17, Band 20, Band 26, Band 28, Band 38, Band 40, Band 41, Band 66
4G LTE Frequency
FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700b, FDD 800 DD, FDD 850+, FDD 700 APT, TDD 2600, TDD 2300, TDD 2500, FDD 1700 - 2110 AWS-3
5G NR Band
N1, n3, n7, n8, n20, n28, n38, n41, n77, n78, n40
5G NR Frequency
FDD 2100, FDD 1800, FDD 2600, FDD 900, FDD 800, FDD 700APT, TDD TD 2600, TDD TD 2500, TDD TD 3700, TDD TD 3500, TDD 2300
Wireless Interface
NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 5.3
Phone Features
Sensors
Accelerometer, gyro sensor, hall sensor, geomagnetic sensor, light sensor
Security Devices
Fingerprint reader
Additional Features
MIMO technology, Samsung KNOX, Samsung Smart Switch, Virtual Proximity Sensing, 5 years of Security Updates, 4 years of OS updates
Media Player
Supported Digital Audio Standards
WAV, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID
Supported Digital Video Standards
MKV, FLV, AVI, 3GP, M4V, WebM, 3G2, MP4
Sound Enhancements
Dolby Atmos sound technology
Clock Speed
2.6 GHz
Processor Core Qty
8-core
RAM
6 GB
Internal Memory Capacity
128 GB
User Memory
101 GB
Supported Flash Memory Cards
microSDHC, microSD, microSDXC - up to 1 TB
Front Camera
Sensor Resolution
13 Megapixel
Lens Aperture
F/2.2
Main Camera
Sensor Resolution
48 Megapixel
Optical Image Stabiliser
Optical Image Stabiliser (OIS)
Lens Aperture
F/1.8
Focus Adjustment
Automatic
Digital Zoom
10x
Light Source
LED flash
Video Resolutions
Slo-mo video 1280 x 720 (720p) at 240 fps, 3840 x 2160 (4K) at 30 fps, Slo-mo video 1280 x 720 (720p) at 480 fps
Auto framing, object eraser, AI image enhancer, Photo Remaster
Second Camera
Sensor Resolution
8 Megapixel
Lens Type
Ultra wide-angle lens
Lens Aperture
F/2.2
Third Camera
Sensor Resolution
5 Megapixel
Lens Aperture
F/2.4
Functions
Macro camera
Display
OLED display
Super AMOLED
Diagonal Size
6.6"
Display Resolution
2340 x 1080 pixels
Display Format
Full HD+
Max Brightness
1000 cd/m²
Colour Depth
16.7 million colours
Refresh Rate
120 Hz
Connector Type
USB Type-C - 24 pin USB-C
5000 mAh
Talk Time
2160 minutes
Run Time Details
Active online usage (LTE): up to 22 hrs , Active online usage (Wi-Fi): up to 22 hrs , Playback (wireless video): up to 21 hrs , Playback (wireless audio): up to 84 hrs , Talk (4G): up to 2160 min
IP67
Sustainability Information
Repairability Index
8.3 (out of 10)
Max Depth of Water Resistance
1 m
