Turn your work/life balance completely around with Samsung Galaxy Book Pro 360. Precisely write down notes with Samsungs redesigned S Pen, immerse yourself in the 120% color volume on a Super AMOLED touchscreen and feel the power of the latest Intel Core processor. And with 5G connectivity, you can work and watch your favorite content anywhere. The new way to PC. Galaxy Book.
Speeds that move as fast as you do
Get the speeds you need to blaze through your work in record time, then binge-watch a show or game with virtually zero lag. -
Get 360 degrees of thin
Turn heads with a stylish, 2-in-1 device that's as powerful as a PC and as thin as a smartphone. Designed to switch between PC and tablet, Galaxy Book Pro 360 is made to make you look good. -
The power to create it, the storage to keep it
Do all the things you need to do with plenty of storage and less lag. -
Work and play with the rest of your Galaxy
Pair your devices and easily jump from your work life to your personal life on your Galaxy Book Pro 360. Set it up as a second screen for twice the productivity, or use it for beautiful note-taking with Samsungs improved S Pen. Plus, you can instantly share files with Quick Share and play mobile games on a larger display. And with your Galaxy Buds Pro, you can smoothly switch from video conferences to catching up with friends. -
Look like a pro, even in your living room
Make WFH work for you with tools that help you look, sound and do your best. Attend a last-minute meeting and still make a good impression with the camera's beauty filter. -
See how the Galaxy Book Pro 360 stacks up
Explore how this Galaxy Book stacks up to others in processor speed, battery power, display quality and more.
- Samsung Galaxy Book2 Pro 360 - 13.3" - Intel Core i7 - 1260P - Evo - 16 GB RAM - 512 GB SSD
- Product Type
- Notebook - flip design
- Operating System
- Win 11 Pro
- Platform Technology
- Intel Evo
- Processor
- Intel Core i7 (12th Gen) - 1260P / 2.1 GHz, up to 4.7 GHz / 18 MB Cache
- Memory
- 16 GB LPDDR5 (provided memory is soldered)
- Storage
- 512 GB SSD - NVMe
- Display
- 13.3" touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel Iris Xe Graphics
- Input Device
- ClickPad, S Pen
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac/ax, Bluetooth 5.1
- Accelerometer, ambient light sensor, gyro sensor
- Security
- Trusted Platform Module (TPM) Security Chip, fingerprint reader
- Graphite
- 30.25 cm x 20.2 cm x 1.15 cm
- 1.04 kg
- Limited warranty - 1 year
- Product Type
- Operating System
- Windows 11 Pro
Processor / Chipset
- CPU
- Intel Core i7 (12th Gen) 1260P / 2.1 GHz
- Max Turbo Speed
- 4.7 GHz
- Number of Cores
- 12-core
- Cache
- L3 - 18 MB
- Intel Evo
- Intel Deep Learning Boost (DL Boost)
- RAM
- 16 GB (provided memory is soldered)
- Technology
- LPDDR5 SDRAM
Storage
- Main Storage
- 512 GB SSD - NVM Express (NVMe)
Display
- 13.3" - AMOLED
- Touchscreen
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Keyboard Name
- Pro keyboard
Audio & Video
- Graphics Processor
- Camera
- Yes - 1080p
- Camera Features
- Auto framing
- Sound
- AKG stereo speakers, dual array microphone
- Dolby Atmos
- Audio Features
- Output: Smart Amp
Input
- Keyboard, ClickPad, S Pen
Communications
- Wireless
- Dual stream (2x2)
- Capacity
- 63 Wh
AC Adapter
- Output
- 65 Watt
Connections & Expansion
- Interfaces Details
- Thunderbolt 4 , 2 x USB-C , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD)
Software
- Software Included
- Samsung Recovery Solution, McAfee LiveSafe (Trial), Samsung Update, Samsung Settings, Samsung Gallery, Studio Plus, Live Message, Samsung Flow, Live Wallpaper, Quick Search, Samsung Notes, Screen Recorder, Galaxy Book Smart Switch, Samsung Security
- Graphite
- Integrated Options
- Security
- Included Accessories
- USB-C power adapter
- IEC 61960
- 1.04 kg
Sustainability Information
- TCO Certified
