The Samsung Flip Cover provides screen protection for the Samsung Galaxy S4 smartphone. The front cover protects the smartphone's screen when it is not in use and it is easily flipped open for full access to the Galaxy S4's screen - whenever you need it. The flip cover is available in a range of different colours, so there is certain to be one to match anyone's personality. Even the most fashion-sensitive smartphone user will find a case, or two or three, that matches their personal style. Additionally, these cases have been specifically designed for the Samsung Galaxy S4 smartphone. The back easily snaps on, replacing the phone's standard battery cover, without making the phone bulky. Installing a Samsung phone case is simple and only takes a few seconds.One of they key features of the flip cover is that you can chat with even the cover closed thanks to the speaker slot.
Replaces the back cover of the Samsung Galaxy S4 to provide full screen protection without additional bulk
Protect the front of your Samsung Galaxy S4 from scratches, scrapes and front-on impacts with the official flip cover. This cover clips onto the back of your device thanks to a flexible rubber bumper without adding any bulk, and then folds over the front when not in use. This means that the most important part of the phone, the screen, is protected from harm without the added thickness and weight normally associated with flip cases.
Durable construction offers premium protection for your screen Made from high quality synthetic materials, this flip cover will keep your Samsung Galaxy S4 screen looking good as new. The cover is tough enough to withstand day-to-day punishment without blemishing, so both your phone and cover will stay looking sharp for longer.
Official Samsung Accessory for Galaxy S4
This is an official Samsung product, so is made to the highest standards with the best quality materials. It is designed specifically for use with the Samsung Galaxy S4 so offers a perfect fit, and does not impede the use of any of the functions such as the power and volume buttons, headphone and charging ports, or front and rear cameras.
Features:
- Prevent damage to the screen by closing the flip-cover
- Keep your phone thin by simply replacing battery cover
- Chat even with cover closed thanks to speaker slot
- Express yourself with a range of attractive colours
- Enhanced protection for your Samsung Galaxy S4
- Samsung Flip Cover EF-FI950B - case for mobile phone
- Product Type
- Case for mobile phone
- 7.1 cm x 1.1 cm x 13.6 cm
- 29 g
- Light blue
- Designed For
- Galaxy S4
- 7.1 cm
- 1.1 cm
- 13.6 cm
- 29 g
- Light blue
Carrying Case
- Case
- Recommended Use
- For mobile phone
- Camera lens cutout, port cut-outs
- Designed For
- Samsung Galaxy S4
