The Samsung Fast Charge Portable Battery gives you additional charges to your smartphone. With Samsung Fast Charge, compatible devices can charge faster than standard USB charging options. You can charge your battery and phone at the same time with pass-through charging. Connect your phone to the portable battery, and then begin charging the battery. An LED power indicator shows just how much power is left in your portable battery.
- Samsung Fast Charge Portable Battery Pack EB-PG950 power bank - USB
- Product Type
- Power bank
- 7.42 cm x 1.38 cm x 13.23 cm
- 151.3 g
- Grey
- Output Connector Type
- USB - on cable: Micro-USB
- Voltage Required
- 5 - 9 V
- Voltage Provided
- 5 - 9 V
- Max Electric Current
- 2 A
- Fast Charge Technology
- Battery
- 5100 mAh
- Cables
- Micro-USB to USB cable - 20 cm , Micro-USB to USB-C adapter
- Designed For
- Galaxy A8 (2018) Enterprise Edition, Note8, S8, S8 Active, S8+
- Product Type
- Power bank
- 7.42 cm
- 1.38 cm
- 13.23 cm
- 151.3 g
- Enclosure Colour
- Grey
- Voltage Required
- 5 - 9 V
- Input Connectors
- 24 pin USB-C
- Input Connectors Qty
- 1
- Voltage Provided
- 5 - 9 V
- Output connectors
- 4 pin USB Type A
- Detachable Cable Connector Type
- Micro-USB Type B
- 2 A
- LED indicator
- Capacity
- 5100 mAh
- Cables Included
- Designed For
- Samsung Galaxy A8 (2018) Enterprise Edition, Note8, S8, S8 Active, S8+
