Product
Samsung Fast In/Out Battery Pack 5,100mAh - Blue
Quicklinx: CTW9WS00 Mfr#: EB-PG950CNEGWW
Stock Status: Clearance
Hurry, only 2 left in stock!
£30.44 ex VAT
£36.52 inc VAT
The Samsung Fast Charge Portable Battery gives you additional charges to your smartphone. With Samsung Fast Charge, compatible devices can charge faster than standard USB charging options. You can charge your battery and phone at the same time with pass-through charging. Connect your phone to the portable battery, and then begin charging the battery. An LED power indicator shows just how much power is left in your portable battery.
Samsung Fast Charge Portable Battery Pack EB-PG950 power bank
Power bank
7.42 cm x 1.38 cm x 13.23 cm
151.3 g
Navy
Output Connector Type
USB - on cable: Micro-USB
5 - 9 V
Voltage Provided
5 - 9 V
Fast Charge Technology
Samsung Fast Charge
- 5100 mAh
Cables
Micro-USB to USB cable - 20 cm , Micro-USB to USB-C adapter
Galaxy A8 (2018) Enterprise Edition, Note8, S8, S8 Active, S8+
Power bank
7.42 cm
1.38 cm
13.23 cm
151.3 g
Enclosure Colour
Navy
5 - 9 V
Input Connectors
24 pin USB-C
Input Connectors Qty
1
Voltage Provided
5 - 9 V
Output connectors
4 pin USB Type A
Detachable Cable Connector Type
Micro-USB Type B
Max Electric Current
2 A
Samsung Fast Charge
LED indicator
5100 mAh
Samsung Galaxy A8 (2018) Enterprise Edition, Note8, S8, S8 Active, S8+
Brand: Samsung
Price Range Ex VAT: 0 - 50
