Samsung F22T450FQU 24" 1920x1080 5ms HDMI DP LED Monitor
Quicklinx: GBJLWS00 Mfr#: LF22T450FQRXXU
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: HDMI, DisplayPort
£112.06 ex VAT
£134.47 inc VAT
Samsung F22T450FQR - T45F Series - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class D
Energy Consumption per Year
18 kWh
Power Consumption (On mode)
12 W
Adaptive-Sync Technology
AMD FreeSync
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Voltage
AC 120/230 V
48.88 cm x 21 cm x 32.53 cm
3.5 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
3-year warranty
Display Type
Energy Class
Class D
18 kWh
Diagonal Size
22"
AMD FreeSync
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Game mode, Mega Dynamic Contrast Ratio, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode, Off Timer Plus, 72% (NTSC 1976) colour gamut, Wide Viewing Angle, 3-sided bezeless
48.88 cm x 21 cm x 32.53 cm - with stand
3.5 kg
DisplayPort (DisplayPort 1.2 mode) , 2 x HDMI , Headphones , 2 x USB 2.0
Mechanical
Tilt Angle
-3/+25
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable
Input Voltage
AC 120/230 V
12 W
12 kWh/1000h
Power Consumption (Typical)
12 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 48.88 cm - depth: 21 cm - height: 32.53 cm - weight: 3.5 kg , Without stand - width: 48.88 cm - depth: 3.94 cm - height: 29.44 cm - weight: 2.2 kg
Shipping Width
55.3 cm
Shipping Depth
14.6 cm
Shipping Height
35.8 cm
Shipping Weight
4.7 kg
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years
10 °C
10 - 80% (non-condensing)
Diagonal Size: 22in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: DisplayPort
Brand: Samsung
