Product
Samsung EP-PG920I Wireless Charging Mat
Quicklinx: B8Y9WS00 Mfr#: EP-PG920IBEGWW
Unlike most conventional chargers, this Samsung Wireless Charging pad is both unique and beautiful in design. Its clear, glass-look details and glossy finish add a touch of sophistication, and allows it to fit in well with a variety of interior settings.
Charging your phone is easier than ever with the Samsung Wireless Charger. No need to connect a cable to your smartphone - simply place your mobile device on the charger pad and watch it charge, so easy.
Samsung Wireless Charger helps keeping that minimal clutter-free look easy. It looks great wherever you use it - the living room, the office or the bedroom.
  • Distinctive design
  • Effortless charging
  • Clutter-free convenience
  • Perfect match for your Galaxy S6
    Samsung Wireless Charger is a great fit with any compatible wireless charging handset The Galaxy S6 and Galaxy S6 Edge is even easier to charge, simply place it on the charger, without any need for additional accessories. Its ambient LED display indicates charging status, turning from a subtle blue to a vibrant green when the battery is full.
Samsung EP-PG920I - wireless charging mat
Wireless charging mat
1.68 cm
Diameter
9.7 cm
87.5 g
5 V
Voltage Provided
5 V
Galaxy Note5, S6, S6 Active, S6 edge, S6 edge+, S7, S7 edge
1.68 cm
Diameter
9.7 cm
87.5 g
Enclosure Colour
5 V
Input Connectors
5 pin Micro-USB Type B
Voltage Provided
5 V
Max Electric Current
1000 mA
LED indicator
WPC, Qi
Samsung Galaxy Note5, S6, S6 Active, S6 edge, S6 edge+, S7, S7 edge
