Product
Samsung ED75E 75" 1920 x 1080 VGA DVI HDMI LED Large Format Display
Quicklinx: BWY7WS00 Mfr#: LH75EDEPLGC/EN
TV Tuner Presence: No
Video Interface: Component, Composite, HDMI
  • 1080p (Full HD)
Hurry, only 1 left in stock!
£3,165.12 ex VAT
£3,798.14 inc VAT
Captivate your audience with stunning, full high-definition (FHD) images and crisp text on Samsung EDE Series displays. This affordable digital signage solution gives you the essential functionality you need to easily produce attention-grabbing messages. Their slim, lightweight design makes installation a snap compared with cumbersome conventional displays, saving you needless start-up expenses. The displays feature direct LED (d-LED) BLU technology for rich picture quality, low power consumption and reduced operating costs.
  • Captivate your audience with an immersive viewing experience
    Entice your audience with crisp, clear FHD images and realistic color on a sleek display with Samsung d-LED technology. A sleek, lightweight design and slim bezels keep your audience focus on your message, helping you capture more business opportunities. The accompanied pivot function gives you the flexibility to display your message vertically or horizontally for the optimal view.
  • Affordable startup cost and economical operation
    Enjoy all the essential functions of digital signage with affordably priced and energy-efficient Samsung EDE series. With the slim, light weight design, the displays are easy and economical to install, helping to reduce startup cost. Because EDE Series displays require less energy, emit less heat and are durable, they can also help lower your total cost of ownership (TCO).
Samsung ED75E ED-E Series - 75" LED display
LED-backlit LCD flat panel display
Diagonal Class
75"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
Energy Class
Class B
275 Watt
Power Consumption (On mode)
215 W
Energy Consumption per Year
314 kWh
167.62 cm x 8.84 cm x 95.95 cm
34.1 kg
Energy Class
Class B
275 Watt
215 W
314 kWh
Diagonal Class
75"
Commercial Use
Series
ED-E Series
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Design
Narrow Bezel Design
167.62 cm
8.84 cm
95.95 cm
34.1 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
LED backlight
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
5000:1
Brightness
400 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.2865 x 0.8595mm
Response Time
4 ms
Mega Dynamic Contrast Ratio
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
VGA input , DVI-D input , HDMI input , Audio line-in , Component video input , Composite video input , Audio line-out , Serial
Batteries
VGA cable
CSA, UL, TUV, VCCI, C-Tick, BSMI, GOST, BSMI CNS 13438 Class A, NEMKO, NOM, SASO, CB, CCC, PSB, FCC, IRAM, IEC 60950-1, EN 60950-1, FCC Part 15 B Class A, KC, GB 9254-2008, K60950-1, cUL No.60950-1, EAC, EN 55024-2:1998+A1:2001+A2:2003, GB4943.1-2011, RCM, EN55024:1998 + A1:2001 + A2:2003, IS13252, VCCI V-3/2010.04 Class A, CNS 14972, AS/NZS CISPR22:2009, GOST-R 51317 series, GOST 22505-97, EN55022:2006 + A1:2007, KN13, KN20, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, NOM-001-SCFI-1993, BIS, INMETRO
Power supply
Nominal Voltage
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0 Watt
Width (Shipping)
181 cm
Depth (Shipping)
25 cm
Height (Shipping)
108.5 cm
Weight (Shipping)
44.1 kg
10 - 80%
Video Interface: Composite
Video Interface: HDMI
Brand: Samsung
Price Range Ex VAT: 1500+
