Samsung ED65E 65" 1920x1080 VGA DVI HDMI LED Large Format Display
Quicklinx: BWY6WS00 Mfr#: LH65EDEPLGC/EN
TV Tuner Presence: No
Video Interface: Component, Composite, HDMI
  • 1080p (Full HD)
£4,482.11 ex VAT
£5,378.53 inc VAT
The Samsung ED65E Commercial Display is a simple, cost-effective and reliable digital signage solution for your business. It features side connectivity for flexible installation, with DVI, Component and Composite inputs. The large 65" LED screen offers high, full HD image quality, while the 3-year onsite warranty secures your investment and peace of mind.
  • Side connectivity opens possibilities for installations with less space
  • Enhanced connectivity with DVI, Component and Compostie inputs
  • Cost-effective display solution to meet business demands
  • 3-year onsite warranty with commercial grade reliability
  • Captivate your audience with an immersive viewing experience
    Entice your audience with crisp, clear FHD images and realistic color on a sleek display with Samsung d-LED technology. A sleek, lightweight design and slim bezels keep your audience focus on your message, helping you capture more business opportunities. The accompanied pivot function gives you the flexibility to display your message vertically or horizontally for the optimal view.
  • Affordable startup cost and economical operation
    Enjoy all the essential functions of digital signage with affordably priced and energy-efficient Samsung EDE series. With the slim, light weight design, the displays are easy and economical to install, helping to reduce startup cost. Because EDE Series displays require less energy, emit less heat and are durable, they can also help lower your total cost of ownership (TCO).
Samsung ED65E ED-E Series - 65" LED display
LED-backlit LCD flat panel display
Diagonal Class
65"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
Energy Class
Class B
253 Watt
Power Consumption (On mode)
180 W
Energy Consumption per Year
263 kWh
146.74 cm x 5.62 cm x 84.8 cm
27.4 kg
Energy Class
Class B
253 Watt
180 W
263 kWh
Diagonal Class
65"
Commercial Use
Series
ED-E Series
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Design
Narrow Bezel Design
Dimensions
Without stand
146.74 cm
5.62 cm
84.8 cm
27.4 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
LED backlight
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
4000:1
Brightness
400 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.744 x 0.744mm
Response Time
6 ms
Mega Dynamic Contrast Ratio, Optional Touch Overlay
Stands & Mounts
Stand
Optional
Stand Design
Floor standing
VESA Mounting Interface
400 x 400 mm
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Connector Type
VGA input , DVI-D input , Composite video input , Component video input , HDMI input , Audio line-in , Audio line-out , Serial input , Serial output
Batteries
VGA cable
CSA, UL, TUV, C-Tick, BSMI, GOST, NEMKO, SASO, CB, CCC, PSB, EK, IRAM, IEC 60950-1, EN 60950-1, KCC, FCC Part 15 B Class A, KC, GB 9254-2008, K60950-1, cUL No.60950-1, EAC, GB4943.1-2011, RCM, EN55024:1998 + A1:2001 + A2:2003, IS13252, EN 55022:2006+A1:2007, VCCI V-3/2010.04 Class A, CNS 14972, AS/NZS CISPR22:2009, GOST-R 51317 series, GOST 22505-97, KN13, KN20, CNS 13438 Class A ITE EMI, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, NOM-001-SCFI-1993, BIS, INMETRO
Power supply
Nominal Voltage
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Width (Shipping)
160 cm
Depth (Shipping)
28.7 cm
Height (Shipping)
98 cm
Weight (Shipping)
35.4 kg
10 - 80%
Video Interface: Composite
Video Interface: HDMI
Brand: Samsung
Price Range Ex VAT: 1500+
