Product
Brand
Samsung ED65D 65" 1920x1080 VGA DVI HDMI LED Large Format Display
Quicklinx: BKQ7WS00 Mfr#: LH65EDDPLGC/EN
  • 1080p (Full HD)
Samsung ED series displays provide viewers with an exciting experience applicable to various scenarios such near-full scale fashion display or clear and legible large-conference display.
Samsung ED65D ED-D Series - 65" Class (65" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
65"
Diagonal Size
65 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
TV Tuner
No tuner
Remote Control
Standard remote
Voltage
Energy Class
Class B
290 Watt
Power Consumption (On mode)
185 W
Energy Consumption per Year
270 kWh
146.75 cm x 6.5 cm x 84.8 cm
26.8 kg
Energy Class
Class B
290 Watt
185 W
270 kWh
Diagonal Class
65"
Diagonal Size
65 in
Commercial Use
Series
ED-D Series
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Dimensions
Without stand
146.75 cm
6.5 cm
84.8 cm
26.8 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
LED backlight
Multiple Display Control (MDC), LED BLU
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Remote Control
Standard remote
Connector Type
VGA input , DVI-D input , HDMI input , Audio line-in , Component video input , Composite video/audio input , Audio line-out , Serial input , Serial output
VGA cable
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0 Watt
On / Off Switch
10 - 80% (non-condensing)
