Product
Brand
Samsung ED55D 55" 1920x1080 DVI HDMI LED Large Format Display
Quicklinx: B25HWS00 Mfr#: LH55EDDPLGC/EN
  • 1080p (Full HD)
Samsung ED series displays provide viewers with an exciting experience applicable to various scenarios such near-full scale fashion display or clear and legible large-conference display.
Samsung ED55D ED-D Series - 55" Class (55" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
55"
Diagonal Size
55 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Interface
Component, composite, HDMI
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Remote Control
Standard remote
Voltage
Energy Class
Class B
165 Watt
Power Consumption (On mode)
140 W
Energy Consumption per Year
204 kWh
124.77 cm x 9.48 cm x 72.29 cm
18.3 kg
Energy Class
Class B
165 Watt
140 W
204 kWh
Diagonal Class
55"
Diagonal Size
55 in
Commercial Use
Series
ED-D Series
TV Tuner
No tuner
Video Interface
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Dimensions
Without stand
124.77 cm
9.48 cm
72.29 cm
18.3 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Colour Depth
16.7 million colours
Dynamic Contrast Ratio
5000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.21 x 0.63mm
Response Time
8 ms
Multiple Display Control (MDC), LED BLU
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Remote Control
Standard remote
Connector Type
VGA input , DVI-D input , HDMI input , Audio line-in , Component video input , Composite video/audio input , Audio line-out
VGA cable
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0 Watt
On / Off Switch
Width (Shipping)
138.1 cm
Depth (Shipping)
17 cm
Height (Shipping)
83.8 cm
Weight (Shipping)
23.4 kg
B25H Peerless-AV Universal Flat Wall Mount for 37" to 75" Displays In Stock £41.66
