Samsung ED series displays provide viewers with an exciting experience applicable to various scenarios such near-full scale fashion display or clear and legible large-conference display.
- Samsung ED46D ED-D Series - 46" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 46"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Component, composite, HDMI
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 121 Watt
- Power Consumption (On mode)
- 98 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 143 kWh
- Dimensions (WxDxH) - without stand
- 105.77 cm x 9.48 cm x 61.58 cm
- 11.9 kg
- Product Type
- Energy Class
- Class B
- 121 Watt
- 98 W
- 143 kWh
- Diagonal Class
- 46"
- Commercial Use
- Series
- ED-D Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Dimensions
- Without stand
- 105.77 cm
- 9.48 cm
- 61.58 cm
- 11.9 kg
- Enclosure Colour
- Black
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Colour Depth
- Up to 1.07 billion colours
- Dynamic Contrast Ratio
- 5000:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.17675 x 0.53025mm
- Response Time
- 8 ms
- Multiple Display Control (MDC), LED BLU
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 400 x 400 mm
Remote Control
- Remote control
- Connector Type
- VGA input , DVI-D input , HDMI input , Audio line-in , Component video input , Composite video/audio input , Audio line-out
- Cables Included
- VGA cable
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0 Watt
- On / Off Switch
- Width (Shipping)
- 115.4 cm
- Depth (Shipping)
- 16.5 cm
- Height (Shipping)
- 72.3 cm
- Weight (Shipping)
- 14.6 kg
