Captivate your audience with stunning, high-definition (HD) images and crisp text on Samsung EDD large format display (LFD) Series. This digital signage solution gives you the essentials you need to easily produce attention-getting messages in one affordable display. Their slim, lightweight design makes installation a snap compared with cumbersome conventional displays, saving you needless start-up expenses. The displays feature direct LED (d-LED) BLU technology for rich picture quality, low power consumption and reduced operating costs.
Captivate your audience with an immersive viewing experience. Entice your audience with crisp, clear HD images and realistic color on a sleek display with Samsung d-LED technology. A sleek, lightweight design and slim bezels keep your audience focus on your message, helping you capture more business opportunities. The accompanied pivot function gives you the flexibility to display your message vertically or horizontally for the optimal view.
Direct-lit LED backlight
Direct-lit LED technology delivers sharp, high-resolution images, along with the uniform brightness typical of traditional CCFL-backlit displays. It also uses less energy, with savings of up to 50% over CCFL. And it does it all with a cost comparable to CCFL. -
More connectivity options
Having flexible content options is important. That's why the ED-D Series delivers a multitude of connectivity choices. -
Commercial reliability
While the ED-D Series displays are affordable, they're also every bit as reliable as Samsung's most expensive display panels. -
High resolution
Samsung ED-D Series displays are bright, vivid and sharp. They feature 1366 x 768 HD resolution, for crisp motion graphics and easily readable text.
- Samsung ED32D ED-D Series - 32" LED-backlit LCD display - HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 32"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1366 x 768
- Display Format
- 720p
- Video Interface
- Component, composite, HDMI
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 77 Watt
- Power Consumption (On mode)
- 48 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 70 kWh
- Dimensions (WxDxH) - without stand
- 73.6 cm x 9.37 cm x 43.45 cm
- 6 kg
- Product Type
- Energy Class
- Class B
- 77 Watt
- 48 W
- 70 kWh
- Diagonal Class
- 32"
- Commercial Use
- Series
- ED-D Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Dimensions
- Without stand
- 73.6 cm
- 9.37 cm
- 43.45 cm
- 6 kg
- Enclosure Colour
- Black
Display
- Resolution
- 1366 x 768
- Display Format
- 720p
- 16:9
- LED backlight
- Colour Depth
- 16.7 million colours
- Dynamic Contrast Ratio
- 4000:1
- Brightness
- 330 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.17025 x 0.51075mm
- Response Time
- 8 ms
- Multiple Display Control (MDC), LED BLU
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 200 x 200 mm
Remote Control
- Remote control
- Connector Type
- VGA input , DVI-D input , HDMI input , Audio line-in , Component video input , Composite video/audio input , Audio line-out
- Cables Included
- VGA cable
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0 Watt
- On / Off Switch
- Width (Shipping)
- 82.6 cm
- Depth (Shipping)
- 16.2 cm
- Height (Shipping)
- 53 cm
- Weight (Shipping)
- 7.6 kg
