The Galaxy S4 standard battery is a high-quality battery that has been designed specifically to deliver the most reliable and long-lasting power for your Samsung Galaxy S4. This battery is equipped with an NFC antenna, allowing your handset to communicate with other devices and accessories that are equipped with NFC technology.
This battery, exclusively for Samsung Smartphones, offers longer battery life, is reliable and safe, having gone through an exhausting testing and certification process. For long travels or extended use, have the peace of mind of an extra Samsung battery on hand when you need it.
Additional power when you need it
The Lithium-Ion battery, exclusively for Samsung smartphones, offers longer battery life, is reliable and safe, having gone through an exhausting testing and certification process. For long travels or extended use, have the peace of mind of an extra Samsung battery on hand when you need it.
- Samsung EB-B600BEB battery - Li-Ion
- Product Type
- Battery
- 5.7 cm x 5.3 cm x 6.3 cm
- 43.9 g
- Battery
- Lithium Ion - 2600 mAh - standard
- Designed For
- Galaxy S4
- Product Type
- Battery
- Designed For
- Mobile phone
- 5.7 cm
- 5.3 cm
- 6.3 cm
- 43.9 g
- Standard
- Technology
- Lithium Ion
- Voltage Provided
- 3.8 V
- Capacity
- 2600 mAh
- NFC aerial
- Designed For
- Samsung Galaxy S4
