Samsung DM82E-BR 82" 1920x1080 VGA DVI HDMI DisplayPort WiFi LED Large Format Display
Quicklinx: BKPLWS00 Mfr#: LH82DMERTBC/EN
  • 1080p
header
Introducing Samsung's NEW 82" eBoard solution.
Unleash the potential of your presentations.
A Smoother, More Interactive Writing Experience Using Touch
writing
Featuring a pre-assembled Touch Overlay and a variety of collabouration-enhancing capabilities, the Samsung e-Board display alleviates misconceptions that digital display writing is complex and unnatural. Instead, the DME-BR’s touchscreen offers a smooth and comfortable writing experience. The DME-BR display’s hand touch function enables up to 10 different participants to touch the display’s screen using two fingers to make content selections, comments or edits, with those individual actions easily recognisable to the entire group. This versatile usability promotes efficiency and productivity by compiling individual feedback within a single source and offering greater visibility to all participants of discussed content.
For added convenience, the Samsung e-Board display also comes with a hand eraser tool useful for erasing larger areas of the screen. Instead of users having to search for and work through a specific removal function key, the simple and intuitive hand eraser makes content revision fast and user-friendly.
A More Engaging, Interactive Content Management Experience
interactive
The Samsung SMART Signage e-Board display’s embedded Magic WB S2* interactive content management software solution transforms a traditional presentation into a dynamic business or educational experience. As an all-in-one touch solution, Samsung’s free Magic WB S2 programme delivers added flexibility for extensive collabouration before, during and after meetings or classes without requiring the use of separate dedicated PCs or additional devices. A touch-activated floating menu enables users to independently control, display and shuffle between multiple screens and various text, image, audio and video content files. Once sessions conclude, Magic WB S2’s compatibility with standard office software programs lets users update, save, capture, print and share files for later viewing. With the support of the Magic WB S2 solution, the Samsung e-Board display enhances the overall knowledge-sharing process through deeper engagement and all-inclusive file management.
*Note: Samsung’s Magic WB S2 software, an advanced version of Magic WB, is available for e-Board display users, but requires a separate PC for operation.
Versatile Usability with Extensive Connectivity and Easy-to-Use Touch Capability
versatile
Today’s business and educational environments require advanced compatibility for users to easily read and share content. Through its enhanced and versatile connectivity, Samsung’s e-Board display allows users to access, share and revise content via their own laptops, tablets and smartphones. This superior connectivity stems from the display being equipped to support a range of signal input sources, including HDMI, D-Sub, DisplayPort (DP), DVI and USB ports, which are compatible with nearly all external devices.
Furthermore, the Samsung e-Board display’s auto switching for the touch function eliminates the headache of needing two different cables to use touch with a notebook PC. Instead, the display features an easily assessable touch out cable (USB upstream) on the side of the front pen tray. Users just need to plug the single touch cable into the USB, connect the cable to the notebook PC and setup source. Together, these integrated solutions simplify multi-device setup and connectivity, as well as ensure convenient utilisation of the display’s advanced touch capability.
An Intuitive Design that Promotes Efficiency and Usability
intuitive
The Samsung SMART Signage e-Board display’s pre-assembled design allows users to comfortably install, control and work with the all-in-one e-Board solution. As part of its professional-grade design, the Samsung e-Board display incorporates a front pen tray for convenient storage and easy access to display components. With a design format resembling that of an analog white board, the Samsung e-Board helps ensure user familiarly and seamless technology adoption, while also bringing design sophistication and advanced functionality to business and educational environments. Additionally, the display’s design positions simplified hot keys on the front and side of the pen tray. The shortcut hot keys allow users to easily locate and select frequently-used functions, including touch on/off, quick menu, power on/off, touch out USB and HDMI, with the simple push of a button.
With the Samsung SMART Signage e-Board, business professionals and educators can economically utilise space while delivering the functionality essential for effective collabouration and productivity.
  • A smoother, more interactive writing experience using touch
    Featuring a pre-assembled Touch Overlay and a variety of collaboration-enhancing capabilities, the Samsung e-Board display alleviates misconceptions that digital display writing is complex and unnatural. Instead, the DME-BR's touchscreen offers a smooth and comfortable writing experience. The DME-BR display's hand touch function enables up to 10 different participants to touch the display's screen using two fingers to make content selections, comments or edits, with those individual actions easily recognisable to the entire group. This versatile usability promotes efficiency and productivity by compiling individual feedback within a single source and offering greater visibility to all participants of discussed content. For added convenience, the Samsung e-Board display also comes with a hand eraser tool useful for erasing larger areas of the screen. Instead of users having to search for and work through a specific removal function key, the simple and intuitive hand eraser makes content revision fast and user-friendly.
  • A more engaging, interactive content management experience
    The Samsung SMART Signage e-Board display's embedded Magic WB S2 interactive content management software solution transforms a traditional presentation into a dynamic business or educational experience. As an all-in-one touch solution, Samsung's free Magic WB S2 program delivers added flexibility for extensive collaboration before, during and after meetings or classes without requiring the use of separate dedicated PCs or additional devices. A touch-activated floating menu enables users to independently control, display and shuffle between multiple screens and various text, image, audio and video content files. Once sessions conclude, Magic WB S2's compatibility with standard office software programs lets users update, save, capture, print and share files for later viewing. With the support of the Magic WB S2 solution, the Samsung e-Board display enhances the overall knowledge-sharing process through deeper engagement and all-inclusive file management.
  • Versatile usability with extensive connectivity and easy-to-use touch capability
    Today's business and educational environments require advanced compatibility for users to easily read and share content. Through its enhanced and versatile connectivity, Samsung's e-Board display allows users to access, share and revise content via their own laptops, tablets and smartphones. This superior connectivity stems from the display being equipped to support a range of signal input sources, including HDMI, D-Sub, DisplayPort (DP), DVI and USB ports, which are compatible with nearly all external devices. Furthermore, the Samsung e-Board display's auto switching for the touch function eliminates the headache of needing two different cables to use touch with a notebook PC. Instead, the display features an easily assessable touch out cable (USB upstream) on the side of the front pen tray. Users just need to plug the single touch cable into the USB, connect the cable to the notebook PC and setup source. Together, these integrated solutions simplify multi-device setup and connectivity, as well as ensure convenient utilization of the display's advanced touch capability.
  • An intuitive design that promotes efficiency and usability
    The Samsung SMART Signage e-Board display's pre-assembled design allows users to comfortably install, control and work with the all-in-one e-Board solution. As part of its professional-grade design, the Samsung e-Board display incorporates a front pen tray for convenient storage and easy access to display components. With a design format resembling that of an analog white board, the Samsung e-Board helps ensure user familiarly and seamless technology adoption, while also bringing design sophistication and advanced functionality to business and educational environments. Additionally, the display's design positions simplified hot keys on the front and side of the pen tray. The shortcut hot keys allow users to easily locate and select frequently-used functions, including touch on/off, quick menu, power on/off, touch out USB and HDMI, with the simple push of a button. With the Samsung SMART Signage e-Board, business professionals and educators can economically utilize space while delivering the functionality essential for effective collaboration and productivity.
Samsung DM82E-BR 82" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
82"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Frame Rate & Enhancement Technology
120Hz Refresh Rate
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
Wi-Fi
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, Image Rotation, Magic Clone, Auto Source Switching & Recovery
Speaker System
2 speakers
Supported Memory Cards
SD Memory Card
USB
Remote control, batteries
Voltage
Energy Class
Class B
495 Watt
Power Consumption (On mode)
323 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
472 kWh
191.18 cm x 14 cm x 112.17 cm
78.2 kg
Energy Class
Class B
495 Watt
323 W
472 kWh
Diagonal Class
82"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
HDMI Ports Qty
3 ports
PC Interface
HDCP Compatible
Dimensions
Without stand
191.18 cm
14 cm
112.17 cm
78.2 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
120Hz Refresh Rate
LED backlight
Coating
Super Clear
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
5000:1
Dynamic Contrast Ratio
50000:1
Brightness
430 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.3135 x 0.9405 mm
Response Time
8 ms
Commercial Features
Multiple Display Control (MDC), digital daisy chain, Smart Scheduling, e-LED BLU, MagicInfo Player-S3
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
600 x 400 mm
Media Player
SD Memory Card
USB Port
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
Wi-Fi
Connector Type
Audio line-out , Audio line-in , USB , DVI-D input , DisplayPort input , 2 x HDMI input - rear , VGA input , HDMI input - front , Composite video / component video / audio input - front
Batteries
VGA cable , Serial adapter
Plug and Play, CSA, UL, TUV, VCCI, C-Tick, BSMI, GOST, cUL, NEMKO, NOM, SASO, CB, AS/NZS 60950-1, CCC, PSB, EK, IRAM, EN 60950-1, KCC, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, cUL No.60950-1, EAC, RCM, IS13252, VCCI V-3/2010.04 Class A, CNS 14972, GOST 22505-97, KN13, KN20, CNS 13438 Class A ITE EMI, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, GOST-R 51317, NOM-001-SCFI-1993, BIS, INMETRO, IEC60950-1, GB 4943.1-2011, AS/NZS CISPR 22:2009, EN 55024:1998+A1:2001+A2:2003, EN 55022:2006+A1:2007
Power supply
Input Voltage
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
206.9 cm
Depth (Shipping)
51.3 cm
Height (Shipping)
128 cm
Weight (Shipping)
94.6 kg
10 - 80%
