Samsung DM82D 82" 1920x1080 VGA DVI HDMI DisplayPort SOC LED Large Format Display
Quicklinx: B4TPWS00 Mfr#: LH82DMDPLGC/EN
  • 1080p
Samsung's DM82D delivers 24/7 reliability on a large 82" screen for continuous operation. Display content without an external PC thanks to an upgraded Samsung SMART Signage Platform (SSP) and full range of connectivity options. All combined with a sleek industrial design and slim 1.9" chassis depth.
  • Reliable 24/7 continuous operation
    Innovative Samsung cooling technologies allow your message to be displayed with highly reliable 24/7 continuous operation. So business users can meet 24/7 operating requirements in venues ranging from retail stores to Command & Control facilities.
  • Enhanced SSP with quad core processor
    Experience enhanced System-on-Chip (SoC) performance with a quad core processor. SMART Signage Platform (SSP) is an integrated, open platform providing a powerful streamlined solution to reduce TCO in digital signage deployments through savings in hardware installation and operating costs.
  • Sleek industrial design
    Edge-Lit LED technology delivers a sleek industrial design with a 1.9" chassis depth for an elegant look. LED can also slim your TCO thanks to energy efficiency.
  • PC-less touch support
    The optional touch overlay accessory delivers a cost effective, PC-less touch solution that transforms your display into an interactive whiteboard. Create more collaborative presentations or a dynamic customer experience with tangible results for your business.
  • Full connectivity
    Discover versatile connectivity options to display a full range of exceptional content that speaks to your audience. Connections include D-Sub, Component, Composite, HDMI, DVI, USB, SD, RS232C/RJ45 and more.
  • Built-in Wi-Fi
    Expanding your versatility even more, you can enjoy easy media sharing and screen control with built-in Wi-Fi and AllShare Cast. Use AllShare Cast over a Wi-Fi connection for simple content mirroring from a tablet or mobile phone to your display.
  • Clean UI design
    A user-friendly interface provides an intuitive user experience from changing display settings to installing video walls and managing content schedules and templates. Helping to streamline installation and maintenance, users can effectively coordinate their signage.
Samsung DM82D DM-D Series - 82" Class (81.5" viewable) LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
82"
Diagonal Size
81.5"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Frame Rate & Enhancement Technology
120Hz Refresh Rate
Max Number of Screens
225
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
Wi-Fi, LAN
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, SMART Signage Platform, Image Rotation, Magic Clone, Auto Source Switching & Recovery, SMART Signage Platform 2nd Generation
Speaker System
2 speakers
Storage Drive Capacity
4 GB
Storage Capacity
4 GB
Supported Memory Cards
SD Memory Card
USB
2 ports
Remote control, batteries
Voltage
363 Watt
Power Consumption Stand by
0.5 Watt
185.42 cm x 4.85 cm x 106.42 cm
50 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
363 Watt
Diagonal Class
82"
Diagonal Size
81.5"
Commercial Use
Series
DM-D Series
Video Processor
Quad-Core
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
HDMI Ports Qty
3 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode
Dimensions
Without stand
185.42 cm
4.85 cm
106.42 cm
50 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
120Hz Refresh Rate
LED backlight
Coating
Super Clear
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
5000:1
Dynamic Contrast Ratio
50000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.3135 x 0.9405 mm
Response Time
8 ms
Commercial Features
Pivot, Multiple Display Control (MDC), Certified for 24/7 Continuous Operation, digital daisy chain, Smart Scheduling, e-LED BLU, MagicInfo Player-S2
Video Wall
225
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
600 x 400 mm
Media Player
Supported Video Formats
MPEG-1, MPEG-2, AVC, H.264, VC-1
Supported Audio Formats
AC3, DTS
Supported Pictures Formats
JPG, PNG
SD Memory Card
USB Port
USB Ports Qty
2
Configuration
ARM Cortex-A9 ( 1 GHz ) - 1.5 GB DDR3 - 4 GB
4 GB
Operating System
Linux
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
Wi-Fi, LAN
Connector Type
Serial input , Serial output , Remote control/ambient sensor input , Audio line-out , Audio line-in , 2 x USB , DVI-D input , DisplayPort input , 3 x HDMI input , VGA input , DisplayPort output , Composite video / component video / audio input , Remote control output , Multiple Display Control
Batteries
VGA cable
Plug and Play, CSA, UL, TUV, VCCI, C-Tick, BSMI, GOST, cUL, NEMKO, NOM, SASO, CB, AS/NZS 60950-1, CCC, PSB, EK, IRAM, EN 60950-1, KCC, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, cUL No.60950-1, EAC, RCM, IS13252, VCCI V-3/2010.04 Class A, CNS 14972, GOST 22505-97, KN13, KN20, CNS 13438 Class A ITE EMI, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, GOST-R 51317, NOM-001-SCFI-1993, BIS, INMETRO, IEC60950-1, GB 4943.1-2011, AS/NZS CISPR 22:2009, EN 55024:1998+A1:2001+A2:2003, EN 55022:2006+A1:2007
Sustainability Information
ENERGY STAR Certified
Power supply
Input Voltage
0.5 Watt
Power Consumption Sleep
0.5 Watt
Limited warranty - 3 years
Width (Shipping)
200.2 cm
Depth (Shipping)
46.2 cm
Height (Shipping)
123.8 cm
Weight (Shipping)
65 kg
10 - 80% (non-condensing)
