Product
Samsung DM65E 65" 1920x1080 VGA DVI HDMI DisplayPort WiFi LED Large Format Display
Quicklinx: BKQ5WS00 Mfr#: LH65DMEPLGC/EN
  • 1080p (Full HD)
Samsung DME series SMART Signage provides powerful 24/7 performance and high-quality, clear images in a sleek and professional design with competitive cost. Businesses and retail establishments can connect the displays in various configurations with expanded connectivity options. Plus, when it comes to installation, usage and maintenance, the displays offer myriad connection options, straightforward control and economical usage.
  • Dependable for continuous commercial operation
    Meet a wide range of business uses 24hours/7days through an advanced, professional-grade display.
  • Rich content delivery through a Quad Core processor
    Easily manage a vast range of dynamic content with various content display features, enhanced 8GB memory storage and 3rd Generation Samsung SMART Signage Platform (SSSP) featuring a built-in media player and expanded connectivity.
  • Streamline content management
    Gain advanced content manageability while reducing Total Cost of Ownership (TCO) through MagicInfo S3.
  • Easy and efficient display configuration
    Conveniently and economically operate and maintain multiple displays with Daisy Chain configuration, Magic Clone and Auto Source Switching
Samsung DM65E DME Series - 65" LED display
LED-backlit LCD flat panel display
Diagonal Class
65"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Motion Enhancement Technology
60 Hz Refresh Rate
Video Wall Components Qty
225
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
Wi-Fi
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, Image Rotation, Magic Clone, Auto Source Switching & Recovery
Settings Cloning Capability
Speaker System
2 speakers
Supported Memory Cards
SD Memory Card
Remote Control
Standard remote
Voltage
Energy Class
Class B
Power Consumption (On mode)
200 W
Energy Consumption per Year
292 kWh
146.74 cm x 5.59 cm x 84.8 cm
27.4 kg
Energy Class
Class B
200 W
292 kWh
Diagonal Class
65"
Commercial Use
Series
DME Series
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
225
Dimensions
Without stand
146.74 cm
5.59 cm
84.8 cm
27.4 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
LED backlight
Coating
Super Clear
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
4000:1
Dynamic Contrast Ratio
50000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.248 x 0.744mm
Response Time
6.5 ms
Commercial Features
Pivot, Multiple Display Control (MDC), digital daisy chain, MagicInfo, LED BLU, MagicInfo Player-S3
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Media Player
SD Memory Card
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Built-in speaker
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
Wi-Fi
Connector Type
VGA input , DVI-D input , 2 x HDMI input , Audio line-in , Composite video / component video input , Audio line-out , DisplayPort input , Serial , DisplayPort output , Audio line-in
VGA cable , Serial adapter
Plug and Play, CSA, UL, C-Tick, BSMI, BSMI CNS 13438 Class A, cUL, NEMKO, SASO, CCC, PSB, IRAM, IEC 60950-1, EN 60950-1, KCC, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, cUL No.60950-1, EAC, RCM, EN55024:1998 + A1:2001 + A2:2003, GB 4943-2011, EN 55022:2006+A1:2007, VCCI V-3/2010.04 Class A, CNS 14972, AS/NZS CISPR22:2009, GOST-R 51317 series, GOST 22505-97, KN13, KN20, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, NOM-001-SCFI-1993, BIS, INMETRO
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
160 cm
Depth (Shipping)
21.7 cm
Height (Shipping)
98 cm
Weight (Shipping)
35.4 kg
10 - 80%
