Enhance your brand image and messaging with Samsung DME Series SMART Signage professional-grade displays. With vivid picture quality, high-brightness screens (450 nit) and exceptional 24/7 durability, DME displays offer the functionality you need to promote your business.
Powered by the enhanced 3rd Generation Samsung SMART Signage Platform (SSSP), DME Series displays deliver rich content without an additional PC or media player. Samsung's MagicInfo Player S3 is also equipped with a range of intuitive features, such as decorative icons, drag and drop functionality and various fonts, and with Samsung's convenient mobile app, you can manage your digital signage from virtually anywhere through a smart phone or tablet.
Conveniently and simply manage a rich array of content with an advanced platform
3rd Generation Samsung SMART Signage Platform (SSSP) features a media player embedded inside the display as a powerful Quad Core System on Chip (SoC). 3rd Generation SSSP integrated hardware and software solution streamlines digital signage configuration and management by eliminating the need for an additional PC unit. And, the internal memory enhancement from 4 GB to 8 GB provides robust performance. -
Easily manage digital signage with a simplified Home UI
Heighten efficiency and productivity with a newly designed Home Menu UI that displays frequently used functions in a new, large-button matrix design. Simplify usage with a selection of customizable menu configurations that allow ready access to repeatedly used menus. Generate content more easily and conveniently than ever with the Home Menu's newly designed templates for various vertical markets including grocery stores, QSRs, terminals and lobbies. Leverage these sharp, professional template layouts to produce and design content in either portrait or landscape orientation. -
Transform your business messaging with a brilliant, yet simple content creator featuring free fonts, convenient stickers, dynamic effects and a weather widget
Boost revenues with professionally polished display content generated with a content management solution, MagicInfo S3, embedded within the 3rd generation SSSP. Along with widgets and stickers, the solution provides 6 different types of free fonts in 23 styles. MagicInfo S3 eliminates single-font formatting limitations with the upgraded ability to select from various free fonts or add your own. Use handy stamps and either preset or self-created, text-editable stickers to update your promotional information and price tags for convenient and straightforward content changes. Create eye-catching transitions with Dynamic Effect, a feature that enables slideshow-type effects, such as fade, fly-on and zoom. Plus, you can leverage a drag-and-drop widget solution to simply add widgets such as AccuWeather that displays daily and weekly weather for the ultimate in professional content presentation. -
Engage viewers with an attractive design that is optimized for the environment
Enhance any display environment with a chic and streamlined design and captivating appearance. For convenient and efficient mechanical compatibility, DME Series displays maintain the same stunning design as previous Samsung D-Series SMART Signage. To elevate your décor, the displays feature slim and elegant black hairline deco-bezels or white color deco-bezels. A flexible, tag-type spacer with a logo is designed for either portrait or landscape installations to create a polished, professional look in any space.
- Samsung DM48E DME Series - 48" Class (47.6" viewable) LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 48"
- Diagonal Size
- 47.6"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Frame Rate & Enhancement Technology
- 60 Hz Refresh Rate
- Max Number of Screens
- 225
- Video Interface
- Component, HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- Wi-Fi
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Button lock, SMART Signage Platform, Image Rotation, Magic Clone, Auto Source Switching & Recovery
- Settings Cloning Capability
- Speaker System
- 2 speakers
- DVR
- Flash - 8 GB
- Storage Drive Capacity
- 8 GB
- Storage Capacity
- 8 GB
- Supported Memory Cards
- SD Memory Card
- USB
- Included Accessories
- Remote control, batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 132 Watt
- Power Consumption (On mode)
- 94 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 137 kWh
- Dimensions (WxDxH) - without stand
- 107.51 cm x 4.99 cm x 61.94 cm
- 11.1 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- Energy Class
- Class B
- 132 Watt
- 94 W
- 137 kWh
- Diagonal Class
- 48"
- Diagonal Size
- 47.6"
- Commercial Use
- Series
- DME Series
- Video Processor
- Quad-Core
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- Component, HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- HDCP Compatible
- Dimensions
- Without stand
- 107.51 cm
- 4.99 cm
- 61.94 cm
- 11.1 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- Super Clear
- Colour Depth
- Up to 1.07 billion colours
- Image Contrast Ratio
- 5000:1
- Dynamic Contrast Ratio
- 50000:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.183 x 0.549mm
- Response Time
- 8 ms
- Pivot, Multiple Display Control (MDC), Certified for 24/7 Continuous Operation, digital daisy chain, MagicInfo, d-LED BLU, MagicInfo Player-S3
Video Wall
- 225
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 400 x 400 mm
DVR
- DVR
- Flash - 8 GB
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, AVC, H.264, VC-1
- Supported Audio Formats
- AC3, DTS
- Supported Pictures Formats
- PNG, JPEG
- SD Memory Card
- USB Port
- USB Ports Qty
- 1
- Configuration
- ARM Cortex-A9 ( 1 GHz ) - 1.5 GB DDR3 - 8 GB
- 8 GB
- Operating System
- Linux
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- Wi-Fi
- Connector Type
- Serial input , Serial output , Remote control/ambient sensor input - rear , Audio line-out - rear , Audio line-in - rear , USB 2.0 - rear , DVI-D input - rear , DisplayPort input - rear , 2 x HDMI input - rear , VGA input - rear , DisplayPort output - rear , Component video input - rear , Remote control output - rear , Multiple Display Control - rear
- Batteries
- Cables Included
- VGA cable , Serial adapter
- Plug and Play, CSA, UL, TUV, VCCI, C-Tick, BSMI, GOST, cUL, NEMKO, NOM, SASO, CB, AS/NZS 60950-1, CCC, PSB, EK, IRAM, IEC 60950-1, EN 60950-1, KCC, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, EAC, RCM, IS13252, GB 4943-2011, VCCI V-3/2010.04 Class A, CNS 14972, GOST-R 51317 series, GOST 22505-97, KN13, KN20, CNS 13438 Class A ITE EMI, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, BIS, INMETRO, AS/NZS CISPR 22:2009, EN 55024:1998+A1:2001+A2:2003, EN 55022:2006+A1:2007
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- On / Off Switch
- Width (Shipping)
- 118.5 cm
- Depth (Shipping)
- 14.8 cm
- Height (Shipping)
- 71.5 cm
- Weight (Shipping)
- 14 kg
- 0 °C
- 40 °C
- 10 - 80%
