Product
Samsung DM40E 40" 1920x1080 VGA DVI HDMI DisplayPort WiFi LED Large Format Display
Quicklinx: BKPZWS00 Mfr#: LH40DMEPLGC/EN
  • 1080p (Full HD)
Enhance your brand image and messaging with Samsung DME Series SMART Signage professional-grade displays. With vivid picture quality, high-brightness screens (450 nit) and exceptional 24/7 durability, DME displays offer the functionality you need to promote your business.
Powered by the enhanced 3rd Generation Samsung SMART Signage Platform (SSSP), DME Series displays deliver rich content without an additional PC or media player. Samsung's MagicInfo Player S3 is also equipped with a range of intuitive features, such as decorative icons, drag and drop functionality and various fonts, and with Samsung's convenient mobile app, you can manage your digital signage from virtually anywhere through a smart phone or tablet.
  • Conveniently and simply manage a rich array of content with an advanced platform
    3rd Generation Samsung SMART Signage Platform (SSSP) features a media player embedded inside the display as a powerful Quad Core System on Chip (SoC). 3rd Generation SSSP integrated hardware and software solution streamlines digital signage configuration and management by eliminating the need for an additional PC unit. And, the internal memory enhancement from 4 GB to 8 GB provides robust performance.
  • Easily manage digital signage with a simplified Home UI
    Heighten efficiency and productivity with a newly designed Home Menu UI that displays frequently used functions in a new, large-button matrix design. Simplify usage with a selection of customizable menu configurations that allow ready access to repeatedly used menus. Generate content more easily and conveniently than ever with the Home Menu's newly designed templates for various vertical markets including grocery stores, QSRs, terminals and lobbies. Leverage these sharp, professional template layouts to produce and design content in either portrait or landscape orientation.
  • Transform your business messaging with a brilliant, yet simple content creator featuring free fonts, convenient stickers, dynamic effects and a weather widget
    Boost revenues with professionally polished display content generated with a content management solution, MagicInfo S3, embedded within the 3rd generation SSSP. Along with widgets and stickers, the solution provides 6 different types of free fonts in 23 styles. MagicInfo S3 eliminates single-font formatting limitations with the upgraded ability to select from various free fonts or add your own. Use handy stamps and either preset or self-created, text-editable stickers to update your promotional information and price tags for convenient and straightforward content changes. Create eye-catching transitions with Dynamic Effect, a feature that enables slideshow-type effects, such as fade, fly-on and zoom. Plus, you can leverage a drag-and-drop widget solution to simply add widgets such as AccuWeather that displays daily and weekly weather for the ultimate in professional content presentation.
  • Engage viewers with an attractive design that is optimized for the environment
    Enhance any display environment with a chic and streamlined design and captivating appearance. For convenient and efficient mechanical compatibility, DME Series displays maintain the same stunning design as previous Samsung D-Series SMART Signage. To elevate your décor, the displays feature slim and elegant black hairline deco-bezels or white color deco-bezels. A flexible, tag-type spacer with a logo is designed for either portrait or landscape installations to create a polished, professional look in any space.
Samsung DM40E DME Series - 40" LED display
LED-backlit LCD flat panel display
Diagonal Class
40"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Wall Components Qty
225
Video Interface
Component, HDMI
HDMI Ports Qty
2 ports
Wi-Fi
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, Image Rotation, Magic Clone, Auto Source Switching & Recovery
Settings Cloning Capability
Speaker System
2 speakers
Supported Memory Cards
SD Memory Card
Remote Control
Standard remote
Voltage
Energy Class
Class B
121 Watt
Power Consumption (On mode)
81 W
Energy Consumption per Year
118 kWh
90.66 cm x 4.99 cm x 52.47 cm
7.52 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class B
121 Watt
81 W
118 kWh
Diagonal Class
40"
Commercial Use
Series
DME Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
Component, HDMI
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
225
Dimensions
Without stand
90.66 cm
4.99 cm
52.47 cm
7.52 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
Super Clear
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
5000:1
Dynamic Contrast Ratio
50000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.15375 x 0.46125mm
Response Time
8 ms
Commercial Features
Pivot, Multiple Display Control (MDC), digital daisy chain, MagicInfo, LED BLU, MagicInfo Player-S3
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
Media Player
SD Memory Card
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Built-in speaker
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
Wi-Fi
Connector Type
VGA input , DVI-D input , 2 x HDMI input , Audio line-in , Component video input , Audio line-out , DisplayPort input , Serial , DisplayPort output
VGA cable , Serial adapter
Plug and Play, CSA, UL, C-Tick, BSMI, BSMI CNS 13438 Class A, cUL, NEMKO, SASO, CCC, PSB, IRAM, IEC 60950-1, EN 60950-1, KCC, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, cUL No.60950-1, EAC, RCM, EN55024:1998 + A1:2001 + A2:2003, GB 4943-2011, EN 55022:2006+A1:2007, VCCI V-3/2010.04 Class A, CNS 14972, AS/NZS CISPR22:2009, GOST-R 51317 series, GOST 22505-97, KN13, KN20, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, NOM-001-SCFI-1993, BIS, INMETRO
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
101.2 cm
Depth (Shipping)
13.8 cm
Height (Shipping)
60.5 cm
Weight (Shipping)
9.1 kg
10 - 80%
