Samsung DH55E 55" 1920x1080 VGA DVI HDMI DisplayPort WiFi LED Large Format Display
Installation required? Contact us today!
Quicklinx: BKPFWS00 Mfr#: LH55DHEPLGC/EN
  • 1080p (Full HD)
The innovative and stylish DHE Series SMART Signage displays feature superb ultra-bright luminosity, consistent durability and performance, and a range of picture quality settings that can be optimized to suit virtually any environment. Powered by the enhanced Samsung SMART Signage Platform (SSSP), DHE Series displays deliver rich content without an additional PC or media player. Samsung's MagicInfo Player S3 is also equipped with a range of intuitive features, such as decorative icons, drag and drop functionality and various fonts, and with Samsung's convenient mobile app, you can manage your digital signage from virtually anywhere through a smart phone or tablet.
  • High brightness (700nit) and 5,000:1 contrast ratio
    Project sharp, crystal-clear images for exceptional readability, even in bright sunlight.
  • Designed for 24/7 operation
    Communicate to customers 24/7 with increased durability and reliability.
  • Samsung SMART Signage Platform (SSSP)
    SSSP is an integrated System on Chip (SoC) media player that streamlines digital signage configuration and management by eliminating the need for an additional PC Unit.
  • New MagicInfo Player S3
    Samsung's MagicInfo Player is a built-in content creation solution that allows you to manage promotional materials quickly and easily. MagicInfo Player S3 offers a range of functions designed to increase convenience and customizability: decorative icons, called Stamps and Stickers, which allow you to modify promotions and prices easily; Dynamic Effects feature, which enables transitions between images, such as fades, fly-outs and zooms; a library of free fonts.
  • Built-in Wi-Fi and enhanced mobile application
    Simplify content control and enhance efficiency by downloading the MagicInfo S3 mobile app to your smart phone or tablet. The streamlined smart phone application allows you to edit media and create content using one of Samsung's professional templates. The more powerful tablet version allows you to edit the templates or create content from scratch to fit your specific needs. In both cases, you can connect wirelessly to your media library, allowing you to edit videos and images, then upload and play that content on your SMART signage displays.
  • Home Screen User Interface (UI)
    Control digital signage functions easily with a newly designed user interface (UI) that is fully customizable and highly intuitive. Auto source-switching and recovery Displays automatically switch from one content source to another when the original source fails.
  • DP Loop Out up to 100 displays
    Up to 100 displays can be conveniently connected with a USB device through DP Loop Out to display identical content.
  • Magic Clone
    Simplify installation of multiple displays with the Magic Clone function, which allows users to save settings from one display - such as brightness and contrast - and then copy them to other displays with a USB device. Direct LED screen with narrow bezel and slim depth DHE series displays offer a sleek, sophisticated product profile that minimizes visual impact, and the slim, lightweight housing guarantees convenient installation in a range of settings.
Samsung DH55E DHE Series - 55" LED display
LED-backlit LCD flat panel display
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Wall Components Qty
225
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
Wi-Fi
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, SMART Signage Platform, Image Rotation, Magic Clone, Auto Source Switching & Recovery
Settings Cloning Capability
Speaker System
2 speakers
Supported Memory Cards
SD Memory Card
Remote Control
Standard remote
Voltage
Energy Class
Class B
175 Watt
Power Consumption (On mode)
133 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
194 kWh
123.72 cm x 5.24 cm x 71.35 cm
17.1 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class B
175 Watt
133 W
194 kWh
Diagonal Class
55"
Commercial Use
Series
DHE Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
225
Dimensions
Without stand
123.72 cm
5.24 cm
71.35 cm
17.1 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
Super Clear
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
5000:1
Dynamic Contrast Ratio
50000:1
Brightness
700 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.21 x 0.63mm
Response Time
6 ms
Commercial Features
Pivot, Multiple Display Control (MDC), Certified for 24/7 Continuous Operation, digital daisy chain, MagicInfo, LED BLU, MagicInfo Player-S3
Stands & Mounts
Stand
Optional
VESA Mounting Interface
400 x 400 mm
Media Player
SD Memory Card
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Built-in speaker
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
Wi-Fi
Connector Type
VGA input , DVI-D input , HDMI input , Audio line-in , Component video input , Audio line-out , DisplayPort input , DisplayPort output
Batteries
VGA cable , Serial adapter
Plug and Play, CSA, UL, C-Tick, BSMI, BSMI CNS 13438 Class A, cUL, NEMKO, SASO, CCC, PSB, IRAM, IEC 60950-1, EN 60950-1, KCC, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, cUL No.60950-1, EAC, RCM, EN55024:1998 + A1:2001 + A2:2003, IS13252, GB 4943-2011, EN 55022:2006+A1:2007, VCCI V-3/2010.04 Class A, CNS 14972, AS/NZS CISPR22:2009, GOST-R 51317 series, GOST 22505-97, KN13, KN20, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, NOM-001-SCFI-1993, BIS, INMETRO
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
141.8 cm
Depth (Shipping)
13 cm
Height (Shipping)
81 cm
Weight (Shipping)
21.4 kg
