These innovative and stylish DHE Series SMART Signage displays feature superb ultra-bright luminosity, consistent durability and performance, and a range of picture quality settings that can be optimized to suit virtually any environment. Powered by the enhanced 3rd Generation Samsung SMART Signage Platform (SSSP), DHE Series displays deliver rich content without an additional PC or media player. Samsung's MagicInfo Player S3 is also equipped with a range of intuitive features, such as decorative icons, drag and drop functionality and various fonts, and with Samsung's convenient mobile app, you can manage your digital signage from virtually anywhere through a smart phone or tablet.
Deliver enriched digital messaging 24/7 with high brightness, visibility and premium picture quality
Boost brand recognition, clearly convey business messaging and increase the flow of customer traffic and revenue with bright, 700 nit, 5,000:1 contrast ratio displays. Focus viewers' attention with vivid, crystal-clear images while eliminating factors that can interrupt visibility by light reflection with glare reduction down to 2%. Optimize the viewing experience for virtually any vertical usage with Samsung's unique Picture Quality Setting function, equipped with color enhancer, contrast enhancer, detail enhancer and color temperature control for fine tuning. Whether a business requires rich color to promote products, sharp text and image display, bright video ads or multi-display video wall content, Picture Quality Setting delivers the ultimate viewing experience. Plus, you can leverage DHE Series robust 24/7 durability for continuous high performance with clear visibility over long periods. -
Conveniently and simply manage a rich array of content with an advanced content management platform
Deliver myriad rich content with DHE Series built-in media player and simplified management through 3rd Generation Samsung SMART Signage Platform (SSSP). The embedded, all-in-one 3rd Generation SSSP eliminates the need for a separate PC or media player to streamline digital signage operation and improve total cost of ownership (TCO). New MagicInfo S3, a content management solution embedded in 3rd Generation SSSP enables you to create, deploy and manage content more easily than the previous version with an enhanced UI and UX. MagicInfo S3 leverages 3rd Generation SSSP, an open platform that provides compatibility with myriad third-party software for flexibility and ease of use with other applications. -
Easily manage digital signage with a simplified Home UI
Heighten efficiency and productivity with a newly designed Home Menu UI that displays frequently used functions in a new, large-button matrix design. Simplify usage with a selection of customizable menu configurations that allow ready access to repeatedly used menus. Generate content more easily and conveniently than ever with the Home Menu's newly designed templates for various vertical markets including grocery stores, QSRs, terminals and lobbies. Leverage these sharp, professional template layouts to produce and design content in either portrait or landscape orientation. And, turn the Home Menu into a touch-activated user experience by adding an optional Touch Overlay. -
Engage viewers with an attractive design that is optimized for the environment
Enhance any display environment with a chic and streamlined design and captivating appearance. For convenient and efficient mechanical compatibility, DHE Series displays maintain the same stunning design as previous Samsung D-Series SMART Signage. A flexible, tag-type spacer with a logo is designed for either portrait or landscape installations to create a polished, professional look in any space. -
Built-in Wi-Fi and enhanced mobile application
Simplify content control and enhance efficiency by downloading the MagicInfo S3 mobile app to your smart phone or tablet. The streamlined smart phone application allows you to edit media and create content using one of Samsung's professional templates. The more powerful tablet version allows you to edit the templates or create content from scratch to fit your specific needs. In both cases, you can connect wirelessly to your media library, allowing you to edit videos and images, then upload and play that content on your SMART signage displays. -
Auto source-switching and recovery
Displays automatically switch from one content source to another when the original source fails. -
DP Loop Out up to 100 displays
Up to 100 displays can be conveniently connected with a USB device through DP Loop Out to display identical content. -
Magic Clone
Simplify installation of multiple displays with the Magic Clone function, which allows users to save settings from one display - such as brightness and contrast - and then copy them to other displays with a USB device. -
Direct LED screen with narrow bezel and slim depth
DHE series displays offer a sleek, sophisticated product profile that minimizes visual impact, and the slim, lightweight housing guarantees convenient installation in a range of settings.
- Samsung DH48E DHE Series - 48" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 48"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Max Number of Screens
- 225
- Video Interface
- Component, HDMI
- HDMI Ports Qty
- 1 ports
- Connectivity
- Wi-Fi
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Button lock, SMART Signage Platform, Image Rotation, Magic Clone, Auto Source Switching & Recovery
- Settings Cloning Capability
- Speaker System
- 2 speakers
- Supported Memory Cards
- SD Memory Card
- Included Accessories
- Remote control, batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 145 Watt
- Power Consumption (On mode)
- 97 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 142 kWh
- Dimensions (WxDxH) - without stand
- 108.17 cm x 5.24 cm x 62.6 cm
- 12.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- Energy Class
- Class B
- 145 Watt
- 97 W
- 142 kWh
- Diagonal Class
- 48"
- Commercial Use
- Series
- DHE Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- Component, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- Dimensions
- Without stand
- 108.17 cm
- 5.24 cm
- 62.6 cm
- 12.2 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- Super Clear
- Colour Depth
- Up to 1.07 billion colours
- Image Contrast Ratio
- 5000:1
- Dynamic Contrast Ratio
- 50000:1
- Brightness
- 700 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.183 x 0.549mm
- Response Time
- 8 ms
- Pivot, Multiple Display Control (MDC), Certified for 24/7 Continuous Operation, digital daisy chain, MagicInfo, LED BLU, MagicInfo Player-S3
Video Wall
- 225
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 400 x 400 mm
Media Player
- SD Memory Card
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Built-in speaker
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- Wi-Fi
- Connector Type
- VGA input , DVI-D input , HDMI input , Audio line-in , Component video input , Audio line-out , DisplayPort input , DisplayPort output
- Batteries
- Cables Included
- VGA cable , Serial adapter
- Plug and Play, CSA, UL, C-Tick, BSMI, BSMI CNS 13438 Class A, cUL, NEMKO, SASO, CCC, PSB, IRAM, IEC 60950-1, EN 60950-1, KCC, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, cUL No.60950-1, EAC, RCM, IS13252, GB 4943-2011, VCCI V-3/2010.04 Class A, CNS 14972, GOST-R 51317 series, GOST 22505-97, KN13, KN20, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, NOM-001-SCFI-1993, BIS, INMETRO, AS/NZS CISPR 22:2009, EN 55024:1998+A1:2001+A2:2003, EN 55022:2006+A1:2007
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Width (Shipping)
- 125.7 cm
- Depth (Shipping)
- 13.72 cm
- Height (Shipping)
- 72 cm
- Weight (Shipping)
- 15.7 kg
- 0 °C
- 40 °C
- 10 - 80%
