Product
Samsung DH48E 48" 1920x1080 VGA DVI HDMI DisplayPort WiFi LED Large Format Display
Quicklinx: BKPDWS00 Mfr#: LH48DHEPLGC/EN
  • 1080p (Full HD)
These innovative and stylish DHE Series SMART Signage displays feature superb ultra-bright luminosity, consistent durability and performance, and a range of picture quality settings that can be optimized to suit virtually any environment. Powered by the enhanced 3rd Generation Samsung SMART Signage Platform (SSSP), DHE Series displays deliver rich content without an additional PC or media player. Samsung's MagicInfo Player S3 is also equipped with a range of intuitive features, such as decorative icons, drag and drop functionality and various fonts, and with Samsung's convenient mobile app, you can manage your digital signage from virtually anywhere through a smart phone or tablet.
  • Deliver enriched digital messaging 24/7 with high brightness, visibility and premium picture quality
    Boost brand recognition, clearly convey business messaging and increase the flow of customer traffic and revenue with bright, 700 nit, 5,000:1 contrast ratio displays. Focus viewers' attention with vivid, crystal-clear images while eliminating factors that can interrupt visibility by light reflection with glare reduction down to 2%. Optimize the viewing experience for virtually any vertical usage with Samsung's unique Picture Quality Setting function, equipped with color enhancer, contrast enhancer, detail enhancer and color temperature control for fine tuning. Whether a business requires rich color to promote products, sharp text and image display, bright video ads or multi-display video wall content, Picture Quality Setting delivers the ultimate viewing experience. Plus, you can leverage DHE Series robust 24/7 durability for continuous high performance with clear visibility over long periods.
  • Conveniently and simply manage a rich array of content with an advanced content management platform
    Deliver myriad rich content with DHE Series built-in media player and simplified management through 3rd Generation Samsung SMART Signage Platform (SSSP). The embedded, all-in-one 3rd Generation SSSP eliminates the need for a separate PC or media player to streamline digital signage operation and improve total cost of ownership (TCO). New MagicInfo S3, a content management solution embedded in 3rd Generation SSSP enables you to create, deploy and manage content more easily than the previous version with an enhanced UI and UX. MagicInfo S3 leverages 3rd Generation SSSP, an open platform that provides compatibility with myriad third-party software for flexibility and ease of use with other applications.
  • Easily manage digital signage with a simplified Home UI
    Heighten efficiency and productivity with a newly designed Home Menu UI that displays frequently used functions in a new, large-button matrix design. Simplify usage with a selection of customizable menu configurations that allow ready access to repeatedly used menus. Generate content more easily and conveniently than ever with the Home Menu's newly designed templates for various vertical markets including grocery stores, QSRs, terminals and lobbies. Leverage these sharp, professional template layouts to produce and design content in either portrait or landscape orientation. And, turn the Home Menu into a touch-activated user experience by adding an optional Touch Overlay.
  • Engage viewers with an attractive design that is optimized for the environment
    Enhance any display environment with a chic and streamlined design and captivating appearance. For convenient and efficient mechanical compatibility, DHE Series displays maintain the same stunning design as previous Samsung D-Series SMART Signage. A flexible, tag-type spacer with a logo is designed for either portrait or landscape installations to create a polished, professional look in any space.
  • Built-in Wi-Fi and enhanced mobile application
    Simplify content control and enhance efficiency by downloading the MagicInfo S3 mobile app to your smart phone or tablet. The streamlined smart phone application allows you to edit media and create content using one of Samsung's professional templates. The more powerful tablet version allows you to edit the templates or create content from scratch to fit your specific needs. In both cases, you can connect wirelessly to your media library, allowing you to edit videos and images, then upload and play that content on your SMART signage displays.
  • Auto source-switching and recovery
    Displays automatically switch from one content source to another when the original source fails.
  • DP Loop Out up to 100 displays
    Up to 100 displays can be conveniently connected with a USB device through DP Loop Out to display identical content.
  • Magic Clone
    Simplify installation of multiple displays with the Magic Clone function, which allows users to save settings from one display - such as brightness and contrast - and then copy them to other displays with a USB device.
  • Direct LED screen with narrow bezel and slim depth
    DHE series displays offer a sleek, sophisticated product profile that minimizes visual impact, and the slim, lightweight housing guarantees convenient installation in a range of settings.
Samsung DH48E DHE Series - 48" LED display
LED-backlit LCD flat panel display
Diagonal Class
48"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Wall Components Qty
225
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
Wi-Fi
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, SMART Signage Platform, Image Rotation, Magic Clone, Auto Source Switching & Recovery
Settings Cloning Capability
Speaker System
2 speakers
Supported Memory Cards
SD Memory Card
Remote Control
Standard remote
Voltage
Energy Class
Class B
145 Watt
Power Consumption (On mode)
97 W
Energy Consumption per Year
142 kWh
108.17 cm x 5.24 cm x 62.6 cm
12.2 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class B
145 Watt
97 W
142 kWh
Diagonal Class
48"
Commercial Use
Series
DHE Series
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
225
Dimensions
Without stand
108.17 cm
5.24 cm
62.6 cm
12.2 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Coating
Super Clear
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
5000:1
Dynamic Contrast Ratio
50000:1
Brightness
700 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.183 x 0.549mm
Response Time
8 ms
Commercial Features
Pivot, Multiple Display Control (MDC), Certified for 24/7 Continuous Operation, digital daisy chain, MagicInfo, LED BLU, MagicInfo Player-S3
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Media Player
SD Memory Card
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Built-in speaker
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
Wi-Fi
Connector Type
VGA input , DVI-D input , HDMI input , Audio line-in , Component video input , Audio line-out , DisplayPort input , DisplayPort output
Batteries
VGA cable , Serial adapter
Plug and Play, CSA, UL, C-Tick, BSMI, BSMI CNS 13438 Class A, cUL, NEMKO, SASO, CCC, PSB, IRAM, IEC 60950-1, EN 60950-1, KCC, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, cUL No.60950-1, EAC, RCM, EN55024:1998 + A1:2001 + A2:2003, IS13252, GB 4943-2011, EN 55022:2006+A1:2007, VCCI V-3/2010.04 Class A, CNS 14972, AS/NZS CISPR22:2009, GOST-R 51317 series, GOST 22505-97, KN13, KN20, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, NOM-001-SCFI-1993, BIS, INMETRO
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
125.7 cm
Depth (Shipping)
13.72 cm
Height (Shipping)
72 cm
Weight (Shipping)
15.7 kg
10 - 80%
