Convey your business messaging with style and power through impeccable, highly reliable Samsung DHD Series digital signage. This innovative digital signage solution provides an immersive viewing experience by delivering crystal-clear images, while operating flawlessly 24/7 to promote your business, attract viewers and increase revenues. Powered by an upgraded 2nd generation Samsung smart signage platform (SSSP) all-in-one embedded content management solution, Samsung DHD Series digital signage doesn't require an additional PC or media player, even for touch interactivity. Plus, you can easily manage the digital signage remotely from virtually anywhere using a Wi-Fi-enabled mobile device. And, with proven technology from an industry leader, DHD Series digital signage is a premium signage lineup for those who consider high durability and exceptional performance as essential.
Provide an immersive viewing experience with crystal-clear images
DHD series digital signage delivers highly advanced technology to create a continuously immersive viewing experience. This professional signage solution offers 700-nit brightness, broadcasting vivid, highly legible images in various lighting conditions. The solution is ideal for information delivery in areas that require superb readability, for example, transportation terminals, shopping malls and other brightly lit environments. -
Simplify content delivery with a hassle-free all-in-one solution
Improve productivity and reduce operating costs by installing and configuring the signage solution with greater ease. The embedded, all-in-one 2nd Generation SSSP eliminates the need for a separate PC or media player to streamline digital signage operation and improve total cost of ownership (TCO). To boost efficiency, content deployment and sharing is simplified with a PC-less network connection that lets you plug in a USB and link multiple displays over a daisy chain configuration. -
Accelerate business performance with advanced SSSP
The quad-core SoC processor substantially improves performance with a remarkably faster processing speed for rich, seamless messaging. The increased power supports interactive digital signage capability that is available for all sizes through an optional Touch Overlay. This innovative feature amplifies your messaging with engaging interactivity, without the need for an additional PC. Now, schools, corporations and other businesses can offer interactive signage with less expense and difficulty. In addition, the 2nd Generation SSSP supports a picture-in-picture (PIP) size over 50 percent of the digital signage area for operational excellence, compared to less than 50 percent in dual-core digital signage. -
Manage digital signage wirelessly virtually anywhere, anytime on a mobile device
DHD series digital signage comes equipped with a Wi-Fi module that enables you, to easily transfer, play, share and schedule digital signage content without a physical connection. You no longer have to deal with burdensome cables and connector ports. With mobile app control and content sharing features, you can deploy and manage content from virtually anywhere using a Wi-Fi-equipped smartphone, PC or tablet for maximum flexibility. You can even wirelessly configure and deploy content to the digital signage installations using the Wi-Fi module. This feature is ideal in places where cabling is difficult to install.
- Samsung DH48D DHD series - 48" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 48"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Max Number of Screens
- 225
- Video Interface
- Component, composite, HDMI
- Connectivity
- Wi-Fi
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- SMART Signage Platform, Image Rotation, Magic Clone, Auto Source Switching & Recovery
- Settings Cloning Capability
- Speaker System
- 2 speakers
- Supported Memory Cards
- SD Memory Card
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 145 Watt
- Power Consumption (On mode)
- 105 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 153 kWh
- Dimensions (WxDxH) - without stand
- 108.17 cm x 5.24 cm x 62.6 cm
- 12.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- Energy Class
- Class B
- 145 Watt
- 105 W
- 153 kWh
- Diagonal Class
- 48"
- Commercial Use
- Series
- DHD series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- PC Interface
- HDCP Compatible
- Dimensions
- Without stand
- 108.17 cm
- 5.24 cm
- 62.6 cm
- 12.2 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- Super Clear
- Colour Depth
- Up to 1.07 billion colours
- Image Contrast Ratio
- 5000:1
- Brightness
- 700 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.183 x 0.549mm
- Response Time
- 8 ms
- Pivot, digital daisy chain, MagicInfo, d-LED BLU, key lock, MagicInfo Player-S2
Video Wall
- 225
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 400 x 400 mm
Media Player
- SD Memory Card
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- Wi-Fi
- Connector Type
- VGA input , DVI-D input , DisplayPort , HDMI , Composite video / component video input , Audio line-in , DisplayPort output , Audio line-out
- Cables Included
- VGA cable , Serial adapter
- Plug and Play, CSA, UL, TUV, VCCI, C-Tick, BSMI, GOST, EN55022, NEMKO, NOM, SASO, CB, AS/NZS 60950-1, CCC, PSB, EK, IRAM, IEC 60950-1, EN 60950-1, KCC, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1993 IRAM, NOM-019-SCFI-1998, KN22, KN24, K60950-1, cUL No.60950-1, EAC, RCM, IS13252, VCCI V-3/2010.04 Class A, CNS 14972, GOST 22505-97, KN13, KN20, CNS 13438 Class A ITE EMI, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, GOST-R 51317, NOM-001-SCFI-1993, BIS, INMETRO, GB 4943.1-2011, AS/NZS CISPR 22:2009, EN 55024:1998+A1:2001+A2:2003, EN 55022:2006+A1:2007
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0 Watt
- On / Off Switch
- Weight (Shipping)
- 15.7 kg
- 0 °C
- 40 °C
- 10 - 80%
