Samsung DH40D 40" 1920x1080 VGA DVI HDMI DisplayPort SOC LED Large Format Display
Quicklinx: B4SNWS00 Mfr#: LH40DHDPLGC/EN
  • 1080p
Convey your business messaging with style and power through impeccable, highly reliable Samsung DHD Series digital signage. This innovative digital signage solution provides an immersive viewing experience by delivering crystal-clear images, while operating flawlessly 24/7 to promote your business, attract viewers and increase revenues. Powered by an upgraded 2nd generation Samsung smart signage platform (SSSP) all-in-one embedded content management solution, Samsung DHD Series digital signage doesn't require an additional PC or media player, even for touch interactivity. Plus, you can easily manage the digital signage remotely from virtually anywhere using a Wi-Fi-enabled mobile device. And, with proven technology from an industry leader, DHD Series digital signage is a premium signage lineup for those who consider high durability and exceptional performance as essential.
  • Provide an immersive viewing experience with crystal-clear images
    DHD series digital signage delivers highly advanced technology to create a continuously immersive viewing experience. This professional signage solution offers 700-nit brightness, broadcasting vivid, highly legible images in various lighting conditions. The solution is ideal for information delivery in areas that require superb readability, for example, transportation terminals, shopping malls and other brightly lit environments.
  • Simplify content delivery with a hassle-free all-in-one solution
    Improve productivity and reduce operating costs by installing and configuring the signage solution with greater ease. The embedded, all-in-one 2nd Generation SSSP eliminates the need for a separate PC or media player to streamline digital signage operation and improve total cost of ownership (TCO). To boost efficiency, content deployment and sharing is simplified with a PC-less network connection that lets you plug in a USB and link multiple displays over a daisy chain configuration.
  • Accelerate business performance with advanced SSSP
    The quad-core SoC processor substantially improves performance with a remarkably faster processing speed for rich, seamless messaging. The increased power supports interactive digital signage capability that is available for all sizes through an optional Touch Overlay. This innovative feature amplifies your messaging with engaging interactivity, without the need for an additional PC. Now, schools, corporations and other businesses can offer interactive signage with less expense and difficulty. In addition, the 2nd Generation SSSP supports a picture-in-picture (PIP) size over 50 percent of the digital signage area for operational excellence, compared to less than 50 percent in dual-core digital signage.
  • Manage digital signage wirelessly virtually anywhere, anytime on a mobile device
    DHD series digital signage comes equipped with a Wi-Fi module that enables you, to easily transfer, play, share and schedule digital signage content without a physical connection. You no longer have to deal with burdensome cables and connector ports. With mobile app control and content sharing features, you can deploy and manage content from virtually anywhere using a Wi-Fi-equipped smartphone, PC or tablet for maximum flexibility. You can even wirelessly configure and deploy content to the digital signage installations using the Wi-Fi module. This feature is ideal in places where cabling is difficult to install.
Samsung DH40D DHD series - 40" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
40"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Max Number of Screens
225
Video Interface
Component, composite, HDMI
Wi-Fi
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
SMART Signage Platform, Image Rotation, Magic Clone, Auto Source Switching & Recovery
Settings Cloning Capability
Speaker System
2 speakers
Supported Memory Cards
SD Memory Card
Remote control
Voltage
Energy Class
Class C
135 Watt
Power Consumption (On mode)
90 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
131 kWh
91.32 cm x 5.24 cm x 53.13 cm
8.6 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class C
135 Watt
90 W
131 kWh
Diagonal Class
40"
Commercial Use
Series
DHD series
Video Processor
Quad-Core
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
PC Interface
HDCP Compatible
Dimensions
Without stand
91.32 cm
5.24 cm
53.13 cm
8.6 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-reflection
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
5000:1
Brightness
700 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.15375 x 0.46125mm
Response Time
8 ms
Commercial Features
Pivot, MagicInfo, d-LED BLU, MagicInfo Player-S2
Video Wall
225
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
Media Player
SD Memory Card
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
Wi-Fi
Connector Type
VGA input , DVI-D input , DisplayPort , HDMI , Composite video / component video input , Audio line-in , DisplayPort output , Audio line-out
VGA cable , Serial adapter
Plug and Play, CSA, UL, TUV, VCCI, C-Tick, BSMI, GOST, EN55022, NEMKO, NOM, SASO, CB, AS/NZS 60950-1, CCC, PSB, EK, IRAM, IEC 60950-1, EN 60950-1, KCC, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1993 IRAM, NOM-019-SCFI-1998, KN22, KN24, K60950-1, cUL No.60950-1, EAC, RCM, IS13252, VCCI V-3/2010.04 Class A, CNS 14972, GOST 22505-97, KN13, KN20, CNS 13438 Class A ITE EMI, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, GOST-R 51317, NOM-001-SCFI-1993, BIS, INMETRO, GB 4943.1-2011, AS/NZS CISPR 22:2009, EN 55024:1998+A1:2001+A2:2003, EN 55022:2006+A1:2007
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Input Voltage
0.5 Watt
Power Consumption Sleep
0 Watt
On / Off Switch
Weight (Shipping)
10.5 kg
10 - 80%
