Samsung DC32E 32" 1920x1080 VGA DVI HDMI LED Large Format Display
Quicklinx: BWY5WS00 Mfr#: LH32DCEPLGC/EN
  • 1080p
Captivate your audience with stunning, Full HD images and crisp text on Samsung DCE series displays. This digital signage solution gives you the essential functionality you need to easily produce attention-grabbing messages. Its slim, lightweight design makes installation a snap compared with cumbersome conventional displays, saving you needless start-up expenses. The displays feature direct LED BLU technology for rich picture quality, low power consumption and reduced operating costs.
  • Attract customers with optimized 16/7 performance
    Engage customers and vividly display business messaging with Samsung DCE series SMART Signage, featuring high picture quality and reliable 16/7 usage. With a slim, sleek design for extended indoor use in retail stores, small businesses and corporate conference rooms and offices, DCE series displays stunningly present a range of immersive and timely information with captivating picture quality.
  • MagicInfo Lite player
    MagicInfo Lite player uses a sophisticated technology to play a huge range of content including video, images, photos on demand, or from a schedule. Customers can easily play files from, or transfer between, the large internal memory or external USB devices plugged into the in-built port.
  • Control displays in multiple locations easily and instantly
    MagicInfo Lite solution that comes with the embedded media player extends the remote content management over network through MagicInfo server. Media contents of the USB memory stick plugged in to the back of the DCE series displays can be scheduled to play from a remote PC. The connection to MagicInfo server also allows remote monitoring and management of the DCE series displays. Device information, content playback schedules, network data monitoring, time scheduling, alarms and various controls are all available remotely even without being in front of the displays.
  • Easily manage digital signage with a versatile connectivity
    Connect the display to other digital signage easily with interfaces based on your specific needs. The displays provide not only the essential connections businesses use the most but support for a wide range of source device types. Interfaces include HDMI, DVI, D-sub, composite input as well as RJ-45 port for extensive connectivity.
Samsung DC32E DCE Series - 32" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
32"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Video Interface
Composite, HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
SMART Signage Platform
Speaker System
1 speaker
USB
Remote control, batteries
Energy Class
Class B
Power Consumption (On mode)
50 W
Energy Consumption per Year
73 kWh
72.14 cm x 4.99 cm x 42.03 cm
4.8 kg
Energy Class
Class B
50 W
73 kWh
Diagonal Class
32"
Commercial Use
Series
DCE Series
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
Composite, HDMI
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode
Dimensions
Without stand
72.14 cm
4.99 cm
42.03 cm
4.8 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
60 Hz Refresh Rate
LED backlight
Image Contrast Ratio
5000:1
Brightness
330 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Commercial Features
MagicInfo Lite, d-LED BLU, Mega Dynamic Contrast Ratio, Certified for 16/7 Continuous Operation
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Speaker System
1 speaker
Output Power / Total
10 Watt
Speakers
1 x main channel speaker - 10 Watt
Network & Internet Multimedia
LAN
Connector Type
VGA input , LAN , Audio line-in , Audio line-out , 2 x HDMI input , DVI-D input , Composite video input , Remote control , Serial , USB
Batteries
Serial adapter
Width (Shipping)
81.5 cm
Depth (Shipping)
13.2 cm
Height (Shipping)
49.1 cm
Weight (Shipping)
5.9 kg
10 - 80%
