The Samsung DB55D delivers advanced display technology in an affordable fashion. Create stunning and seamless video walls in Full HD resolution thanks to an upgraded Samsung SMART Signage Platform (SSP) and full range of connectivity options. Combined with a sleek industrial design and slim 2" chassis depth, you can captivate your audience in a moment and leave a lasting impression on the 55" screen.
Enhanced SSP with Quad Core processor
Experience 2x SoC performance thanks to SSP with a quad core processor. SSP is an integrated, open platform providing a powerful streamlined solution to reduce TCO in digital signage deployments through savings in hardware installation and operating costs. -
Sleek industrial design
Slim-direct LED backlight technology delivers a sleek industrial design with a 2" chassis depth that is combined with a symmetrical 10.5 mm bezel for an elegant look. LED also slims your TCO thanks to up to 50% energy savings over CCFL. -
Full connectivity
Discover versatile connectivity options to display a full range of exceptional content that speaks to your audience. Connections include D-Sub, Component, and Composite, DVI, HDMI, USB, SD, RS232C in/out, ir in/out and more. -
Wi-Fi ready
Ready to expand your versatility even more, you can enjoy easy media sharing and screen control after installing Wi-Fi. Use AllShare Cast over a Wi-Fi connection for simple content mirroring from a tablet or mobile phone to your display. -
Clean UI design
A user-friendly interface provides an intuitive user experience from changing display settings to installing video walls and managing content schedules and templates. Helping to streamline installation and maintenance, users can effectively coordinate their signage.
- Samsung DB55D DB-D Series - 55" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 55"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Button lock, SMART Signage Platform, Image Rotation, Magic Clone, Auto Source Switching & Recovery, Lamp Error Detection
- Supported Memory Cards
- SD Memory Card
- USB
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 176 Watt
- Power Consumption (On mode)
- 120 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 175 kWh
- Dimensions (WxDxH) - without stand
- 123.06 cm x 4.99 cm x 70.69 cm
- 15.4 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- Energy Class
- Class B
- 176 Watt
- 120 W
- 175 kWh
- Diagonal Class
- 55"
- Commercial Use
- Series
- DB-D Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Dimensions
- Without stand
- 123.06 cm
- 4.99 cm
- 70.69 cm
- 15.4 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- Super Clear
- Colour Depth
- 16.7 million colours
- Dynamic Contrast Ratio
- 5000:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.21 x 0.63mm
- Response Time
- 6 ms
- Pivot, Multiple Display Control (MDC), MagicInfo, LED BLU, Smart Scheduling
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 400 x 400 mm
Media Player
- SD Memory Card
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Built-in speaker
- Connector Type
- VGA input , DVI-D input , HDMI input , Audio line-in , Component video input , Composite video/audio input , Audio line-out , USB 2.0
- Cables Included
- VGA cable
- TUV, C-Tick, BSMI, GOST, cUL, EN 60950, EN55022, NOM, PCBC, SASO, SIQ, IEC 60950, EN55024, UL 60950, CB, CCC, EMC, PSB, EK, AS/NZS 3548, IRAM, KCC, FCC Part 15 B Class A, VCCI V-3, GB 9254-2008, GB 17625.1-2003 EMC, KN22, KN24, K60950, NOM-001-SCFI-1993 IRAM, GB 4943.1, CNS 13438, IS13252
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Width (Shipping)
- 134.8 cm
- Depth (Shipping)
- 14.8 cm
- Height (Shipping)
- 81 cm
- Weight (Shipping)
- 19.5 kg
- 0 °C
- 40 °C
- 10 - 80%
