Samsung DB48E 48" 1920x1080 VGA DVI HDMI WiFi LED Large Format Display
Quicklinx: BKPTWS00 Mfr#: LH48DBEPLGC/EN
  • 1080p (Full HD)
The Samsung DB48E delivers advanced display technology in an affordable fashion. Create stunning and seamless video walls in Full HD resolution. Combined with a sleek industrial design and slim chassis depth, you can captivate your audience in a moment and leave a lasting impression on a large screen.
  • Enhanced experience
    Experience is enhanced with powerful processor and SSP. SSP is an integrated, open platform providing a powerful streamlined solution to reduce TCO in digital signage deployments through savings in hardware installation and operating costs.
  • Sleek industrial design
    Slim-direct LED backlight technology delivers a sleek industrial design with a slim chassis depth that is combined with a symmetrical bezel for an elegant look. LED also slims your TCO thanks to energy savings over CCFL.
  • Full connectivity
    Discover versatile connectivity options to display a full range of exceptional content that speaks to your audience.
  • Clean UI design
    User-friendly interface provides an intuitive user experience from changing display settings to installing video walls and managing content schedules and templates. Helping to streamline installation and maintenance, users can effectively coordinate their signage.
Samsung DB48E DBE Series - 48" LED display
LED-backlit LCD flat panel display
Diagonal Class
48"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Motion Enhancement Technology
60 Hz Refresh Rate
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
Wi-Fi, LAN
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, SMART Signage Platform, Image Rotation, Magic Clone, Auto Source Switching & Recovery
Speaker System
2 speakers
Supported Memory Cards
SD Memory Card
USB
Remote Control
Standard remote
Voltage
Energy Class
Class A
132 Watt
Power Consumption (On mode)
85 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
124 kWh
107.51 cm x 4.99 cm x 61.94 cm
11.1 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class A
132 Watt
85 W
124 kWh
Diagonal Class
48"
Commercial Use
Series
DBE Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Dimensions
Without stand
107.51 cm
4.99 cm
61.94 cm
11.1 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Coating
Super Clear
Colour Depth
16.7 million colours
Image Contrast Ratio
5000:1
Dynamic Contrast Ratio
50000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.183 x 0.549mm
Response Time
8 ms
Commercial Features
Pivot, Multiple Display Control (MDC), Smart Scheduling, d-LED BLU, MagicInfo Player-S3
Stands & Mounts
Stand
Optional
VESA Mounting Interface
400 x 400 mm
Media Player
SD Memory Card
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Smart phone remote support
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
Wi-Fi, LAN
Connector Type
Remote control/ambient sensor input , VGA input , Multiple Display Control , Serial input , Serial output , Audio line-in , Audio line-out , DVI-D input , HDMI input , Composite video / component video input
Batteries
VGA cable , Serial adapter
Plug and Play, CSA, UL, TUV, C-Tick, BSMI, BSMI CNS 13438 Class A, cUL, DDC-2B, NEMKO, NOM, SASO, CB, AS/NZS 60950-1, CCC, PSB, IRAM, IEC 60950-1, EN 60950-1, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1998, K60950-1, KCC KN22, KCC KN24, EAC, EN 55024-2:1998+A1:2001+A2:2003, GB4943.1-2011, RCM, EN 55022:2006+A1:2007, VCCI V-3/2010.04 Class A, CNS 14972, AS/NZS CISPR22:2009, GOST-R 51317 series, GOST 22505-97, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, NOM-001-SCFI-1993, BIS, INMETRO
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
118.5 cm
Depth (Shipping)
14.8 cm
Height (Shipping)
71.5 cm
Weight (Shipping)
14 kg
10 - 80% (non-condensing)
