Product
Samsung DB32E 32" 1920x1080 VGA DVI HDMI WiFi LED Large Format Display
Quicklinx: BKPQWS00 Mfr#: LH32DBEPLGC/EN
  • 1080p (Full HD)
Engage customers with vivid business messaging on affordable Samsung DBE Series displays. Featuring high picture quality, bright screens (350 nit) and the durability to operate for up to 16 hours a day, DBE Series displays present high-quality content to help you stand out from the competition. With internal memory and embedded Wi-Fi, DBE displays offer convenience and cost-efficiency. Powered by the enhanced 3rd Generation Samsung SMART Signage Platform (SSSP), DME Series displays deliver rich content without an additional PC or media player. Samsung's MagicInfo Player S3 is also equipped with a range of intuitive features, such as decorative icons, drag and drop functionality and various fonts, and with Samsung's convenient mobile app, you can manage your digital signage from virtually anywhere through a smart phone or tablet.
  • Attract customers with optimized 16/7 performance
    Attract customers and improve your professional image with DBE Series SMART Signage, featuring 350 nit brightness, stunning picture quality and reliable 16/7 operation. Bright DBE Series displays eliminate interrupted visibility by reducing glare down to 2%. Picture quality can be optimized for virtually any conditions with a color enhancer, contrast enhancer, detail enhancer and color temperature control. Whether your business requires rich color and detailed textures, sharp text and image display or multi-display video wall content, you can adjust DBE Series displays to clearly convey your message.
  • Engage viewers with an attractive design that is optimized for the environment
    Enhance your display environment with sleek, streamlined displays. DBE Series displays maintain the same stunning design as previous Samsung D-Series SMART Signage for convenient and efficient mechanical compatibility. The displays feature slim and elegant black hairline deco-bezels or white color deco-bezels to complement your business décor. And, a flexible, tag-type spacer with a logo is designed for either portrait or landscape installations to create a polished, professional look in any space.
Samsung DB32E DBE Series - 32" LED display
LED-backlit LCD flat panel display
Diagonal Class
32"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Motion Enhancement Technology
60 Hz Refresh Rate
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
Wi-Fi, LAN
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, SMART Signage Platform, Image Rotation, Magic Clone, Auto Source Switching & Recovery
Speaker System
2 speakers
Supported Memory Cards
SD Memory Card
USB
Remote Control
Standard remote
Voltage
Energy Class
Class B
121 Watt
Power Consumption (On mode)
54 W
Energy Consumption per Year
79 kWh
72.14 cm x 4.99 cm x 42.03 cm
4.8 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class B
121 Watt
54 W
79 kWh
Diagonal Class
32"
Commercial Use
Series
DBE Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Dimensions
Without stand
72.14 cm
4.99 cm
42.03 cm
4.8 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Coating
Super Clear
Colour Depth
16.7 million colours
Image Contrast Ratio
5000:1
Dynamic Contrast Ratio
50000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.12125 x 0.36375mm
Response Time
8 ms
Commercial Features
Pivot, Multiple Display Control (MDC), Smart Scheduling, d-LED BLU, MagicInfo Player-S3
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
Media Player
SD Memory Card
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Smart phone remote support
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
Wi-Fi, LAN
Connector Type
Remote control/ambient sensor input , VGA input , Multiple Display Control , Serial input , Serial output , Audio line-in , Audio line-out , DVI-D input , HDMI input , Composite video / component video input
Batteries
VGA cable , Serial adapter
Plug and Play, CSA, UL, TUV, C-Tick, BSMI, BSMI CNS 13438 Class A, cUL, DDC-2B, NEMKO, NOM, SASO, CB, AS/NZS 60950-1, CCC, PSB, IRAM, IEC 60950-1, EN 60950-1, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1998, K60950-1, KCC KN22, KCC KN24, EAC, EN 55024-2:1998+A1:2001+A2:2003, GB4943.1-2011, RCM, EN 55022:2006+A1:2007, VCCI V-3/2010.04 Class A, CNS 14972, AS/NZS CISPR22:2009, GOST-R 51317 series, GOST 22505-97, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, NOM-001-SCFI-1993, BIS, INMETRO
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
81.5 cm
Depth (Shipping)
13.2 cm
Height (Shipping)
49.1 cm
Weight (Shipping)
5.9 kg
10 - 80% (non-condensing)
