Samsung's DB22D-T offers touchscreen interactivity along with a fully embedded solution to manage digital signage content without connecting external devices. An enhanced Samsung SMART Signage Platform (SSP) features a quad core processor, combined with media player functionality via System-on-Chip (SoC), and MagicInfo software. The 22" form factor fits small placements, while Full HD resolution delivers sharp, stunning images.
Touchscreen interactivity
With an interactive touchscreen, the DB22D-T can enhance the customer experience in various retail and hospitality settings. The hands-on approach helps your customers engage with your business in new ways, which can lead to tangible results. -
Enhanced SSP with quad core processor
Experience enhanced SoC performance with a quad core processor. SSP is an integrated, open platform providing a powerful streamlined solution to reduce TCO in digital signage deployments through savings in hardware installation and operating costs. -
All-in-One solution
The DB22D features SSP enabled with media player functionality via SoC, built-in processing, built-in power control and MagicInfo content management software for an all-in-one digital signage solution that allows users to effectively and efficiently coordinate their signage. -
Sleek industrial design
Slim-direct LED backlight technology delivers a sleek industrial design with a 2.3" chassis depth that is combined with a 22" form factor for an elegant look in small placements. LED also slims your TCO thanks to up to 50% energy savings over CCFL. -
Connectivity and control
Discover versatile connectivity options to display a range of exceptional content that speaks to your audience. Connections include D-sub, USB, HDMI and WiFi embedded and external control capability via RS232C. Built-in Wi-Fi allows you to eliminate LAN cables for simpler installation. -
Adapts to your business
Small shops, shopping malls and large chain stores can utilize the DB22D as a shelf-level or endcap solution. Enterprises can share agenda or meeting room information outside of conference rooms. In public spaces, advertising or floor level information can be displayed on the inside of an elevator.
- Samsung DB22D-T 22" Class (21.5" viewable) LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 22"
- Diagonal Size
- 21.5"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- TV Tuner
- No tuner
- Commercial Features
- Button lock, SMART Signage Platform, Image Rotation, Magic Clone, Auto Source Switching & Recovery
- Speaker System
- 2 speakers
- USB
- Included Accessories
- Remote control, batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 44 Watt
- Power Consumption (On mode)
- 31 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 45 kWh
- Dimensions (WxDxH) - without stand
- 50.75 cm x 5.93 cm x 31.12 cm
- 4.4 kg
- 3-year warranty
- Product Type
- Energy Class
- Class B
- 44 Watt
- 31 W
- 45 kWh
- Diagonal Class
- 22"
- Diagonal Size
- 21.5"
- Commercial Use
- Video Processor
- Quad-Core
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- Modes
- Portrait mode, landscape mode
- Dimensions
- Without stand
- 50.75 cm
- 5.93 cm
- 31.12 cm
- 4.4 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- LED backlight
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 1000:1
- Dynamic Contrast Ratio
- 50000:1
- Brightness
- 220 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.2482 x 0.2482mm
- Touchpoints Qty
- 10
- Response Time
- 14 ms
- Pivot, Multiple Display Control (MDC), Smart Scheduling, e-LED BLU, Certified for 16/7 Continuous Operation, MagicInfo Player-S2
Stands & Mounts
- Flat Panel Mount Interface
- 100 x 100 mm
Media Player
- USB Port
Remote Control
- Remote control
- Smart phone remote support
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 2 Watt
- Speakers
- 2 x main channel speaker - 1 Watt
- Connector Type
- HDMI input , VGA input , Audio line-in , Multiple Display Control , USB 2.0
- Batteries
- Cables Included
- VGA cable
- Plug and Play, DDC-2B, EN 60950, EN55022, IEC 60950, EN55024, EMC
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Limited warranty - 3 years
- Width (Shipping)
- 57 cm
- Depth (Shipping)
- 12.8 cm
- Height (Shipping)
- 37.6 cm
- Weight (Shipping)
- 5.7 kg
- 0 °C
- 40 °C
- 10 - 80%
