Samsung DB22D-P 21.5" 1920x1080 VGA HDMI WiFi LED Large Format Display
Quicklinx: BKPPWS00 Mfr#: LH22DBDPSGR/EN
  • 1080p
Samsung's DB22D-P provides a fully embedded solution to manage digital signage content without connecting external devices. An enhanced Samsung SMART Signage Platform (SSP) features a quad core processor, combined with media player functionality via System-on-Chip (SoC), and MagicInfo software. The 22" form factor fits small placements, while full HD resolution delivers sharp, stunning images.
  • Enhanced SSP with quad core processor
    Experience enhanced SoC performance with a quad core processor. SSP is an integrated, open platform providing a powerful streamlined solution to reduce TCO in digital signage deployments through savings in hardware installation and operating costs.
  • All-in-One solution
    The DB22D features SSP enabled with media player functionality via SoC, built-in processing, built-in power control and MagicInfo content management software for an all-in-one digital signage solution that allows users to effectively and efficiently coordinate their signage.
  • Sleek industrial design
    Slim-direct LED backlight technology delivers a sleek industrial design with a 2.3" chassis depth that is combined with a 22" form factor for an elegant look in small placements. LED also slims your TCO thanks to up to 50% energy savings over CCFL.
  • Connectivity and control
    Discover versatile connectivity options to display a range of exceptional content that speaks to your audience. Connections include D-sub, USB, HDMI and WiFi embedded and external control capability via RS232C. Built-in WiFi allows you to eliminate LAN cables for simpler installation.
  • Adapts to your business
    Small shops, shopping malls and large chain stores can utilize the DB22D as a shelf-level or endcap solution. Enterprises can share agenda or meeting room information outside of conference rooms. In public spaces, advertising or floor level information can be displayed on the inside of an
Samsung DB22D-P 22" Class (21.5" viewable) LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
22"
Diagonal Size
21.5"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Video Interface
HDMI
HDMI Ports Qty
1 ports
Wi-Fi
PC Interface
VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
TV Tuner
No tuner
Commercial Features
Button lock, SMART Signage Platform, Image Rotation, Magic Clone, Auto Source Switching & Recovery
Settings Cloning Capability
Speaker System
2 speakers
USB
Remote control, batteries
Voltage
Energy Class
Class C
44 Watt
Power Consumption (On mode)
31 W
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
45 kWh
50.75 cm x 5.78 cm x 31.12 cm
3.6 kg
Energy Class
Class C
44 Watt
31 W
45 kWh
Diagonal Class
22"
Diagonal Size
21.5"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Modes
Portrait mode
Dimensions
Without stand
50.75 cm
5.78 cm
31.12 cm
3.6 kg
Display
Resolution
1920 x 1080
Display Format
1080p
60 Hz Refresh Rate
LED backlight
Colour Depth
16.7 million colours
Image Contrast Ratio
1000:1
Dynamic Contrast Ratio
50000:1
Brightness
250 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.2482 x 0.2482mm
Response Time
14 ms
Commercial Features
Multiple Display Control (MDC), Smart Scheduling, e-LED BLU, MagicInfo Player-S2
Stands & Mounts
Flat Panel Mount Interface
100 x 100 mm
Media Player
USB Port
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
2 Watt
Built-in speaker
Speakers
2 x main channel speaker - 1 Watt
Network & Internet Multimedia
Wi-Fi
Connector Type
HDMI input , VGA input , Audio line-in , Multiple Display Control , USB
Batteries
VGA cable
Plug and Play, CSA, UL, TUV, VCCI, C-Tick, BSMI, GOST, cUL, DDC-2B, NEMKO, SASO, AS/NZS 60950-1, CCC, PSB, IRAM, IEC 60950-1, EN 60950-1, KCC, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1998, K60950-1, KCC KN22, KCC KN24, cUL No.60950-1, EAC, IS13252, VCCI V-3/2010.04 Class A, CNS 14972, GOST-R 51317 series, GOST 22505-97, CNS 13438 Class A ITE EMI, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, NOM-001-SCFI-1993, BIS, INMETRO, GB 4943.1-2011, AS/NZS CISPR 22:2009, EN 55024:1998+A1:2001+A2:2003, EN 55022:2006+A1:2007
Power supply
Input Voltage
0.3 Watt
Width (Shipping)
57 cm
Depth (Shipping)
12.8 cm
Height (Shipping)
37.6 cm
Weight (Shipping)
4.9 kg
10 - 80%
