Present your business messages in the ideal way with affordable Samsung DB22D series digital signage that delivers flexible connectivity and high indoor performance. The affordable, embedded, all-in-one media solution with improved performance makes it easy to manage content while maintaining low total cost of ownership (TCO). Economical 21.5 inches Samsung DBD series digital signage features a distinctive, sleek design. Turn your small space into creative advertising and effective information sharing with Samsung's small-sized signage solution.
Optimize performance, cost-efficiency and easy installation in advanced digital signage
DBD series digital signage offers you a winning combination of cost-efficiency, ease of installation and optimal performance that enables you to be more productive. The embedded, all-in-one Samsung smart signage platform (SSSP) boosts power and capacity while providing user-friendly content management. Without the need for external media players or PCs, the deployment process is streamlined, saving your time and resources. You can conveniently install this cable-less, lightweight digital signage with its sleek design and built-in power supply for an impressive, modern look and clear message delivery 16/7 on bright, 250-nit screens. -
Simplify content delivery with a hassle-free all-in-one solution
Improve productivity and reduce operating costs by installing and configuring the signage solution in small spaces with greater ease. Even for small space. The embedded, all-in-one SSSP eliminates the need for a separate PC or media player to streamline digital signage operation and improve total cost of ownership (TCO). To boost efficiency, content deployment is simplified without a PC by USB Plug-and-Play. -
Accelerate business performance with advanced SSSP
DB22D series digital signage is powered by a significantly upgraded embedded SSSP. The quad-core SoC processor substantially improves performance with a remarkably faster processing speed for rich, seamless messaging. In addition, the SSSP supports a picture-in-picture (PIP) size over 50 percent of the digital signage area for operational excellence, compared to less than 50 percent in dual-core digital signage. -
Manage digital signage wirelessly virtually anywhere, anytime on a mobile device
With a convenient built-in Wi-Fi module, users can control and wirelessly distribute content to the digital signage solution using mobile devices for convenient content management. The ability to send and schedule content from a mobile device, instead of locating a PC that is connected to the digital signage or finding suitable cable connections simplifies display management. -
Easily manage digital signage with a simplified Home UI, tools and templates
Experience intuitive control of digital signage functions with a Home screen user interface (UI). Frequently used functions are conveniently available on the Home screen in a matrix design represented by large menu buttons for ease of use. A selection of menu configurations is also displayed on the Home screen, which can be customized to populate repeatedly used menus instead of using the default selection, for quick access.
- Samsung DB22D DB-D Series - 22" Class (21.5" viewable) LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 22"
- Diagonal Size
- 21.5"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Max Number of Screens
- 225
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- TV Tuner
- No tuner
- Commercial Features
- SMART Signage Platform, Image Rotation, Magic Clone
- Speaker System
- 1 speaker
- USB
- 2 ports
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 40 Watt
- Power Consumption (On mode)
- 31 W
- Power Consumption Stand by
- 0.3 Watt
- Energy Consumption per Year
- 43 kWh
- Dimensions (WxDxH) - without stand
- 50.75 cm x 5.78 cm x 31.12 cm
- 3.3 kg
- Product Type
- Energy Class
- Class B
- 40 Watt
- 31 W
- 43 kWh
- Diagonal Class
- 22"
- Diagonal Size
- 21.5"
- Commercial Use
- Series
- DB-D Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- Dimensions
- Without stand
- 50.75 cm
- 5.78 cm
- 31.12 cm
- 3.3 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- LED backlight
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 1000:1
- Dynamic Contrast Ratio
- 50000:1
- Brightness
- 250 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 170 degrees
- Pixel Pitch
- 0.2482 x 0.2482mm
- Response Time
- 5 ms
- Pivot, Multiple Display Control (MDC), MagicInfo, security lock slot (cable lock sold separately), e-LED BLU
Video Wall
- 225
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 100 x 100 mm
Media Player
- USB Port
- USB Ports Qty
- 2
Remote Control
- Remote control
Audio System
- Speaker System
- 1 speaker
- Output Power / Total
- 10 Watt
- Speakers
- 1 x main channel speaker - 10 Watt
- Connector Type
- HDMI input , VGA input , Serial input , Audio line-in , Multiple Display Control , 2 x USB 2.0
- Cables Included
- VGA cable , Serial cable
- Power Device
- Power supply
- Input Voltage
- 0.3 Watt
- Width (Shipping)
- 57 cm
- Depth (Shipping)
- 12.8 cm
- Height (Shipping)
- 37.6 cm
- Weight (Shipping)
- 4.5 kg
- 0 °C
- 40 °C
- 10 - 80%
