Product
Brand
Samsung DB22D 21.5" 1920x1080 VGA HDMI SOC LED Large Format Display
Quicklinx: B4STWS00 Mfr#: LH22DBDPLGC/EN
  • 1080p (Full HD)
Present your business messages in the ideal way with affordable Samsung DB22D series digital signage that delivers flexible connectivity and high indoor performance. The affordable, embedded, all-in-one media solution with improved performance makes it easy to manage content while maintaining low total cost of ownership (TCO). Economical 21.5 inches Samsung DBD series digital signage features a distinctive, sleek design. Turn your small space into creative advertising and effective information sharing with Samsung's small-sized signage solution.
Samsung DB22D DB-D Series - 22" Class (21.5" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
22"
Diagonal Size
21.5 in
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Wall Components Qty
225
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
TV Tuner
No tuner
Commercial Features
SMART Signage Platform, Image Rotation, Magic Clone
Speaker System
1 speaker
USB
2 ports
Remote Control
Standard remote
Voltage
Energy Class
Class B
40 Watt
Power Consumption (On mode)
31 W
Energy Consumption per Year
43 kWh
50.75 cm x 5.78 cm x 31.12 cm
3.3 kg
Energy Class
Class B
40 Watt
31 W
43 kWh
Diagonal Class
22"
Diagonal Size
21.5 in
Commercial Use
Series
DB-D Series
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
HDCP Compatible
225
Dimensions
Without stand
50.75 cm
5.78 cm
31.12 cm
3.3 kg
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
LED backlight
Colour Depth
16.7 million colours
Image Contrast Ratio
1000:1
Dynamic Contrast Ratio
50000:1
Brightness
250 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
170 degrees
Pixel Pitch
0.2482 x 0.2482mm
Response Time
5 ms
Commercial Features
Pivot, Multiple Display Control (MDC), MagicInfo, security lock slot (cable lock sold separately), e-LED BLU
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
100 x 100 mm
Media Player
USB Port
USB Ports Qty
2
Remote Control
Standard remote
Audio System
Speaker System
1 speaker
Output Power / Total
10 Watt
Speakers
1 x main channel speaker - built-in - 10 Watt
Connector Type
HDMI input , VGA input , Serial input , Audio line-in , Multiple Display Control , 2 x USB 2.0
VGA cable , Serial cable
Power supply
Nominal Voltage
Power Consumption Stand by
0.3 Watt
Width (Shipping)
57 cm
Depth (Shipping)
12.8 cm
Height (Shipping)
37.6 cm
Weight (Shipping)
4.5 kg
10 - 80%
