Samsung's touch-enabled DBE-T display packs all the power, functionality and reliability of larger professional-grade displays into a compact, affordable alternative. Adaptable to a range of business environments, these versatile displays solve the installation challenges of larger, multi-screen setups. Featuring an easy-to-use content creation platform, touch-screen functionality and the world-class picture quality Samsung customers have come to expect, Samsung Small Signage creates an immersive experience that simultaneously engages and informs customers with an easy intuitive touch interface. Don't let the complexities of display installation and maintenance limit your brand expansion and viewer interaction opportunities.
Elevate the customer experience through interactive touch and dynamic sound
The Samsung Small Signage DBE-T display transforms customer engagement into a multi-sensory experience. The display's interactive touch screen with five-point, two-drawing touch capability makes product and service navigation user-friendly and personalized. This helps promote customer engagement, which in turn, drives revenue opportunities. As a PC-less display, the DBE-T display's touch function comes fully integrated. Since the DBE-T eliminates the need for a separate PC or content management software, businesses can deploy the integrated solution without incurring additional equipment and installation costs. Built-in 5W speakers further elevate interactivity by connecting on-screen content with dynamic sound. By combining these professional-grade features with the display's sleek appearance and uniform bezel design, the DBE-T creates a truly memorable experience for customers. -
Easily manage digital signage with a simplified Home UI
Heighten efficiency and productivity with a Home Menu UI that displays frequently used functions in a large-button matrix design. Simplify usage with a selection of customizable menu configurations that allow ready access to repeatedly used menus. Generate content more easily and conveniently than ever with the Home Menu's templates for various vertical markets including grocery stores, QSRs, terminals and lobbies. Leverage these sharp, professional template layouts to produce and design content in either portrait or landscape orientation. -
Manage real-time, multi-display content through data server compatibility
For retail, corporate and transportation environments where multiple displays are installed and need to be remotely managed, such as QSRs, grocery stores, conference rooms and airport terminals, the time and effort required to update frequently-changing data in real-time can strain business operations and staff effectiveness.
- Samsung DB10E-T DBE Series - 10" Class (10.1" viewable) LED-backlit LCD display - HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 10"
- Diagonal Size
- 10.1"
- Commercial Use
- Yes - digital signage
- Resolution
- 1280 x 800
- Display Format
- 720p
- Frame Rate & Enhancement Technology
- 60 Hz Refresh Rate
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- Connectivity
- Wi-Fi
- LCD Backlight Technology
- LED backlight
- TV Tuner
- No tuner
- Commercial Features
- Image Rotation, Magic Clone, Auto Source Switching & Recovery, SMART Signage Platform 3nd Generation
- Speaker System
- 1 speaker
- DVR
- Flash - 4 GB
- Storage Drive Capacity
- 4 GB
- Storage Capacity
- 4 GB
- Supported Memory Cards
- SD Memory Card
- USB
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class D
- 20.9 Watt
- Power Consumption (On mode)
- 18 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 27 kWh
- Dimensions (WxDxH) - without stand
- 24.68 cm x 2.79 cm x 16.52 cm
- 700 g
- Product Type
- Energy Class
- Class D
- 20.9 Watt
- 18 W
- 27 kWh
- Diagonal Class
- 10"
- Diagonal Size
- 10.1"
- Commercial Use
- Series
- DBE Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- Modes
- Portrait mode
- Protection
- Protection glass
- Dimensions
- Without stand
- 24.68 cm
- 2.79 cm
- 16.52 cm
- 700 g
Display
- Resolution
- 1280 x 800
- Display Format
- 720p
- LED backlight
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 900:1
- Dynamic Contrast Ratio
- 50000:1
- Brightness
- 400 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.1695 x 0.1695mm
- Response Time
- 30 ms
- Multiple Display Control (MDC), e-LED BLU, MagicInfo Player-S3
Stands & Mounts
- Flat Panel Mount Interface
- 75 x 75 mm
DVR
- DVR
- Flash - 4 GB
Media Player
- SD Memory Card
- USB Port
- Configuration
- 4 GB
- 4 GB
Remote Control
- Remote control
Audio System
- Speaker System
- 1 speaker
- Output Power / Total
- 5 Watt
- Speakers
- 1 x main channel speaker - 5 Watt
Network & Internet Multimedia
- Connectivity
- Wi-Fi
- Connector Type
- HDMI input , Serial input , Multiple Display Control , USB
- Cables Included
- Serial cable
- Plug and Play, CSA, UL, TUV, VCCI, C-Tick, GOST, cUL, DDC-2B, NEMKO, NOM, SASO, CB, AS/NZS 60950-1, CCC, EMC, PSB, EK, IRAM, EN 60950-1, KCC, BSMI CNS 13438, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, cUL No.60950-1, EAC, RCM, IS13252, VCCI V-3/2010.04 Class A, CNS 14972, GOST-R 51317 series, GOST 22505-97, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, NOM-001-SCFI-1993, BIS, INMETRO, IEC60950-1, GB 4943.1-2011, AS/NZS CISPR 22:2009, EN 55024:1998+A1:2001+A2:2003, EN 55022:2006+A1:2007
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Width (Shipping)
- 30 cm
- Depth (Shipping)
- 7.9 cm
- Height (Shipping)
- 20.5 cm
- Weight (Shipping)
- 1.5 kg
- 0 °C
- 40 °C
- 10 - 80%
