Samsung DB10E-T 10.1" 1280x800 HDMI WiFi Touchscreen LED LFD
Quicklinx: BKPMWS00 Mfr#: LH10DBEPTGC/EN
Samsung's touch-enabled DBE-T display packs all the power, functionality and reliability of larger professional-grade displays into a compact, affordable alternative. Adaptable to a range of business environments, these versatile displays solve the installation challenges of larger, multi-screen setups. Featuring an easy-to-use content creation platform, touch-screen functionality and the world-class picture quality Samsung customers have come to expect, Samsung Small Signage creates an immersive experience that simultaneously engages and informs customers with an easy intuitive touch interface. Don't let the complexities of display installation and maintenance limit your brand expansion and viewer interaction opportunities.
  • Elevate the customer experience through interactive touch and dynamic sound
    The Samsung Small Signage DBE-T display transforms customer engagement into a multi-sensory experience. The display's interactive touch screen with five-point, two-drawing touch capability makes product and service navigation user-friendly and personalized. This helps promote customer engagement, which in turn, drives revenue opportunities. As a PC-less display, the DBE-T display's touch function comes fully integrated. Since the DBE-T eliminates the need for a separate PC or content management software, businesses can deploy the integrated solution without incurring additional equipment and installation costs. Built-in 5W speakers further elevate interactivity by connecting on-screen content with dynamic sound. By combining these professional-grade features with the display's sleek appearance and uniform bezel design, the DBE-T creates a truly memorable experience for customers.
  • Easily manage digital signage with a simplified Home UI
    Heighten efficiency and productivity with a Home Menu UI that displays frequently used functions in a large-button matrix design. Simplify usage with a selection of customizable menu configurations that allow ready access to repeatedly used menus. Generate content more easily and conveniently than ever with the Home Menu's templates for various vertical markets including grocery stores, QSRs, terminals and lobbies. Leverage these sharp, professional template layouts to produce and design content in either portrait or landscape orientation.
  • Manage real-time, multi-display content through data server compatibility
    For retail, corporate and transportation environments where multiple displays are installed and need to be remotely managed, such as QSRs, grocery stores, conference rooms and airport terminals, the time and effort required to update frequently-changing data in real-time can strain business operations and staff effectiveness.
Samsung DB10E-T DBE Series - 10" Class (10.1" viewable) LED-backlit LCD display - HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
10"
Diagonal Size
10.1"
Commercial Use
Yes - digital signage
Resolution
1280 x 800
Display Format
720p
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Video Interface
HDMI
HDMI Ports Qty
1 ports
Wi-Fi
LCD Backlight Technology
LED backlight
TV Tuner
No tuner
Commercial Features
Image Rotation, Magic Clone, Auto Source Switching & Recovery, SMART Signage Platform 3nd Generation
Speaker System
1 speaker
DVR
Flash - 4 GB
Storage Drive Capacity
4 GB
Storage Capacity
4 GB
Supported Memory Cards
SD Memory Card
USB
Remote control
Voltage
Energy Class
Class D
20.9 Watt
Power Consumption (On mode)
18 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
27 kWh
24.68 cm x 2.79 cm x 16.52 cm
700 g
Energy Class
Class D
20.9 Watt
18 W
27 kWh
Diagonal Class
10"
Diagonal Size
10.1"
Commercial Use
Series
DBE Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
Modes
Portrait mode
Protection
Protection glass
Dimensions
Without stand
24.68 cm
2.79 cm
16.52 cm
700 g
Display
Resolution
1280 x 800
Display Format
720p
60 Hz Refresh Rate
LED backlight
Colour Depth
16.7 million colours
Image Contrast Ratio
900:1
Dynamic Contrast Ratio
50000:1
Brightness
400 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.1695 x 0.1695mm
Response Time
30 ms
Commercial Features
Multiple Display Control (MDC), e-LED BLU, MagicInfo Player-S3
Stands & Mounts
Flat Panel Mount Interface
75 x 75 mm
DVR
DVR
Flash - 4 GB
Media Player
SD Memory Card
USB Port
Configuration
4 GB
4 GB
Remote Control
Remote control
Audio System
Speaker System
1 speaker
Output Power / Total
5 Watt
Speakers
1 x main channel speaker - 5 Watt
Network & Internet Multimedia
Wi-Fi
Connector Type
HDMI input , Serial input , Multiple Display Control , USB
Serial cable
Plug and Play, CSA, UL, TUV, VCCI, C-Tick, GOST, cUL, DDC-2B, NEMKO, NOM, SASO, CB, AS/NZS 60950-1, CCC, EMC, PSB, EK, IRAM, EN 60950-1, KCC, BSMI CNS 13438, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, cUL No.60950-1, EAC, RCM, IS13252, VCCI V-3/2010.04 Class A, CNS 14972, GOST-R 51317 series, GOST 22505-97, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, NOM-001-SCFI-1993, BIS, INMETRO, IEC60950-1, GB 4943.1-2011, AS/NZS CISPR 22:2009, EN 55024:1998+A1:2001+A2:2003, EN 55022:2006+A1:2007
Power supply
Input Voltage
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
30 cm
Depth (Shipping)
7.9 cm
Height (Shipping)
20.5 cm
Weight (Shipping)
1.5 kg
10 - 80%
