Your basket is empty
Samsung DB10E-T 10.1" 1280x800 HDMI WiFi Touchscreen LED LFD
Quicklinx: BKPMWS00 Mfr#: LH10DBEPTGC/EN
Samsung's touch-enabled DBE-T display packs all the power, functionality and reliability of larger professional-grade displays into a compact, affordable alternative. Adaptable to a range of business environments, these versatile displays solve the installation challenges of larger, multi-screen setups. Featuring an easy-to-use content creation platform, touch-screen functionality and the world-class picture quality Samsung customers have come to expect, Samsung Small Signage creates an immersive experience that simultaneously engages and informs customers with an easy intuitive touch interface. Don't let the complexities of display installation and maintenance limit your brand expansion and viewer interaction opportunities.
Samsung DB10E-T DBE Series - 10" Class (10.1" viewable) LED display
LED-backlit LCD flat panel display
Diagonal Class
10"
Diagonal Size
10.1 in
Commercial Use
Yes - digital signage
Resolution
1280 x 800
Display Format
720p
Motion Enhancement Technology
60 Hz Refresh Rate
Video Interface
HDMI
HDMI Ports Qty
1 ports
Wi-Fi
LCD Backlight Technology
LED backlight
TV Tuner
No tuner
Commercial Features
Image Rotation, Magic Clone, Auto Source Switching & Recovery, SMART Signage Platform 3nd Generation
Speaker System
1 speaker
DVR
Flash - 4 GB
Storage Drive Capacity
4 GB
Supported Memory Cards
SD Memory Card
USB
Remote Control
Standard remote
Voltage
Energy Class
Class D
20.9 Watt
Power Consumption (On mode)
18 W
Energy Consumption per Year
27 kWh
24.68 cm x 2.79 cm x 16.52 cm
700 g
Energy Class
Class D
20.9 Watt
18 W
27 kWh
Diagonal Class
10"
Diagonal Size
10.1 in
Commercial Use
Series
DBE Series
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
Modes
Portrait mode
Protection
Protection glass
Dimensions
Without stand
24.68 cm
2.79 cm
16.52 cm
700 g
Display
Resolution
1280 x 800
Display Format
720p
60 Hz Refresh Rate
LED backlight
Colour Depth
16.7 million colours
Image Contrast Ratio
900:1
Dynamic Contrast Ratio
50000:1
Brightness
400 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.1695 x 0.1695mm
Response Time
30 ms
Commercial Features
Multiple Display Control (MDC), e-LED BLU, MagicInfo Player-S3
Stands & Mounts
Flat Panel Mount Interface
75 x 75 mm
DVR
DVR
Flash - 4 GB
Media Player
SD Memory Card
USB Port
4 GB
Remote Control
Standard remote
Audio System
Speaker System
1 speaker
Output Power / Total
5 Watt
Speakers
1 x main channel speaker - built-in - 5 Watt
Network & Internet Multimedia
Wi-Fi
Connector Type
HDMI input , Serial input , Multiple Display Control , USB
Serial cable
Plug and Play, CSA, UL, TUV, VCCI, C-Tick, GOST, cUL, DDC-2B, NEMKO, NOM, SASO, CB, AS/NZS 60950-1, CCC, EMC, PSB, EK, IRAM, EN 60950-1, KCC, BSMI CNS 13438, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, cUL No.60950-1, EAC, GB4943.1-2011, RCM, EN55024:1998 + A1:2001 + A2:2003, IS13252, VCCI V-3/2010.04 Class A, CNS 14972, AS/NZS CISPR22:2009, GOST-R 51317 series, GOST 22505-97, EN55022:2006 + A1:2007, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, NOM-001-SCFI-1993, BIS, INMETRO, IEC60950-1
Power supply
Nominal Voltage
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
30 cm
Depth (Shipping)
7.9 cm
Height (Shipping)
20.5 cm
Weight (Shipping)
1.5 kg
10 - 80%
