Equipped with a variety of integrated technologies, Samsung Small Signage enables you to deliver interactive and informative content with fewer external resources required. For space-conscious businesses, the DBE-PoE display offers a minimalistic connection format conducive to multiple device usage. Instead of requiring two separate cables for power and network connectivity, the PoE-enabled display just needs one cable to deliver a high-speed network connection while supplying 30 W of power at the same time. The elimination of cables and adapters ensures tidy installation, especially when multiple displays are installed in one location. In this way, the DBE-PoE minimizes visual distraction and enhances the visual appeal of your business environment and digital signage for customers.
Deliver myriad rich content with DBE Series built-in media player and simplified management through 3rd Generation Samsung SMART Signage Platform (SSSP). The embedded, all-in-one 3rd generation SSSP eliminates the need for a separate PC or media player to streamline digital signage operation and improve total cost of ownership (TCO).
A small, yet powerful, content display for your business
Samsung Small Signage meets the reliability and durability demands of your business environment. -
Convenient, PoE-backed display connectivity for space-conscious businesses
Equipped with a variety of integrated technologies, Samsung Small Signage enables you to deliver interactive and informative content with fewer external resources required. For space-conscious businesses, the DBE-PoE display offers a minimalistic connection format conducive to multiple device usage. Instead of requiring two separate cables for power and network connectivity, the PoE-enabled display just needs one cable to deliver a high-speed network connection while supplying 30 W of power at the same time. The elimination of cables and adapters ensures tidy installation, especially when multiple displays are installed in one location. In this way, the DBE-PoE minimizes visual distraction and enhances the visual appeal of your business environment and digital signage for customers. -
Conveniently and simply manage a rich array of content with an advanced content management platform
Deliver myriad rich content with DBE Series built-in media player and simplified management through 3rd Generation Samsung SMART Signage Platform (SSSP). The embedded, all-in-one 3rd generation SSSP eliminates the need for a separate PC or media player to streamline digital signage operation and improve total cost of ownership (TCO). -
Easily manage digital signage with a simplified Home UI
Heighten efficiency and productivity with a newly designed Home Menu UI that displays frequently used functions in a large-button matrix design. Simplify usage with a selection of customizable menu configurations that allow ready access to repeatedly used menus. Generate content more easily and conveniently than ever with the Home Menu's newly designed templates for various vertical markets including grocery stores, QSRs, terminals and lobbies. Leverage these sharp, professional template layouts to produce and design content in either portrait or landscape orientation. -
A cost-efficient content management solution designed for your small business
While small- and mid-sized businesses (SMBs) and small office/home office (SOHO) business owners may not need to connect several displays with real-time or frequently-changing data as larger retail and corporate content managers require, they still value the convenience and efficiency of effective content management. As an alternative to MagicInfo DataLink, Samsung's Data Module solution is specifically designed with SMB and SOHO users in mind. Instead of requiring a MagicInfo server and DataLink license fee, the embedded Data Module connects with a business owners' existing local data storage. Information is then shared automatically from the data storage and transmitted to the MagicInfo Author tool. Using Data Module-capable Samsung Small Signage, SMBs and SOHO business owners can thus share timely and informative content more effectively with a reduced total cost of ownership (TCO).
- Samsung DB10E-POE DBE Series - 10" Class (10.1" viewable) LED-backlit LCD display - HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 10"
- Diagonal Size
- 10.1"
- Commercial Use
- Yes - digital signage
- Resolution
- 1280 x 800
- Display Format
- 720p
- Frame Rate & Enhancement Technology
- 60 Hz Refresh Rate
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- LCD Backlight Technology
- LED backlight
- TV Tuner
- No tuner
- Commercial Features
- Button lock, Image Rotation, Magic Clone, Auto Source Switching & Recovery, SMART Signage Platform 3nd Generation
- DVR
- Flash - 8 GB
- Storage Drive Capacity
- 8 GB
- Storage Capacity
- 8 GB
- Supported Memory Cards
- SD Memory Card
- USB
- Included Accessories
- Remote control, batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class D
- 20.9 Watt
- Power Consumption (On mode)
- 18 W
- Power Consumption Stand by
- 0.4 Watt
- Energy Consumption per Year
- 26 kWh
- Dimensions (WxDxH) - without stand
- 24.68 cm x 2.7 cm x 16.52 cm
- 700 g
- Product Type
- Energy Class
- Class D
- 20.9 Watt
- 18 W
- 26 kWh
- Diagonal Class
- 10"
- Diagonal Size
- 10.1"
- Commercial Use
- Series
- DBE Series
- Video Processor
- Quad-Core
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- Modes
- Portrait mode
- Dimensions
- Without stand
- 24.68 cm
- 2.7 cm
- 16.52 cm
- 700 g
Display
- Resolution
- 1280 x 800
- Display Format
- 720p
- LED backlight
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 900:1
- Dynamic Contrast Ratio
- 50000:1
- Brightness
- 400 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.1695 x 0.1695mm
- Response Time
- 30 ms
- Multiple Display Control (MDC), e-LED BLU, Certified for 16/7 Continuous Operation, MagicInfo Player-S3
Stands & Mounts
- Flat Panel Mount Interface
- 75 x 75 mm
DVR
- DVR
- Flash - 8 GB
Media Player
- SD Memory Card
- USB Port
- Configuration
- ARM Cortex-A9 ( 1 GHz ) - 1.5 GB DDR3 - 8 GB
- 8 GB
- Operating System
- Linux
Remote Control
- Remote control
- Connector Type
- HDMI input , Serial input , LAN , USB 2.0 , Audio line-out , USB 2.0 upstream
- Batteries
- Cables Included
- Serial cable
- Plug and Play, UL, C-Tick, BSMI, DDC-2B, EN55022, NOM, SASO, IEC 60950, EN55024, CB, CCC, PSB, UL 60950-1, EN 60950-1, FCC CFR47 Part 15 B, S Mark, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, EAC, CNS 13438, GB 17625.1-2012, IEC60950-1, VCCI - V-3/2014.04, AS/NZS CISPR22:2009+A1:2010, CAN/CSA-C22.2 No. 60950-1
- Power Device
- Power supply
- Input Voltage
- 0.4 Watt
- Width (Shipping)
- 30 cm
- Depth (Shipping)
- 7.9 cm
- Height (Shipping)
- 20.5 cm
- Weight (Shipping)
- 1.5 kg
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
