Samsung DB10E-PoE 10.1" 1280x800 HDMI LED Large Format Display
Quicklinx: BKPNWS00 Mfr#: LH10DBEPEBB/EN
Equipped with a variety of integrated technologies, Samsung Small Signage enables you to deliver interactive and informative content with fewer external resources required. For space-conscious businesses, the DBE-PoE display offers a minimalistic connection format conducive to multiple device usage. Instead of requiring two separate cables for power and network connectivity, the PoE-enabled display just needs one cable to deliver a high-speed network connection while supplying 30 W of power at the same time. The elimination of cables and adapters ensures tidy installation, especially when multiple displays are installed in one location. In this way, the DBE-PoE minimizes visual distraction and enhances the visual appeal of your business environment and digital signage for customers.
Deliver myriad rich content with DBE Series built-in media player and simplified management through 3rd Generation Samsung SMART Signage Platform (SSSP). The embedded, all-in-one 3rd generation SSSP eliminates the need for a separate PC or media player to streamline digital signage operation and improve total cost of ownership (TCO).
  • A small, yet powerful, content display for your business
    Samsung Small Signage meets the reliability and durability demands of your business environment.
  • Convenient, PoE-backed display connectivity for space-conscious businesses
  • Conveniently and simply manage a rich array of content with an advanced content management platform
  • Easily manage digital signage with a simplified Home UI
    Heighten efficiency and productivity with a newly designed Home Menu UI that displays frequently used functions in a large-button matrix design. Simplify usage with a selection of customizable menu configurations that allow ready access to repeatedly used menus. Generate content more easily and conveniently than ever with the Home Menu's newly designed templates for various vertical markets including grocery stores, QSRs, terminals and lobbies. Leverage these sharp, professional template layouts to produce and design content in either portrait or landscape orientation.
  • A cost-efficient content management solution designed for your small business
    While small- and mid-sized businesses (SMBs) and small office/home office (SOHO) business owners may not need to connect several displays with real-time or frequently-changing data as larger retail and corporate content managers require, they still value the convenience and efficiency of effective content management. As an alternative to MagicInfo DataLink, Samsung's Data Module solution is specifically designed with SMB and SOHO users in mind. Instead of requiring a MagicInfo server and DataLink license fee, the embedded Data Module connects with a business owners' existing local data storage. Information is then shared automatically from the data storage and transmitted to the MagicInfo Author tool. Using Data Module-capable Samsung Small Signage, SMBs and SOHO business owners can thus share timely and informative content more effectively with a reduced total cost of ownership (TCO).
Samsung DB10E-POE DBE Series - 10" Class (10.1" viewable) LED-backlit LCD display - HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
10"
Diagonal Size
10.1"
Commercial Use
Yes - digital signage
Resolution
1280 x 800
Display Format
720p
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Video Interface
HDMI
HDMI Ports Qty
1 ports
LCD Backlight Technology
LED backlight
TV Tuner
No tuner
Commercial Features
Button lock, Image Rotation, Magic Clone, Auto Source Switching & Recovery, SMART Signage Platform 3nd Generation
DVR
Flash - 8 GB
Storage Drive Capacity
8 GB
Storage Capacity
8 GB
Supported Memory Cards
SD Memory Card
USB
Remote control, batteries
Voltage
Energy Class
Class D
20.9 Watt
Power Consumption (On mode)
18 W
Power Consumption Stand by
0.4 Watt
Energy Consumption per Year
26 kWh
24.68 cm x 2.7 cm x 16.52 cm
700 g
Energy Class
Class D
20.9 Watt
18 W
26 kWh
Diagonal Class
10"
Diagonal Size
10.1"
Commercial Use
Series
DBE Series
Video Processor
Quad-Core
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
HDMI
HDMI Ports Qty
1 ports
Modes
Portrait mode
Dimensions
Without stand
24.68 cm
2.7 cm
16.52 cm
700 g
Display
Resolution
1280 x 800
Display Format
720p
60 Hz Refresh Rate
LED backlight
Colour Depth
16.7 million colours
Image Contrast Ratio
900:1
Dynamic Contrast Ratio
50000:1
Brightness
400 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.1695 x 0.1695mm
Response Time
30 ms
Commercial Features
Multiple Display Control (MDC), e-LED BLU, Certified for 16/7 Continuous Operation, MagicInfo Player-S3
Stands & Mounts
Flat Panel Mount Interface
75 x 75 mm
DVR
DVR
Flash - 8 GB
Media Player
SD Memory Card
USB Port
Configuration
ARM Cortex-A9 ( 1 GHz ) - 1.5 GB DDR3 - 8 GB
8 GB
Operating System
Linux
Remote Control
Remote control
Connector Type
HDMI input , Serial input , LAN , USB 2.0 , Audio line-out , USB 2.0 upstream
Batteries
Serial cable
Plug and Play, UL, C-Tick, BSMI, DDC-2B, EN55022, NOM, SASO, IEC 60950, EN55024, CB, CCC, PSB, UL 60950-1, EN 60950-1, FCC CFR47 Part 15 B, S Mark, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, EAC, CNS 13438, GB 17625.1-2012, IEC60950-1, VCCI - V-3/2014.04, AS/NZS CISPR22:2009+A1:2010, CAN/CSA-C22.2 No. 60950-1
Power supply
Input Voltage
0.4 Watt
Width (Shipping)
30 cm
Depth (Shipping)
7.9 cm
Height (Shipping)
20.5 cm
Weight (Shipping)
1.5 kg
10 - 80% (non-condensing)
