Built-in speakers mean this curved soundbar can deliver powerful, pure sound. Tweeters provide crisp and clear high tones while mid-range drivers deliver mid-range frequencies that are warm and detailed.
The wireless way to upgrade your TV sound
Connect your soundbar to your TV without wires and enjoy superb, powerful sound that brings programs, movies and music to life. -
Enhanced surround sound from a wider range of listening positions
Surround sound expansion expands the listening area sideways and up so it is more realistic and coming directly from the screen. You can enjoy great sound with truly immersive surround effects. -
Bluetooth connectivity
You can power on your audio system and control it from your smartphone with Bluetooth. After an initial pairing, you can quickly find the devices you want, wake them up, and stream your music.
- Samsung HW-J6001R - sound bar system - for home theatre - wireless
- Product Type
- Sound bar system - for home theatre - 2.1-channel
- Media Content Source
- USB-host
- System Components
- Subwoofer, sound bar
- Speaker Type
- Active
- Nominal Output Power (Total)
- 300 Watt
- Amplifier
- Integrated
- Bluetooth
- Audio Formats
- WAV, WMA, AAC, MP3, FLAC, OGG
- Speaker System Details
- 1 x sound bar 132 Watt 4 Ohm , 1 x subwoofer 168 Watt 3 Ohm
- Speaker Details
- Sound bar - surround x 6 - 22 Watt - at 1 kHz - 10% THD - 4 Ohm - active , Speaker - subwoofer - 168 Watt - at 100 Hz - 10% THD - 3 Ohm - active
- Silver
- Built-in Decoders
- Dolby Digital, DTS decoder, DTS Digital Surround
- Sound Effects
- Surround Sound Expansion
- Power Options
- Auto power on/off
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- USB-host
- Enclosure Colour
- Silver
- Design Features
- Curved
Speaker System
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 300 Watt
- Amplifier
- Integrated
- Sound Effects
- Bluetooth
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP)
- Recommended Placing
- Wall-mountable, under-the-TV
- Built-in Decoders
- Audio Formats
- Controls
- Input selector, power on/off, volume
- Speakers Included
- 1 x sound bar - 132 Watt - 4 Ohm - wireless , 1 x subwoofer - 168 Watt - 3 Ohm - wireless
- Speaker Details
- Sound bar - surround x 6 - 22 Watt - at 1 kHz CFR - 10% THD - 4 Ohm - active , Speaker - subwoofer - 168 Watt - at 100 Hz CFR - 10% THD - 3 Ohm - active
- Driver Details
- Subwoofer: subwoofer driver - 7"
- Connector Type
- HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , Audio line-in (mini-phone stereo 3.5 mm) , Digital audio input (optical) (TOS Link) , USB (4 PIN USB Type A)
- Included Accessories
- AC power adaptor, remote control, power cable, wall mount, 2 mounting brackets
Sustainability Information
- ENERGY STAR Certified
- Power Source
- AC power adapter
- Options
- Auto power on/off
- Dimensions (WxDxH) / Weight Details
- Sound bar: 1.078 m x 12.9 cm x 4.75 cm / 2.7 kg , Subwoofer: 45.2 cm x 15.4 cm x 33.5 cm / 6.8 kg
