Samsung CLX 8640ND Colour Laser Multifunction Printer
CALL YOUR ACCOUNT MANAGER FOR PRICING!
Quicklinx: B2ZXWS00 Mfr#: CLX-8640ND/SEE
When your business regularly needs to deliver big print or copy jobs and deliver them quickly, then you'll find that the CLX-8640ND is up the task with power to spare. With fast printing and scanning capabilities provided by a fully integrated Samsung 1 GHz Dual Core processor, office productivity increases dramatically. Large print/copy jobs are finished faster, and scan throughput is swifter. In fact, every document task you perform with the CLX-8640ND is 1.5 times quicker, allowing you to spend more time working and less time waiting around.
Scanning takes less time now too. You can enjoy the fastest duplex scan speed of any multifunction device - an impressive 70 ipm. Forget waiting forever for printouts. With an incredible 38 pages printing per minute, it's the quickest printer and copier around.
  • Twice the power delivers high performance
  • Reduce job time with faster scanning and printing
  • Save time with reliability that won't let you down
    Busy businesses can't afford to waste time with unreliable products. That's why the anti-jam technology stops stress-causing device blocks by using a roller that provides a backward friction during the paper pickup process. And with a monthly duty cycle of 200,000, productivity is kept steady and reliable.
Samsung CLX-8640ND - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
200000 impressions
Max Copying Speed
Up to 38 ppm (mono) / up to 38 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
1200 x 600 dpi (colour)
Scanning
600 x 600 dpi
Display
7"
Original Size
145 x 145 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
92 x 148 mm (min) - 216 x 1200 mm (max)
Media Type
Envelopes, plain paper, cards, labels, recycled paper, thin paper, thick paper
Standard Media Capacity
620 sheets
Max Media Capacity
2180 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
500 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to folder, scan to network
55 cm x 52.3 cm x 77.6 cm
70.4 kg
Environmental Standards
EPEAT Bronze, ENERGY STAR Qualified
Copier Type
Digital
Printing Technology
Laser - colour
200000 impressions
Display Diagonal Size
7"
Display Features
Touch screen
Standard Memory
1 GB 1 GB
Max Supported Memory
1 GB 1 GB
Hard Disk Drive
320 GB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Copying Features
Fit to page, ID Card Copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF 1.7
Automatic Duplexing
First Print Out Time B/W
9 sec
First Print Out Time Colour
11 sec
Scanning
Scan Element
CCD
Optical Resolution
600 x 600 dpi
Interpolated Resolution
4800 x 4800 dpi
Document & Media Handling
Min Original Size
145 x 145 mm
Max Original Size
Original Type
Sheets
100 sheets
Min Media Size
92 x 148 mm
Max Media Size
A4
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), 92 x 148 mm, 216 x 1200 mm
Supported Envelope Sizes
International C5 (162 x 229 mm)
620 sheets
Max Media Capacity
2180 sheets
100 sheets
500 sheets
ADF - 100 sheets size: 145 x 145 mm - Legal (216 x 356 mm) , Paper cassette - 520 sheets size: 148 x 210 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 100 sheets size: 92 x 148 mm - 216 x 1200 mm weight: 60 g/m² - 220 g/m² , Output tray - 500 sheets
Speed Details
Printing: up to 38 ppm (A4) - B/W , Printing: up to 40 ppm (Letter A) - B/W , Printing: up to 38 ppm (A4) - colour , Printing: up to 40 ppm (Letter A) - colour , Copying: up to 38 ppm (A4) - B/W , Copying: up to 40 ppm (Letter A) - B/W , Copying: up to 38 ppm (A4) - colour , Copying: up to 40 ppm (Letter A) - colour
1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
Security Protocols & Features
SSL, IPsec, IP filtering
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, HP-UX 11i v3, Sun Solaris 9, Red Hat Enterprise Linux WS 4.0, MS Windows 7, Red Hat Enterprise Linux WS 5.0, SuSE Linux Enterprise Desktop 10, SuSE Linux Enterprise Desktop 11, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), HP-UX 11.0, HP-UX 11i v2, MS Windows Server 2008, Debian Linux 5.0, Apple Mac OS X 10.4 - 10.7, Fedora 5 - 13, Ubuntu Linux 6.06 - 10.04, SuSe Linux 10.1, Debian Linux 4.0, HP-UX 11i v1, IBM AIX 5.1 - 5.4, MS Windows Server 2008 R2 x64 Edition, openSUSE 10.2 - 11.2, Mandriva 2007 - 2010
Software Included
Drivers & Utilities
1600 Watt
Power Consumption Sleep
1.5 Watt
First Copy Out Time B/W
9 sec
First Copy Out Time Colour
9 sec
WHQL, CCC, ISO 15408
EPEAT Compliant
EPEAT Bronze
ENERGY STAR Certified
55 cm
52.3 cm
77.6 cm
70.4 kg
Shipping Width
76 cm
Shipping Depth
74 cm
Shipping Height
110 cm
Sound Emission
30 dBA (idle) / 59 dBA (operating)
