With 4-in-1 versatility, the Samsung CLX-6260FW printer streamlines workflow and ensures that the office print operation is working as efficient as possible. With print, copy, scan and fax functionality, the CLX-6260FW offers flexibility and lets you work with less barriers. A host of innovative features like ID Copy, N-up copy, Scan-to-email and the convenient PC fax functionality ensure that your workforce has the necessary functionality needed to thrive in the modern world of business.
Fast and economical color printing
Businesses today need to know that they can produce a high level of printing quickly, and in a cost-effective way. The CLX-6260FW not only delivers brilliant color quality, but can scan, copy and fax for extra convenience. Plus, a fast Dual CPU, gigabit network support and instant fusing technology ensures enhanced speed and less waiting time. -
4-in-1 Multifunction
With 4-in-1 versatility, the Samsung CLX-6260FW printer streamlines workflow and ensures that the office print operation is working as efficient as possible. With print, copy, scan and fax functionality, the CLX-6260FW offers flexibility and lets you work with less barriers. A host of innovative features like ID Copy, N-up copy, Scan-to-email and the convenient PC fax functionality ensure that your workforce has the necessary functionality needed to thrive in the modern world of business. -
Now every workgroup can enjoy professional color output
Whatever size your team, and however busy you are, you can rely on the CLX-6260FW to constantly deliver professional, quality color output. Because anything less isn't good enough. -
Make sharp images and text even sharper
Samsung's unique ReCP (Rendering Engine for Clean Page) Technology improves the overall quality and vibrancy of your color printing, ensuring every printout looks perfect. It automatically sharpens the focus of both graphics and text, while solid objects are overlapped to eliminate white gaps. -
Make colors more vibrant
The newly developed polymerized toner has smaller and more uniform particles than conventional toner. Your printouts will have crisper lines and more vivid colors, in addition to eliminating paper curling. Also, its higher wax content improves the image gloss and enhances the durability preventing unwanted fading. -
High power printing performance
Whatever the size of your print job, the CLX-6260FW will shine with an impressive 17 seconds First Print Out Time, and a speedy 24 pages per minute after that. This means you can focus on what's important rather than wait for your prints. -
More power, higher productivity
Some days it seems like the printing never ends. With the CLX-6260FW's 533 MHz Dual CPU, and 512MB standard memory (expandable up to 1GB) you can be sure that this printer will handle the entire load of your workgroup's need. -
Speedy and flexible paper handling
If you want to print or copy onto heavier weights of paper, you can. Weights of up to 220g/m2 are handled with ease through the 50 page multipurpose tray as well as the 250 page standard cassette. Plus, with the optional 520 sheet second cassette you can increase your total paper input capacity to 820 sheets. That way you can also use up to three different media types without the need to waste time changing paper. -
Professional color printing made easy for you
With the CLX-6260FW you can increase your entire workgroup's workflow with a range of easy-to-use features and ingenious time-saving support software that helps free you to work smarter and faster.
- Samsung CLX-6260FW - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 60000 impressions
- Max Copying Speed
- Up to 24 ppm (mono) / up to 24 ppm (colour)
- Max Copying Resolution
- 1200 x 1200 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- 9600 x 600 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 4.3"
- Original Size
- 142 x 148 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, photo paper, film, thin paper, thick paper
- Standard Media Capacity
- 300 sheets
- Max Media Capacity
- 820 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
- Office Machine Features
- Save to USB flash drive, scan to application, scan to network
- 46.9 cm x 45.25 cm x 50.43 cm
- 26.7 kg
- Environmental Standards
- EPEAT Bronze, ENERGY STAR Qualified
- Copier Type
- Digital
- Fax Type
- Plain paper
- Laser - colour
- 60000 impressions
- Display Diagonal Size
- 4.3"
- Interface
- Max Supported Memory
- 512 MB 512 MB
- Supported Flash Memory
- SD Memory Card
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Copying Features
- ID Card Copy, collation copy
Printing
- Printer Drivers / Emulations
- PCL 5e, PostScript 3, PCL 5c, SPLC, PDF 1.7, PCL 6C
- First Print Out Time B/W
- 17 sec
- First Print Out Time Colour
- 17 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Interpolated Resolution
- 4800 x 4800 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
Fax Machine Features
- Fax forwarding, multi-send, delayed sending
Document & Media Handling
- Min Original Size
- 142 x 148 mm
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- Legal
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Com-9 (98 x 225 mm)
- 300 sheets
- 820 sheets
- 50 sheets
- 150 sheets
- Paper cassette - 250 sheets - Legal (216 x 356 mm) , Bypass tray - 50 sheets - Legal (216 x 356 mm) , Output tray - 150 sheets , ADF - 50 sheets - Legal (216 x 356 mm)
- Speed Details
- Printing: up to 24 ppm (A4) - B/W , Printing: up to 24 ppm (A4) - colour , Copying: up to 24 ppm (A4) - B/W , Copying: up to 24 ppm (A4) - colour , Printing: up to 25 ppm (Letter A) - B/W , Printing: up to 25 ppm (Letter A) - colour , Copying: up to 25 ppm (Letter A) - B/W , Copying: up to 25 ppm (Letter A) - colour
- 1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
- Operating System Support
- MS Windows XP, UNIX, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.4 - 10.7
- 450 Watt
- Power Consumption Standby
- 18 Watt
- Power Consumption Sleep
- 2.4 Watt
- First Copy Out Time B/W
- 17 sec
- First Copy Out Time Colour
- 17 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 2000 pages , 1 x toner cartridge (cyan) - up to 1500 pages , 1 x toner cartridge (magenta) - up to 1500 pages , 1 x toner cartridge (yellow) - up to 1500 pages
- ISO 19798
- EPEAT Compliant
- EPEAT Bronze
- ENERGY STAR Certified
- 46.9 cm
- 45.25 cm
- 50.43 cm
- 26.7 kg
- Shipping Width
- 60 cm
- Shipping Depth
- 60 cm
- Shipping Height
- 68 cm
- Sound Emission
- 54 dBA (operating)
