Product
Samsung CLX-6260FW Colour Laser Printer
Quicklinx: 8T29WS00 Mfr#: CLX-6260FW/SEE
With 4-in-1 versatility, the Samsung CLX-6260FW printer streamlines workflow and ensures that the office print operation is working as efficient as possible. With print, copy, scan and fax functionality, the CLX-6260FW offers flexibility and lets you work with less barriers. A host of innovative features like ID Copy, N-up copy, Scan-to-email and the convenient PC fax functionality ensure that your workforce has the necessary functionality needed to thrive in the modern world of business.
  • Fast and economical color printing
    Businesses today need to know that they can produce a high level of printing quickly, and in a cost-effective way. The CLX-6260FW not only delivers brilliant color quality, but can scan, copy and fax for extra convenience. Plus, a fast Dual CPU, gigabit network support and instant fusing technology ensures enhanced speed and less waiting time.
  • 4-in-1 Multifunction
  • Now every workgroup can enjoy professional color output
    Whatever size your team, and however busy you are, you can rely on the CLX-6260FW to constantly deliver professional, quality color output. Because anything less isn't good enough.
  • Make sharp images and text even sharper
    Samsung's unique ReCP (Rendering Engine for Clean Page) Technology improves the overall quality and vibrancy of your color printing, ensuring every printout looks perfect. It automatically sharpens the focus of both graphics and text, while solid objects are overlapped to eliminate white gaps.
  • Make colors more vibrant
    The newly developed polymerized toner has smaller and more uniform particles than conventional toner. Your printouts will have crisper lines and more vivid colors, in addition to eliminating paper curling. Also, its higher wax content improves the image gloss and enhances the durability preventing unwanted fading.
  • High power printing performance
    Whatever the size of your print job, the CLX-6260FW will shine with an impressive 17 seconds First Print Out Time, and a speedy 24 pages per minute after that. This means you can focus on what's important rather than wait for your prints.
  • More power, higher productivity
    Some days it seems like the printing never ends. With the CLX-6260FW's 533 MHz Dual CPU, and 512MB standard memory (expandable up to 1GB) you can be sure that this printer will handle the entire load of your workgroup's need.
  • Speedy and flexible paper handling
    If you want to print or copy onto heavier weights of paper, you can. Weights of up to 220g/m2 are handled with ease through the 50 page multipurpose tray as well as the 250 page standard cassette. Plus, with the optional 520 sheet second cassette you can increase your total paper input capacity to 820 sheets. That way you can also use up to three different media types without the need to waste time changing paper.
  • Professional color printing made easy for you
    With the CLX-6260FW you can increase your entire workgroup's workflow with a range of easy-to-use features and ingenious time-saving support software that helps free you to work smarter and faster.
Samsung CLX-6260FW - multifunction printer (colour)
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
60000 impressions
Max Copying Speed
Up to 24 ppm (mono) / up to 24 ppm (colour)
Max Copying Resolution
1200 x 1200 dpi (colour)
Max Printing Speed
Max Printing Resolution
9600 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi
Scanning
1200 x 1200 dpi
Display
4.3"
Original Size
142 x 148 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, photo paper, film, thin paper, thick paper
Standard Media Capacity
300 sheets
Max Media Capacity
820 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
Office Machine Features
Save to USB flash drive, scan to application, scan to network
46.9 cm x 45.25 cm x 50.43 cm
26.7 kg
Environmental Standards
ENERGY STAR Qualified, EPEAT Bronze
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - colour
60000 impressions
Display Diagonal Size
4.3"
Max Supported Memory
512 MB
Supported Flash Memory
SD Memory Card
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Automatic Duplexing
Copying Features
ID Card Copy, collation copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 5e, PostScript 3, PCL 5c, SPLC, PDF 1.7, PCL 6C
Automatic Duplexing
First Print Out Time B/W
17 sec
First Print Out Time Colour
17 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
4800 x 4800 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Fax Machine Features
Fax forwarding, multi-send, delayed sending
Document & Media Handling
Min Original Size
142 x 148 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76 x 127 mm
Max Media Size
Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Com-9 (98 x 225 mm)
300 sheets
Max Media Capacity
820 sheets
50 sheets
150 sheets
Paper cassette - 250 sheets - Legal (216 x 356 mm) , Bypass tray - 50 sheets - Legal (216 x 356 mm) , Output tray - 150 sheets , ADF - 50 sheets - Legal (216 x 356 mm)
Speed Details
Printing: up to 24 ppm (A4) - B/W , Printing: up to 24 ppm (A4) - colour , Copying: up to 24 ppm (A4) - B/W , Copying: up to 24 ppm (A4) - colour , Printing: up to 25 ppm (Letter A) - B/W , Printing: up to 25 ppm (Letter A) - colour , Copying: up to 25 ppm (Letter A) - B/W , Copying: up to 25 ppm (Letter A) - colour
1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
Operating System Support
MS Windows XP, UNIX, Linux, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.4 - 10.7
450 Watt
Power Consumption Standby
18 Watt
Power Consumption Sleep
2.4 Watt
First Copy Out Time B/W
17 sec
First Copy Out Time Colour
17 sec
Consumables Included
1 x Cartridge (black) - up to 2000 pages , 1 x Cartridge (cyan) - up to 1500 pages , 1 x Cartridge (magenta) - up to 1500 pages , 1 x Cartridge (yellow) - up to 1500 pages
ISO 19798
EPEAT Compliant
EPEAT Bronze
ENERGY STAR Certified
46.9 cm
45.25 cm
50.43 cm
26.7 kg
Shipping Width
60 cm
Shipping Depth
60 cm
Shipping Height
68 cm
Sound Emission
54 dBA (operating)
