Samsung CLX 4195FN Colour Laser Multifunction Printer
Quicklinx: 8749WS00 Mfr#: CLX-4195FN/SEE
Enjoy quality printing with high-powered performance. The Samsung CLX-4195FN Colour Laser Multifunction Printer features Samsung's ReCP technology and uses new polymerised toner, so your output will be crisper, more vibrant and more vivid than ever before. You'll also be able to print, copy, scan or fax at the touch of a button. And, with a print speed of 18 pages a minute, you won't have to wait around.
  • 4-in-1 Multifunction
    With 4-in-1 versatility, the Samsung CLX-4195FN printer streamlines workflow and ensures that the office print operation is working as efficient as possible. With print, copy, scan and fax functionality, the CLX-4195FN offers flexibility and lets you work with less barriers. A host of innovative features like ID Copy, N-up copy, Scan-to-email and the convenient PC fax functionality ensure that your workforce has the necessary functionality needed to thrive in the modern world of business.
  • Enjoy quality printouts
    Samsung's unique ReCP (Rendering Engine for Clean Page) Technology improves the overall quality and vibrancy of your black & white printing, ensuring every printout looks perfect. It automatically sharpens the focus of both graphics and text, while solid objects are overlapped to eliminate white gaps.
  • Polymerised toner
    Our newly developed polymerised toner has smaller and more uniform particles than conventional toner. Your printouts will have crisper lines and more vivid detail, in addition to eliminating paper curling. Also, its higher wax content improves the image gloss and enhances the durability preventing unwanted fading.
  • A higher level of printing performance
    Accelerating your business' productivity begins with your printer. With its 18 / 18 pages per minute output and a first page out time of just 16 seconds the CLX-4195FN doesn't let you down. More power, better productivity With the power of two cores the device can process your work files simultaneously and therefore with higher speeds. The 256MB memory ensures even heavy printing documents are spooled faster and you don't have to wait long for your print outs. What all this means for you is simple: the CLX-4195FN is perfect when there's a lot to print and a tight deadline to meet.
  • An easier user experience for you
    Your time is too precious to waste standing around a printer for hours on end. So from operation to support software tools, you're in total control with this easy-to-use, multi-function device. Easy Operating PanelIt all revolves around 4.0" colour display. It's clear, simple-to-read and it has never been easier to track your print jobs and activate every unique feature.
Samsung CLX-4195FN - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
40000 impressions
Max Copying Speed
Up to 18 ppm (mono) / up to 18 ppm (colour)
Max Printing Speed
Max Printing Resolution
9600 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi
Scanning
1200 x 1200 dpi
Original Size
142 x 148 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, photo paper, film, thin paper, thick paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
100 sheets
Connection Availability
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Save to USB flash drive, scan to e-mail
42 cm x 42.6 cm x 44.8 cm
21.44 kg
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - colour
40000 impressions
Display
4 lines
Max Supported Memory
256 MB 256 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Copying Features
ID Card Copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 5e, PostScript 3, PCL 5c, SPLC, PDF 1.7, PCL 6C
First Print Out Time B/W
16 sec
First Print Out Time Colour
16 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
4800 x 4800 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Fax Machine Features
Fax forwarding, multi-send, delayed sending
Document & Media Handling
Min Original Size
142 x 148 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
250 sheets
1 sheet
100 sheets
Paper cassette - 250 sheets - Legal (216 x 356 mm) , Bypass tray - 1 sheet - Legal (216 x 356 mm) , Output tray - 150 sheets , ADF - 50 sheets - Legal (216 x 356 mm)
Speed Details
Printing: up to 18 ppm (A4) - B/W , Printing: up to 18 ppm (A4) - colour , Copying: up to 18 ppm (A4) - B/W , Copying: up to 18 ppm (A4) - colour , Printing: up to 19 ppm (Letter A) - B/W , Printing: up to 19 ppm (Letter A) - colour , Copying: up to 19 ppm (Letter A) - B/W , Copying: up to 19 ppm (Letter A) - colour
1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
Operating System Support
MS Windows XP, UNIX, Linux, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.4 - 10.7
380 Watt
Power Consumption Standby
50 Watt
Power Consumption Sleep
1 Watt
First Copy Out Time B/W
16 sec
First Copy Out Time Colour
16 sec
Consumables Included
1 x toner cartridge (black) - up to 1000 pages , 1 x toner cartridge (cyan) - up to 700 pages , 1 x toner cartridge (magenta) - up to 700 pages , 1 x toner cartridge (yellow) - up to 700 pages
ISO 19798
42 cm
42.6 cm
44.8 cm
21.44 kg
Sound Emission
52 dBA (operating)
