Samsung color laser supplies are designed to maximize the machine performance. Constantly redesigned and improved Samsung supplies provide best performance, reliability and outstanding color printing quality. Its unique design and enhanced technology offers ease-for-use features and smart technology. Semi glossy toner makes it easy to produce brilliant and professional color documents at home. Uniformly pulverized toner produces gloss uniformity, crisp print and consistent high image quality.
Reliable performance
Compatible with original Samsung laser supplies for reliable performance. -
Security label
Samsung supplies include a color-changing security label that proves they are genuine products. When the label is tilted, the color changes from clear to cyan. Plus, the embossed characters change between red gold and blue when seen from different angles. You can also verify its originality by feeling its texture. -
Easy installation
Samsung drum is designed with the customer's convenience in mind. Each drum is easy to install and convenient to replace.
- Samsung CLT-R406 - 1 - OPC drum
- Product Type
- OPC drum
- Printing Technology
- Laser
- Yield
- Up to 16000 pages
- Included Qty
- 1
- Compatible with
- CLP-360, 365, 365W, 368; CLX-3300, 3305, 3305FN, 3305FW, 3305W; Xpress C430, C430W, C460FW, C460W, C480, C480FN, C480FW, C480W
- Shipping Width
- 33.9 cm
- Shipping Depth
- 17.4 cm
- Shipping Height
- 29.8 cm
- Shipping Weight
- 1.19 kg
Consumable
- Consumable Type
- OPC drum
- Laser
- Included Qty
- 1
- Yield
- Up to 16000 pages
- Compatible with
- Samsung CLP-360, 365, 365W, 368 , Samsung CLX-3300, 3305, 3305FN, 3305FW, 3305W , Samsung Xpress C430, C430W, C460FW, C460W, C480, C480FN, C480FW, C480W
