Give your business the printer it deserves with the CLP-775ND colour laser printer. Ulitising the 600MHz Dual-core parallel printing technology, it is Samsung's fastest colour printer and is 1.5x faster than a single core printer. Featuring the Easy Colour Manager, Secure Printing, Mobile, and Barcode Printing, it is the ideal printer for any office environment. Delivering brilliant printing results and affordable up-keep, this printer will really help office productivity.
Connect with your colleagues
Connect everyone in your office to one network and keep everything running smoothly. They'll share a common printer and you'll save time from servicing multiple machines. And with a powerful 1 Gigabit network LAN connection you can increase your performance by hooking it up to the network. Improve your communication skills with the CLP-775ND laser printer and keep your lines of communication open. -
Your printing experience just got a lot more colourful
With an almost unreal knack for colour accuracy and the power to handle the demands of premium quality 9600 x 600dpi with absolute ease, the CLP-775ND delivers high quality colour printing whenever you need it. And its Easy Colour Manager and enhanced CTD sensor ensure that colour output is always clear, sharp and professional, giving you control of your colours — allowing you to easily adjust colour balance, brightness, contrast and saturation of any image that you view on your monitor. -
Take control of office documents with Secure Printing
Important documents can easily end up in the wrong hands, especially when work printers are shared among many users. With Secure Printing you can now keep your documents safe from prying eyes using a pin code, which prevents your documents from being printed until it has been entered. Once you have sent the job to the printer, you simply go to the printer, scroll down the user interface to find your particular file, and then authorise the print by entering in the pin code. This is a simple and effective way of keeping tight control over the circulation of important documents, while also minimising unnecessary printing. -
Work better with Fast Speed printing performance
Print documents (small or large) quickly thanks to Samsung's Fast Speed printing, which is made possible with the 600MHz Dual-core parallel printing technology - 1.5 times faster than single core - and expandable memory. Perfect for getting important work documents printed with high quality and zero fuss, the faster printing speeds will also help boost office productivity and enhance workflows. A reliable and superior printer like this will quickly become a must-have business tool - you'll wonder how your business ever functioned without one. -
Free your day with a reliable printing
Utilising a semi-retard roller, which provides a unique backward friction during the paper pickup process, your operation will see increases in productivity and even bigger reductions in work frustration. Common problems that often add to stress-levels, will become things of the past. An impressive high monthly duty is one of the clear-cut and measurable benefits found with anti-jam technology, and will add to a more streamlined and reliable workflow.
