Now every business can print in true colour with speed. The Samsung CLP-680ND Colour Laser Printer uses Samsung's ReCP technology and new polymerised toner, so your printouts will be more vibrant and vivid than ever before. Thanks to print speeds of up to 18 pages a minute, you won't have to wait to see the results. You can even print onto a wide range of media, including heavier weights of paper up to 220g/m2, as well as loading more paper for us.
Enjoy quality printouts
Samsung's unique ReCP (Rendering Engine for Clean Page) Technology improves the overall quality and vibrancy of your colour printing, ensuring every printout looks perfect. It automatically sharpens the focus of both graphics and text, while solid objects are overlapped to eliminate white gaps. -
Polymerized toner
Our newly developed polymerized toner has smaller and more uniform particles than conventional toner. Your printouts will have crisper lines and more vivid colours, in addition to eliminating paper curling. Also, its higher wax content improves the image gloss and enhances the durability preventing unwanted fading. -
More power, higher productivity
Some days it seems like the printing never ends. With the CLP-680ND -
Speedy and flexible paper handling
If you want to print or copy onto heavier weights of paper, you can. Weights of up to 220g/m2 are handled with ease through the 50 page multipurpose tray as well as the 250 page standard cassette. Plus, with the optional 520 sheet second cassette you can increase your total paper input capacity to 820 sheets. That way you can also use up to three different media types without the need to waste time changing paper. -
Professional colour printing made easy for you
With the CLP-680ND you can increase your entire workgroup's workflow with a range of easy-to-use features and ingenious time-saving support software that helps free you to work smarter and faster. Easy Operating PanelWith the CLP-680ND's two line liquid crystal display and intuitive 5 key compass navigation you can control the device's status, browse the menu and access each unique feature with ease.
- Samsung CLP-680ND - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 20.15 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 24 ppm - colour - A4 (210 x 297 mm) , Up to 24 ppm - B/W - A4 (210 x 297 mm) , Up to 25 ppm - colour - ANSI A (Letter) (216 x 279 mm) , Up to 25 ppm - B/W - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (Colour)
- 9600 x 600 dpi
- Automatic Duplexing
- Interface
- USB, Gigabit LAN, USB host
- Processor
- 533 MHz
- RAM Installed (Max)
- 256 MB
- Language Simulation
- PostScript 3, PCL 6C, SPL-C, PCL 5Ce, PDF 1.7
- Media Type
- Envelopes, labels, plain paper, photo paper, cards, recycled paper, film, cotton paper, thick paper, thin paper, glossy paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 250-sheet input tray, 50-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 60000 images
- Networking
- Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
- System Requirements
- UNIX, Linux, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Apple MacOS X 10.4 - 10.7
- 42 cm x 45.25 cm x 31.13 cm
- Printer Type
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- 9600 x 600 dpi
- First Print Out Time B/W
- 17 sec
- First Print Out Time Colour
- 17 sec
- Media Handling
- Processor
- 533 MHz
RAM
- 256 MB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 76 x 127 mm, Oficio (216 x 343 mm)
- Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
- 300 sheets
- Media Feeders
- 1 x automatic - 250 sheets , 1 x automatic - 50 sheets
- Max Media Capacity
- 820 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 60000 images
- Networking
- Print server
- Data Link Protocol
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) - up to 2000 pages , 1 x toner cartridge (cyan) - up to 1500 pages , 1 x toner cartridge (magenta) - up to 1500 pages , 1 x toner cartridge (yellow) - up to 1500 pages
- Power Device
- Power supply - internal
- 450 Watt
- Power Consumption Stand by / Sleep
- 10 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- Sound Emission (Idle)
- 32 dBA
- Sound Emission (Operating)
- 52 dBA
- 42 cm
- 45.25 cm
- 31.13 cm
- 20.15 kg
- Width (Shipping)
- 57.5 cm
- Depth (Shipping)
- 55 cm
- Height (Shipping)
- 45.5 cm
