Product
Samsung CLP-680ND Colour Laser Printer
Quicklinx: 877MWS00 Mfr#: CLP-680ND/SEE
Now every business can print in true colour with speed. The Samsung CLP-680ND Colour Laser Printer uses Samsung's ReCP technology and new polymerised toner, so your printouts will be more vibrant and vivid than ever before. Thanks to print speeds of up to 18 pages a minute, you won't have to wait to see the results. You can even print onto a wide range of media, including heavier weights of paper up to 220g/m2, as well as loading more paper for us.
  • Enjoy quality printouts
    Samsung's unique ReCP (Rendering Engine for Clean Page) Technology improves the overall quality and vibrancy of your colour printing, ensuring every printout looks perfect. It automatically sharpens the focus of both graphics and text, while solid objects are overlapped to eliminate white gaps.
  • Polymerized toner
    Our newly developed polymerized toner has smaller and more uniform particles than conventional toner. Your printouts will have crisper lines and more vivid colours, in addition to eliminating paper curling. Also, its higher wax content improves the image gloss and enhances the durability preventing unwanted fading.
  • More power, higher productivity
    Some days it seems like the printing never ends. With the CLP-680ND
  • Speedy and flexible paper handling
    If you want to print or copy onto heavier weights of paper, you can. Weights of up to 220g/m2 are handled with ease through the 50 page multipurpose tray as well as the 250 page standard cassette. Plus, with the optional 520 sheet second cassette you can increase your total paper input capacity to 820 sheets. That way you can also use up to three different media types without the need to waste time changing paper.
  • Professional colour printing made easy for you
    With the CLP-680ND you can increase your entire workgroup's workflow with a range of easy-to-use features and ingenious time-saving support software that helps free you to work smarter and faster. Easy Operating PanelWith the CLP-680ND's two line liquid crystal display and intuitive 5 key compass navigation you can control the device's status, browse the menu and access each unique feature with ease.
Samsung CLP-680ND - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
20.15 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 24 ppm - colour - A4 (210 x 297 mm) , Up to 24 ppm - B/W - A4 (210 x 297 mm) , Up to 25 ppm - colour - ANSI A (Letter) (216 x 279 mm) , Up to 25 ppm - B/W - ANSI A (Letter) (216 x 279 mm)
Max Resolution (Colour)
9600 x 600 dpi
Automatic Duplexing
USB, Gigabit LAN, USB host
533 MHz
RAM Installed (Max)
256 MB
Language Simulation
PostScript 3, PCL 6C, SPL-C, PCL 5Ce, PDF 1.7
Media Type
Envelopes, labels, plain paper, glossy paper, photo paper, cards, recycled paper, film, cotton paper, thick paper, thin paper
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet multipurpose tray
Monthly Duty Cycle (max)
60000 images
Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
UNIX, Linux, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Apple MacOS X 10.4 - 10.7
42 cm x 45.25 cm x 31.13 cm
Printer Type
Printer
Print Speed
Wired
9600 x 600 dpi
Automatic Duplexing
First Print Out Time B/W
17 sec
First Print Out Time Colour
17 sec
Language Simulation
Media Handling
533 MHz
RAM
RAM Installed (Max)
256 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 76 x 127 mm, Oficio (216 x 343 mm)
Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
300 sheets
Media Feeders
1 x automatic - 250 sheets , 1 x automatic - 50 sheets
Max Media Capacity
820 sheets
Output Trays Capacity
150 sheets
Duty Cycle
60000 images
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 2000 pages , 1 x toner cartridge (cyan) - up to 1500 pages , 1 x toner cartridge (magenta) - up to 1500 pages , 1 x toner cartridge (yellow) - up to 1500 pages
Power supply - internal
450 Watt
Power Consumption Stand by / Sleep
10 Watt
Environmental Standards
ENERGY STAR
Sound Emission (Idle)
32 dBA
Sound Emission (Operating)
52 dBA
42 cm
45.25 cm
31.13 cm
20.15 kg
Width (Shipping)
57.5 cm
Depth (Shipping)
55 cm
Height (Shipping)
45.5 cm
