Samsung CHG90 49" 3840x1080 1ms (mprt) HDMI Display Port C-VA Monitor
Quicklinx: D73YWS00 Mfr#: LC49HG90DMUXEN
Diagonal Size: 49in
Max Resolution: 3840 x 1080
Response Time: 1ms
Speakers: None
Interfaces: DisplayPort, HDMI, Mini DisplayPort
26 in stock
£847.07 ex VAT
£1,016.48 inc VAT
Discover the ground-breaking 49-inch super ultra-wide curved monitor from Samsung, with 32:9 aspect ratio. Giving you a more comfortable viewing experience and more realistic colours with Quantum dot and HDR technology. The CHG90 49" monitor make working in the office easy with powerful multi-tasking with picture-by-picture and easy setting software.
Display more of your documents
With its 32:9 aspect ratio the 49" super ultra-wide curved panel provides all the space you need to display more of your data-rich documents. The CHG90 offers a view so panoramic that you can keep many windows open at once and work comfortably with less scrolling and zooming.
Display more documents
No more dual-monitor inconvenience
Equivalent to two 27" monitors side by side, the super ultra-wide panel eliminates the need for traditional dual monitor setups with mismatched screens, awkward bezel breaks and multiple cables cluttering your office space. With the CHG90 QLED monitor, you can do it all on a single monitor.
Dual monitor inconvenience
More lifelike color
HDR and Samsung’s advanced QLED technology are capable of producing more realistic color than conventional monitor technologies. Which means that whatever the task in front of you, you can be sure the colors you see onscreen are truer to those around you.
More lifelike colour
Maximum multitasking efficiency
The Picture-by-Picture function simultaneously displays input from different devices without losing any of the original image quality. You can simply hook up your Galaxy S8/S8+with the Samsung DEX Station to manage all your mobile content alongside other onscreen projects.
Work smarter with Easy setting box Soft Ware
With its intuitive interface and options designed for maximum efficiency, Easy Setting Box Soft Ware lets you quickly and easily partition the screen or display multiple screens of various sizes in a variety of configurations. Multitask smarter with Easy setting box.
Work smarter
PIP + DeX Station
Letting you resize a second image up to 25% of the screen and position it anywhere you want, Picture-in-Picture makes multitasking simple whatever you are working on. And connect the DeX Station to keep any eye on all your mobile calls, messages and more.
PIP and Dex
Ideal for long hours of work
Engineered to match the natural curvature of your eyes, the ergonomic 1800R curved panel offers enhanced viewing comfort compared to traditional flat screens. And Samsung’s Flicker Free technology and blue light-reducing Eye Saver Mode minimize eye fatigue when working for extended periods.
Enhanced speed and fine control
The superfast response time, 144hz screen refresh rate, and AMD freeSync maximize productivity when working with photo and video files, ensure smoother display and playback, and provide fine cursor control for accuracy. With the CHG90, you can handle even the most demanding tasks with ease.
Enhanced speed and control
Increase your ergonomic efficiency
It swivels, tilts, and is height-adjustable, compatible with VESA-standard monitor arms. With these functions at your disposal, you can effortlessly position your screen at whatever height and angle you want and share the onscreen content with nearby coworkers.
Increased ergonomic efficiency
Multiple input ports that connect to any device
Featuring DP, Mini-DP and multiple HDMI and USB ports, the CHG90 lets you connect almost any device you can imagine with minimum fuss. So, whatever device you, your colleagues, or your clients choose to use, you can always rely on the CHG90.
Multiple ports
  • HDR changes the game
    The CHG90 features support for HDR, so dark areas are darker and bright areas are brighter. See mind-blowing detail and contrast as bright blue skies share the screen with deep shadows and silhouettes.
  • Built for speed
    Blending its advanced motion blur reduction technology with its superior panel, Samsung has created this curved monitor with a super-fast motion picture response time that lets you enjoy unprecedented gaming performance without motion blur across the entire screen.
  • Smoother gameplay
    The fast screen refresh rate ensures you flawlessly smooth action scenes even in games with high frame rates. And you can adjust the refresh rate when necessary.
  • Play for longer
    The CHG90 features an eye-saver mode which cuts down blue light emissions to a substantial extent. So, play on with reduced eyestrain and greater visual comfort.
  • Seamless multitasking
    Equivalent to two 16:9 monitors side by side, the 32:9 super ultra-wide screen provides the ultimate in multitasking flexibility.
Samsung C49HG90DMU - CHG9 Series - QLED monitor - curved - 49"
QLED monitor - 49"
Energy Class
Class B
Energy Consumption per Year
104 kWh
Power Consumption (On mode)
71 W
Curved Screen
USB 3.0 hub
Panel Type
VA
Aspect Ratio
32:9
Native Resolution
3840 x 1080 at 144 Hz
Brightness
600 cd/m²
Response Time
1 ms
Colour Support
1.07 billion colours
Input Connectors
2xHDMI, DisplayPort, Mini DisplayPort
Display Position Adjustments
Height, swivel, tilt
Black coal
120.3 cm x 38.16 cm x 52.55 cm
15 kg
Display Type
QLED monitor / TFT active matrix
Energy Class
Class B
104 kWh
71 W
Diagonal Size
49"
Viewable Size
48.9"
Curved Screen
Yes (1800R)
Built-in Devices
USB 3.0 hub
Panel Type
VA
Aspect Ratio
32:9
Native Resolution
Brightness
600 cd/m²
Colour Support
Response Time
1 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HighBrightness, picture by picture, Cinema Mode, Mega Dynamic Contrast Ratio, 92% Adobe RGB colour gamut, CustomColor Mode, On-screen Digital Controls, FPS Mode, RTS Mode, Factory Calibration, Eye Saver Mode, DAS Mode (Dynamic Action Sync), Quantum Dot Technology, 1ms Motion Blur Reduction, HDR (high dynamic range), RPG Mode
Black coal
120.3 cm x 38.16 cm x 52.55 cm - with stand
15 kg
2 x HDMI , DisplayPort , Mini DisplayPort , Headphones , 2 x USB 3.0 , USB 3.0 upstream , Audio line-in
Mechanical
Tilt Angle
-2/+15
Swivel Angle
30
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable , 1 x HDMI cable
71 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Easy Setting Box
Dimensions & Weight Details
With stand - width: 120.3 cm - depth: 38.16 cm - height: 52.55 cm - weight: 15 kg , Without stand - width: 120.3 cm - depth: 19.44 cm - height: 36.94 cm
10 °C
10 - 80% (non-condensing)
Samsung CHG90 49 Bundle deal on Samsung CHG90 49" 3840x1080 1ms (mprt) HDMI Display Port C-VA Monitor
£946.83
Diagonal Size: 49in
Response Time: 1ms
Speakers: None
Interfaces: HDMI
Interfaces: Mini DisplayPort
Brand: Samsung
Price Range Ex VAT: 750 - 1000
