Samsung C43J890DKU 43" 3480x1200 5ms HDMI LED Monitor
Quicklinx: F5JSWS00 Mfr#: LC43J890DKUXEN
Diagonal Size: 43in
Max Resolution: 3840 x 1200
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, USB-C
More than 50 in stock
£668.22 ex VAT
£801.86 inc VAT
With a feature set as impressive as its ultra-wide curved screen, Samsung's CJ89 monitor is designed to improve performance in any workplace. So whatever your task, enjoy working smarter with Samsung.
  • Goodbye to dual
    With no bezel blind spots, perfectly matched image quality even from different sources, and fewer cables cluttering your desktop, the CJ89 is the smart alternative to dual monitor setups.
  • Double your view
    Picture-by-picture lets you display input from two PCs simultaneously for effortless collaboration with colleagues or clients. Simply connect a second device, such as a laptop, to instantly view its display side by side with your primary PC's display.
  • Built-in KVM switch
    When two devices are connected to the CJ89, its built-in KVM switch lets you control them both using just one keyboard and mouse. Multitask more efficiently and save desk space at the same time.
  • Fast refresh rate
    The rapid screen refresh rate provides flawlessly smooth scene and can be adjustable to 60Hz/120Hz for optimized monitor performance.
  • Multiple inputs
    Featuring DP, HDMI, USB and USB Type-C inputs, the CJ89 lets you connect almost any device you can imagine. And with built-in stereo speakers, you can be sure that whatever you, your colleagues, or your clients bring to the table, your monitor is up to the task.
  • Curved for comfort
    When you view a flat screen monitor for an extended time, your eyes make small but continual focus shifts that lead to increased fatigue. The CJ89's curved display lets your eyes maintain a constant focus across the entire screen, resulting in less fatigue and a more comfortable viewing experience.
  • Optimized view
    The swivel/tilt and height-adjustable stand offers all the flexibility you need to position the screen for maximum comfort.
Samsung C43J890DKU - CJ89 Series - LED monitor - curved - 43"
LED-backlit LCD monitor - 43"
Energy Class
Class B
Energy Consumption per Year
86 kWh
Power Consumption (On mode)
59 W
Curved Screen
KVM Switch, USB 3.0/USB-C hub
Panel Type
VA
Aspect Ratio
32:10
Native Resolution
3840 x 1200 at 120 Hz
Brightness
300 cd/m²
Contrast Ratio
3000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Height, swivel, tilt
Dark grey/blue
106.27 cm x 31.44 cm x 52.46 cm
13 kg
Display Type
Energy Class
Class B
86 kWh
59 W
Diagonal Size
43"
Viewable Size
43.4"
Curved Screen
Yes (1800R)
Built-in Devices
Panel Type
VA
Aspect Ratio
32:10
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, Magic Upscale, Flicker Free technology, Image Size, Eye Saver Mode, Factory Tunning, Smart Eco Saving, Off Timer Plus, Custom Key, Picture-in-Picture, Picture-by-Picture
Dark grey/blue
106.27 cm x 31.44 cm x 52.46 cm - with stand
13 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
DisplayPort , HDMI , USB-C upstream , USB 3.0 downstream , 2 x USB 2.0 downstream , 2 x USB-C , Headphones
Mechanical
Tilt Angle
-2/+17
Swivel Angle
30
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
DisplayPort cable , USB-C cable
AC 120/230 V
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 106.27 cm - depth: 31.44 cm - height: 52.46 cm - weight: 13 kg , Without stand - width: 106.27 cm - depth: 17.44 cm - height: 35.92 cm - weight: 10.2 kg
Shipping Width
114.9 cm
Shipping Depth
44.5 cm
Shipping Height
27.4 cm
Shipping Weight
17.8 kg
10 °C
10 - 80% (non-condensing)
Samsung C43J890DKU 43 Bundle deal on Samsung C43J890DKU 43" 3480x1200 5ms HDMI LED Monitor
£767.39
Diagonal Size: 43in
Response Time: 5ms
Interfaces: HDMI
Interfaces: USB-C
Brand: Samsung
Price Range Ex VAT: 500 - 750
